Problem to run kEpsilonSST in OpenFOAM
Like Tree1Likes
  • 1 Post By ignacio
Old   May 22, 2013, 11:58
Default Problem to run kOmegaSST in OpenFOAM
Anselme Bonnet
OpenF is on a distinguished road
Hi everyone,
I'm trying to adapt the tutorial "motorBike" which contains kOmegaSST turbulence model to my own case "the Backward facing step".
I'm not running in parallel. I just implemented the classical files to run a computation.
The computation starts and the residuals look good except "time step continuity errors" which crash.
I don't understand where the problem is. My boundaries conditions seem good.
I get this error in the terminal.
smoothSolver: Solving for Ux, Initial residual = 0.545989, Final residual = 0.0462827, No Iterations 34
smoothSolver: Solving for Uy, Initial residual = 0.495099, Final residual = 0.0440825, No Iterations 28
GAMG: Solving for p, Initial residual = 0.999999, Final residual = 0.104651, No Iterations 1000
time step continuity errors : sum local = 7.15765e+24, global = -1.17591e+21, cumulative = -1.17591e+21
smoothSolver: Solving for omega, Initial residual = 0.962478, Final residual = 0.0860166, No Iterations 18
smoothSolver: Solving for k, Initial residual = 0.53023, Final residual = 2.24728e-06, No Iterations 1
ExecutionTime = 125.26 s ClockTime = 126 s
Time = 34
smoothSolver: Solving for Ux, Initial residual = 0.388555, Final residual = 192672, No Iterations 1000
smoothSolver: Solving for Uy, Initial residual = 0.448615, Final residual = 32484.1, No Iterations 1000
#0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#4 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#5 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#6 Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam220/platforms/linux64GccDPOpt/bin/simpleFoam"
#9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
Floating point exception (core dumped)
I will be very grateful if someone could help me ! If necessary I can provide other files.
Best regards,
Anselme
OpenF is offline   Reply With Quote
Old   May 24, 2013, 10:49
Anselme Bonnet
The computation is still crahing after 34 iterations.. After reading some threads about running in parallel, I think the error come from the turbulence model implementation because originally, the motorbike tutorial is implemented to run in parallel and files "fvSchemes" and "fvSolution" have not been changed. I don't know..
Maybe some files will be usefull to debug the code..
Thank you very much for your assistance !
fvScheme
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         steadyState;
gradSchemes
    default         Gauss linear;
divSchemes
    default         none;
    div(phi,U)      bounded Gauss linearUpwindV grad(U);
    div(phi,k)      bounded Gauss upwind;
    div(phi,omega)  bounded Gauss upwind;
    div((nuEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    p;
fvSolution
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    p
        solver          PCG;
        preconditioner  DIC;
        tolerance        1e-7;
        relTol           0.1;
    U
        solver          PBiCG;
        preconditioner  DILU;
        tolerance        1e-8;
        relTol           0.1;
        nSweeps          1;
    k
        solver          PBiCG;
        tolerance        1e-8;
        relTol           0.1;
    omega
        solver          PBiCG;
        tolerance        1e-8;
        relTol           0.1;
SIMPLE
    nNonOrthogonalCorrectors 0;
potentialFlow
    nNonOrthogonalCorrectors 10;
relaxationFactors
    fields
        p               0.3;
    equations
        U               0.7;
        k               0.7;
        omega           0.7;
cache
    grad(U);
ControlDict
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
application     simpleFoam;
startFrom       latestTime;
startTime       0;
stopAt          endTime;
endTime         20000;
deltaT          1;
writeControl    timeStep;
writeInterval   200;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable true;
U file
FoamFile
version 2.0;
format ascii;
class volVectorField;
location "0";
object U;
#include "include/initialConditions"
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
inlet
type fixedValue;
value uniform (10 0 0);
outlet
type zeroGradient;
lowerWall
type fixedValue;
value uniform (0 0 0);
upperWall
type fixedValue;
frontAndBack
type empty;
p file
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0";
    object      p;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform $pressure;
boundaryField
    inlet
        type            zeroGradient;
    outlet
        type            fixedValue;
        value           $internalField;
    lowerWall
        type            zeroGradient;
    upperWall
        type            zeroGradient;
    frontAndBack
        type            empty;
Initialconditions
flowVelocity         (10 0 0);
pressure             0;
turbulentKE          0.24;
turbulentOmega       1.78;
#inputMode           merge
Old   May 24, 2013, 11:41
Ignacio
ignacio is on a distinguished road
Regarding your first message. Your turbulent model is kOmega SST, kEpsilon SST does not exist
OpenF likes this.
ignacio is offline   Reply With Quote
Old   May 24, 2013, 11:51
Anselme Bonnet
Yes I'm sorry I had slipped on that one..
Thank you, I'll just correct it.
Problem running OpenFOAM 2.2.x in parallel in Centos 5 lvalvare OpenFOAM Running, Solving & CFD 33 December 9, 2020 09:44
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 12:08
[Other] how run a DNS for ZPG turbulent boundary layer on a plate with OpenFOAM? dictatore_bozorg OpenFOAM Meshing & Mesh Conversion 3 October 9, 2015 06:08
Can not run OpenFOAM in parallel in clusters, help! ripperjack OpenFOAM Running, Solving & CFD 5 May 6, 2014 16:25
How can i run case in OpenFOam? premal OpenFOAM 2 June 24, 2012 01:58
