May 17, 2013, 02:05 |
compressible low-Re turbulence model
Ehsan
Rep Power: 27 |
what low-Re models are available for compressible flows?
I know there isn't any for kOmegaSST,but what are probable replacements(for other models)?
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King. To Be or Not To Be,Thats the Question! The Only Stupid Question Is the One that Goes Unasked. |
May 17, 2013, 02:51 |
Administrator
Most low-Re models can be used also for compressible flows, assuming they are formulated in a correct way. Only hypesonic flow with very strong compressibility effects require special compressible turbulence models. You can find equation details here: http://www.cfd-online.com/Wiki/Favre...okes_equations
May 17, 2013, 09:14 |
Ehsan
Rep Power: 27 |
Thank you Mr.Larrson.
I noticed befor that for example there is not any low-Re kOmegaSST model for compressible flows in OF http://www.openfoam.org/mantisbt/vie..._page.php?id=6 which low-Re model you suggest to me?how can I find the appropriate coefficients,is there an example tutorial? thanks.
May 17, 2013, 09:51 |
Ignacio
Rep Power: 13 |
Hello Ehsan,
chtMultiRegionFoam uses Low Reynolds models for compressible flows. I am using kOmega SST-LowRe with it now =) |
May 17, 2013, 10:51 |
Ehsan
Rep Power: 27 |
Hi Ignacio.
thanks for your replying. where turbulent models are there in the folder of chtMultiRegionFoam? then why Dr.Weller told me that they have not a sponsor for kOmegaSST low-Re models? could you guide me more specific to find the model and related coefficients? thanks.
June 5, 2013, 22:55 |
kkLOmegaSST
Ehsan
Rep Power: 27 |
hi
@Ignatio: Dear Ignacio Could you please tell me more how to perform a low-Re turbulent study in a compressible unsteady case? There are some folders in the solver you mentioned. And what about other settings and mesh requisits to have a low-Re study? Could you send me your case please? @Jola: Dear Jola could you introduce me some of methods that are appropriate for compressible to be more certained? is kklOmegaSST suitable(for more sure)? (Dr.Weller told me its an incompressible method) How can i find out incompressible models are also applicable for compressible cases from the formulas? What other methods exist? Thanks
June 6, 2013, 03:57 |
Administrator
Peter Jones
Rep Power: 10 |
Just make sure that when impementing the turbulence model the incompressibility condition of zero divergence of the velocity field has not been used. In compressible flows this assumption is not correct and you can not use it in for example the Boussinesq eddy viscosity assumption. CFD-Wiki has more info, look for example here:
http://www.cfd-online.com/Wiki/Bouss...ity_assumption |
June 10, 2013, 09:09 |
Ehsan
Rep Power: 27 |
Hi
I'm using low-Re kOmegaSST but time step is too low(about 5e-10) due to small cell near the wall I assume.how can improve it for having more quick run?
June 11, 2013, 04:58 |
#9 |
Ehsan
Rep Power: 27 |
Hi again
since rhoCentralFoam is explicit I changed to sonicFoam. also now I use LaunderSharmaKE. now run is rapid enough.but a problem is seen in the first top cell in opening.its pressure goes too high.I think because velocity is near zero in the first cell center(in laminar-sublayer) and since I have set a totalPressure in opening the pressure in the cell near the wall goes high.am I right?! or its only because of mesh in flow-direction that is much bigger than normal to wall direction? I'll attach a figure soon/.
paper request for lien cubic low Re and lien leschziner low re turbulence model | romant | OpenFOAM | 4 | February 2, 2017 09:52 |
Turbulence model for low Reynolds number flow? | Nokadu | Main CFD Forum | 3 | May 26, 2013 11:42 |
Wrong calculation of nut in the kOmegaSST turbulence model | FelixL | OpenFOAM Bugs | 27 | March 27, 2012 09:02 |
a low Re number model for impinging jets | mahesh prakash | Main CFD Forum | 14 | September 3, 1999 16:40 |
