inlet outlet boundary using timeVaryingMappedFixedValue
Like Tree3Likes
  • 1 Post By Gildeh
  • 1 Post By zhengzh5
Old   May 15, 2013, 01:42
Default inlet outlet boundary using timeVaryingMappedFixedValue
Hossein
Gildeh is on a distinguished road
Hello All,
I need a fully developed velocity profile as an inlet boundary condition so at first I want to develop this profile in a straight pipe and use the outlet values.
I believe that I need to use timeVaryingMappedFixedValue patch in my 0/U boundary condition for velocity in the target case. And as I read the other threads, the outlet patch coordinates should be the same as the inlet in the target case (this is true in my case). According to the tutorial in the pitzDailyExptInlet, I need two dictionary that I do not know how to extract from my initial case (these are obviously the data on the outlet patch in the initial run): (i) the points dictionary in the boundaryData folder, and (ii) the U dictionary in the 0 file.
I have already checked several threads here, but could not understand how to get these data from my initial run (e.g.: Inlet reading from a different case..)
Thank you very much in for your help in advance.
Gildeh
MaySea likes this.
Gildeh is offline   Reply With Quote
Old   May 15, 2013, 01:59
Default Mapping data for every time step
Pj.
Luca
Pj. is on a distinguished road
wrong post. Delete please, sorry
Pj. is offline   Reply With Quote
Old   May 23, 2013, 15:23
Jace
zhengzh5 is on a distinguished road
Originally Posted by Gildeh View Post
Hello All,
Gildeh
hey, you can use the sample utility in OpenFOAM to extract the velocity profile on the outlet patch of your initial run and feed that to your actual run as inlet conditions.
check out application/utilities/postProcessing/sampling/sample, you will need to copy the sampleDict to your system directory and make necessary modifications to sample the outlet patch for specific fields.
you can read about the utility little more here:
http://www.openfoam.org/docs/user/sample.php
Gildeh likes this.
zhengzh5 is offline   Reply With Quote
Old   May 23, 2013, 15:37
Hossein
Hello Jace,
Thank you very much for your reply. I actually did not see the sampling utility explanation in the user guide. I will go over that and see what would be the result.
Thanks
Gildeh
Old   May 23, 2013, 16:20
Jace
Hello Jace,
Thanks
Gildeh
sounds good, let me know if you have any further question. I actually just played with timeVaryingMappedFixedValue BC recently, so everything is moreless fresh in my head =)
Gildeh likes this.
Old   May 24, 2013, 05:09
Pj.
Luca
I'm trying to do exactly the same right now. What i found is that you need to use the sample utility do sample your source case (you need to set the output format to foamFile).
Then i use a little script to reorder the files from the sample output structure to the timeVaryingMappedFixedValue input one.
You will also need to add the header to all the files, but you can do it again with a simple script.
I'm comparing the solutions right now, because it seams that i have a problem with the coordinate system. I will let you know soon with what i found. In the meantime if you share your problems and your solutions here we can help each other.
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
Inlet & Outlet Boundary Conditions dhananjay Main CFD Forum 2 December 21, 2006 11:03
Inlet & Outlet Boundary Conditions dhananjay Main CFD Forum 0 December 18, 2006 03:51
VOF Outlet boundary condition in cfd - ace JM Main CFD Forum 0 December 15, 2006 09:07
