simpleFoam MRF validation
Like Tree1Likes
  • 1 Post By crixman
Old   April 23, 2013, 19:26
Default simpleFoam MRF validation
mpl
Mark L
mpl is on a distinguished road
Hello!
I'm experimenting with the MRF capability in the simpleFoam solver (turbulence turned off). I'm trying to compare rotatingWallVelocity vs. fvOptions to establish the rotating walls. As a validation and trying to understand how to set up the problem, I'm just using a simple rotating cylinder and I'm trying to see the pressure rise at the outer boundary (like a centrifuge).
My problem is that this doesn't seem to converge. It should be a simple problem that readily converges.
I've attached my blockMeshDict, 0/p and 0/U.
Any suggestions would be appreciated!
Best regards,
Mark
0/p:
FoamFile
version 2.0;
format ascii;
class volScalarField;
location "0";
object p;
dimensions [ 0 2 -2 0 0 0 0 ];
internalField uniform 101.325;
boundaryField
ID
type fixedValue;
value uniform 101.325;
OD
type zeroGradient;
TB
type empty;
0/U:
FoamFile
version 2.0;
format ascii;
class volVectorField;
location "0";
object U;
dimensions [ 0 1 -1 0 0 0 0 ];
internalField uniform ( 0 0 0 );
boundaryField
ID
type rotatingWallVelocity;
origin (0 0 0);
axis (0 1 0);
omega 837;
// type fixedValue;
// value uniform (0 0 0);
OD
origin ( 0.0 0.0 0.0 );
axis ( 0.0 1.0 0.0 );
omega 837;
// type fixedValue;
// type surfaceNormalFixedValue;
// refValue uniform 0;
TB
type empty;
blockMeshDict:
| \\ / O peration | Version: 2.1.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 0.001;
vertices
(25 0 0)
(100 0 0)
(0 0 100)
(0 0 25)
(-25 0 0)
(-100 0 0)
(0 0 -25)
(0 0 -100)
(25 5 0)
(100 5 0)
(0 5 100)
(0 5 25)
(-25 5 0)
(-100 5 0)
(0 5 -25)
(0 5 -100)
blocks
hex (0 1 9 8 3 2 10 11) rotor (20 1 30) simpleGrading (1 1 1)
hex (3 2 10 11 4 5 13 12) rotor (20 1 30) simpleGrading (1 1 1)
hex (4 5 13 12 6 7 15 14) rotor (20 1 30 ) simpleGrading (1 1 1)
hex (6 7 15 14 0 1 9 8) rotor (20 1 30) simpleGrading (1 1 1)
edges
arc 1 2 (70.7106781202421 0 70.7106781202421)
arc 2 5 (-70.7106781202421 0 70.7106781202421)
arc 5 7 (-70.7106781202421 0 -70.7106781202421)
arc 7 1 (70.7106781202421 0 -70.7106781202421)
arc 3 0 (17.6776695300605 0 17.6776695300605)
arc 3 4 (-17.6776695300605 0 17.6776695300605)
arc 4 6 (-17.6776695300605 0 -17.6776695300605)
arc 6 0 (17.6776695300605 0 -17.6776695300605)
arc 9 10 (70.7106781202421 5 70.7106781202421)
arc 10 13 (-70.7106781202421 5 70.7106781202421)
arc 13 15 (-70.7106781202421 5 -70.7106781202421)
arc 15 9 (70.7106781202421 5 -70.7106781202421)
arc 8 11 (17.6776695300605 5 17.6776695300605)
arc 11 12 (-17.6776695300605 5 17.6776695300605)
arc 12 14 (-17.6776695300605 5 -17.6776695300605)
arc 14 8 (17.6776695300605 5 -17.6776695300605)
boundary
TB
type empty;
faces
(11 10 9 8)
(13 10 11 12)
(13 12 14 15)
(15 14 8 9)
(0 1 2 3)
(3 2 5 4)
(4 5 7 6)
(6 7 1 0)
OD
type patch;
faces
(1 9 10 2)
(13 5 2 10)
(15 7 5 13)
(7 15 9 1)
ID
type patch;
faces
(8 0 3 11)
(11 3 4 12)
(12 4 6 14)
(14 6 0 8)
mergePatchPairs
mpl is offline   Reply With Quote
Old   August 19, 2014, 13:17
crixman's Avatar
Christian
crixman is on a distinguished road
Hi Mark, did you make any progress?
I am using simpleFoam with fvOptions for MRF (OF 2.2.2.), making the geometry with Salome and meshing with cfMesh - I find it much easier to setup!
JR22 likes this.
crixman is offline   Reply With Quote
interFoam vs. simpleFoam channel flow comparison DanM OpenFOAM Running, Solving & CFD 12 January 31, 2020 16:26
simpleFoam Validation in Urban Environment using AIJ guidelines (openCAE) JR22 OpenFOAM Verification & Validation 30 July 23, 2014 10:07
CFX problem in ubuntu (linux) Vigneshramaero CFX 0 July 13, 2012 11:22
Trying to run a benchmark case with simpleFoam spsb OpenFOAM 3 February 24, 2012 10:07
CFX-Pre problem, pls help!!! cth_yao CFX 0 February 17, 2012 01:52
