Using fvOptions with interFoam in a rotating framework
Like Tree1Likes
  • 1 Post By wrcase
Old   April 16, 2013, 14:01
Default Using fvOptions with interFoam in a rotating framework
William Case
wrcase is on a distinguished road
Dear FOAMers:
I am having difficulties applying the fvOptions file (new to OpenFOAM 2.2) to do interFoam calculations in a rotating framework.
To get a better understanding, I created a minimum working example (MWE), where I defined a graduated cylinder (100 mm tall x 20 mm radius) using axisymmetry with the centerline following the y-axis. The cylinder is filled 50 mm with water and open to atmosphere on top as shown in the first image (plot of alpha1 variable). I then rotate the cylinder about the axis of symmetry and would expect the water level to rise on the side, but lower in the middle. However, I seem to get no response. In the second image, I should see a rise in pressure at the right side wall. Also attached is the case directory.
alpha1.gifpressure.gifcylinder.tar.gz
Questions:
Q1. Am I defining the cellzones correctly in blockMeshDict (first in blocks statement and 2nd in boundary statement)? Example:
blocks
    hex (   0   2   4   1   0   3   5   1) rotor (  10  50   1) simpleGrading (1 1 1)
boundary
    wall
        type wall rotor;
        faces
            ( 0 2 3 0 )  // Bottom
            ( 2 4 5 3 )  // Right
    atmosphere
        type patch rotor;
        faces
            ( 1 1 5 4 ) // Top
Q2. Am I correctly assuming the fvOptions is the way to add Coriolis and Centrifugal force terms to my momentum equation. Keep in mind that in my actual problem both play a role. Am I correctly describing this?
MRF1
    type            MRFSource;
    active          true;
    selectionMode   cellZone;
    cellZone        rotor;
    MRFSourceCoeffs
        nonRotatingPatches ();
        origin      (0 0 0);
        axis        (0 1 0);
        omega       constant 50;
Q3. Is the variable omega the rotational speed in rad/s? If so, then I have about 5 g's at the right wall, so I should definitely see something.
Thank you for your support,
Bill
wrcase is offline   Reply With Quote
Old   April 16, 2013, 16:31
Albrecht vBoetticher
vonboett is on a distinguished road
Hi Bill,
If you are in a hurry, a work around would be using interDymFoam with rotating the cylinder instead of the framework, might be interesting for comparison to the new fvOptions approach. Of course, computational costs are higher.
vonboett is offline   Reply With Quote
Old   April 16, 2013, 18:29
William Case
Hello Albrecht
It turns out if I let the simulation run longer (endTime = 20 s) I do get a rise in pressure and water begins to climb up the right wall. A look at the velocities shows that they are very slowly catching up to the wall velocity. Additionally the wall velocities at the first time step took on the value (0 0 -1) = r * omega in the -z direction, which tells me the setup and behavior are correct. It happened to respond much slower than I originally guessed.
Thank you for the suggestion, though. I may be able to apply what I learned from the testTubeMixer tutorial.
Kind regards,
Bill
lth likes this.
Old   October 11, 2013, 10:20
otm
otm is on a distinguished road
Looks like you simulated the quite classical Ekman spin-up time problem.
A quite good description can be found on this link.
http://go.owu.edu/~physics/StudentRe...asto/home.html
BR
Olle
otm is offline   Reply With Quote
fvoptions, mrfinterfoam, rotating cylinder
interFoam vs. simpleFoam channel flow comparison DanM OpenFOAM Running, Solving & CFD 12 January 31, 2020 16:26
Rotating Impeller Naith FloEFD, FloWorks & FloTHERM 22 November 5, 2012 09:53
Rotating tank problem using interFoam and an axisymmetric model Krishna Sandeep OpenFOAM 0 July 3, 2012 05:10
Vertical Axis Wind Turbine Rotating Domain Problems TWaung CFX 4 May 1, 2012 04:14
question about governing equation in CFX using rotating/non rotating reference frame rystokes CFX 0 January 12, 2010 07:14
