airFoil2D - Calculating / Printing Reynolds number of flow
Like Tree1Likes
  • 1 Post By hakonbar
Old   March 20, 2013, 07:30
Default airFoil2D - Calculating / Printing Reynolds number of flow
M. Abdul Akbar
akku is on a distinguished road
Dear Foamers,
I am running a slightly modified version of the airFoil2D tutorial in OpenFOAM. My question is; how do I calculate the Reynolds number of flow for any particular run ?. In other words is there any command or tool pre-built in OpenFOAM wherein I can make the program print the Reynolds number ?
Thanks in Advance
akku is offline   Reply With Quote
Old   March 20, 2013, 17:28
Håkon Bartnes Line
hakonbar is on a distinguished road
I don't think there is an automatic tool for this. You'll just have to choose a relevant velocity and length scale, and note down their values. For airfoils it's the convention to construct the Reynolds number with the chord length (distance from leading edge to trailing edge) and the inlet velocity. The kinematic viscosity can be found in "constant/transportProperties".
hakonbar is offline   Reply With Quote
Old   March 21, 2013, 09:30
Dongyue Li
sharonyue is on a distinguished road
Sorry for hajacking this thread.
Does anyone check the yplus of this airFoil2D?
Why yplus is so big in the boundary?Its about 17000.on the contrary in the main flow, yplus becomes zero.
sharonyue is offline   Reply With Quote
Old   April 6, 2013, 21:39
M. Abdul Akbar
Thanks for your response. Could you please check my details given below to see if I am calculating the Reynolds number correct or not. I have only included the relevant details from the relevant files to avoid clutter of data.
Block Mesh File
convertToMeters 1.00
Maximum ordinate used for the coordinates = 1.00
Transport properties file
transportModel Newtonian;
rho rho [ 1 -3 0 0 0 0 0 ] 1;
nu nu [ 0 2 -1 0 0 0 0 ] 1e-05;
U
internalField uniform (-70 0 0);
Based on the above inputs, I am calculating Reynolds number as,
Re = 70 * 1 * 1 / 10^-5 = 7,000,000.
Please confirm if what I have calculated is correct or not. Or are there some other data too which determine the calculation of Reynolds number of flow. How about units ?. I have heard in an youtube tutorial video that the units for analysis and post processing are different in OpenFOAM or something like that. Could you please clarify on how to make the units consistent.
Thanks in Advance.
Old   April 7, 2013, 15:09
Håkon Bartnes Line
Hi there,
Please keep in mind that since
"nu (the kinematic viscosity) = mu (the dynamic viscosity) / rho (the density)",
the Reynolds number is defined as
"Re_L = U*L/nu = rho*U*L/mu".
It doesn't matter in this case since rho is constant and equal to one, but the distinction would be significant if the flow were compressible, for instance.
I don't know what the "maximum ordinate" means here. Is it the size of the bounding box? In that case, the Reynolds number on the wing would be significantly smaller than what you have calculated, since it's the length of the wing from tip to trailing edge which should be the characteristic length in this case.
The units used in OpenFOAM are internally consistent, so as long as you get "convertToMeters" right, there are no nasty surprises that I can think of. I haven't heard of a mismatch between OpenFOAM and Paraview in this regard, but maybe some of the other foamers have?
Good luck with your simulations, and don't hesitate to ask if there's anything else.
-Håkon
immortality likes this.
Old   April 7, 2013, 18:12
Smile
immortality's Avatar
Ehsan
immortality is on a distinguished road
hi Abdul akbar.
Hakon,your last sentence isn't correct here because there are some bodies that feels bad in themselves when some one wants to know more.
It seems they enumerate the number of post and act jealously.
I have received some messages that tells don't ask or "your post numbers is reaching mine" or "i don't want to answer for free"
We can only be sorry for these people that don't know the value of knowledge.
We only want to know more and more ant want to help each other more and more.
immortality is offline   Reply With Quote
airfoil2d, cfd, nutilda, openfoam, reynolds number
same geometry,structured and unstructured mesh,different behaviour. sharonyue OpenFOAM Running, Solving & CFD 13 January 2, 2013 23:40
Flapping Airfoil Simulation in Low Reynolds Number Flow M.Sc_Student Main CFD Forum 0 April 6, 2010 10:30
Flow over a cilinder at critical Reynolds number Rodge FLUENT 4 July 11, 2003 11:23
High Reynolds Number Incompressible Flow Nick Lavery Main CFD Forum 3 February 19, 2002 16:47
Difficulties in solving a high Reynolds number Flow? wowakai Main CFD Forum 10 December 29, 1998 14:46
