whats the cause of error?
Like Tree4Likes
  • 3 Post By immortality
  • 1 Post By CFDUser_
Old   March 5, 2013, 17:54
Default whats the cause of error?
immortality's Avatar
Ehsan
immortality is on a distinguished road
i have written three pressure BC.and then tried to do by groovyBC.although it seems equivalent to others it don't work.
if this problem resolve i think the trouble is removed.
fixedValue p:OK
type fixedValue;
        value uniform 1023382.5;
totalPressure:OK
type totalPressure;
        rho none;
        psi psi;
        phi phi;
        p0 1023382.5;
        gamma 1.4;
but groovyBC:
type groovyBC;
        fractionExpression "1";
        valueExpression "1023382.5/pow(1+(1.4-1)*magSqr(U)/(2*1.4*287.14*T),3.5)";
        value uniform 3523382.5;
results in:
Create time
Create mesh for time = 0
PIMPLE: no residual control data found. Calculations will employ 3 corrector loops
Reading thermophysical properties
Selecting thermodynamics package hPsiThermo<pureMixture<sutherlandTransport<specieThermo<janafThermo<perfectGas>>>>>
Reading field U
Creating turbulence model
Selecting turbulence model type laminar
Creating field dpdt
Creating field kinetic energy K
Starting time loop
Courant Number mean: 0 max: 0
deltaT = 1e-06
Time = 1e-06
diagonal:  Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
PIMPLE: iteration 1
DILUPBiCG:  Solving for Ux, Initial residual = 0.9999620096, Final residual = 4.199402748e-15, No Iterations 2
DILUPBiCG:  Solving for Uy, Initial residual = 1.005998662e-08, Final residual = 7.973709578e-16, No Iterations 1
DILUPBiCG:  Solving for h, Initial residual = 0.0001693584029, Final residual = 4.837750541e-11, No Iterations 1
#0  Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2   in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#4  void Foam::divide<Foam::fvsPatchField, Foam::surfaceMesh>(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so"
#5  Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> > Foam::operator/<Foam::fvsPatchField, Foam::surfaceMesh>(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> > const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so"
#6  Foam::fv::backwardDdtScheme<Foam::Vector<double> >::fvcDdtPhiCorr(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
at rhoPimpleFoam.C:0
in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/rhoPimpleFoam"
#9  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
Floating point exception
why?
thanks for quick helps.
immortality is offline   Reply With Quote
Old   March 5, 2013, 17:57
Ehsan
the whole p is:
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p;
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform 3523382.5;//1823382.5
boundaryField
    right
        /*type fixedValue;
        value uniform 1023382.5;*/
        /*type totalPressure;
        rho none;
        psi psi;
        phi phi;
        p0 1023382.5;
        gamma 1.4;*/
        type groovyBC;
    left
      type zeroGradient;
    walls
        type zeroGradient;
    empty
        type empty;
the problem is in p(other variables are ok as i tested)
I have to write BC in groovyBC form because of more complicated main case I have to solve.
thanks very much.please answer rapidly.
Old   March 5, 2013, 19:50
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
There are several issues:
  • Divide by Zero Error I am taking a guess that there is a divide by zero in there
    If I were to start to track that one down, I would look where a divide by zero might be. Looking at what you have provided...I would say its near
    valueExpression "1023382.5/pow(1+(1.41)*magSqr(U)/(2*1.4*287.14*T),3.5)";
    which is equivalent to
    \frac{1023382.5}{\left(1+\frac{1.41*||\vec{U}||}{2*1.4*287.14*T}\right)^{3.5}}
    I see a T in the denominator, and if there is a zero there....one will have a divide by zero issue....this could be the problem
  • OpenFOAM Protip
    Using things like "please answer rapidly" will most likely do exactly the opposite of what you want. In my experience, people answer questions here for several reasons:
    • They have experienced the same problem in their own work want to save the questioner some head ache
    • They are genuinely interested in the problem and want to take the time out of their schedule and learn something for themselves and also help the person posing the questions
    • They are interested in helping future questioners that may thoroughly search the issue and stumble upon the solution to their current problem
    • The questioner has helped them in the past and they want to return the favor.
    • Fame, fortune, and super moderator status
Your BC may be giving the error when a boundary condition is corrected and has a T == zero for some reason. Honestly, without more information this is the best i can do with solving your issue...but its an educated guess at this point.
#OFProtip
chegdan is offline   Reply With Quote
Old   March 5, 2013, 20:03
Ehsan
thanks.T isn't zero and also its same for all three tests.but only in groovy it occurs.
Old   March 5, 2013, 20:23
Daniel P. Combest
did you try another time integration scheme? I see a backwardDdtScheme in your error message and there may be something happening there. Also, just to prove that its not the T in the denominator, change your value expression to
valueExpression "1023382.5/pow(1+(1.41)*magSqr(U)/(2*1.4*287.14*T + 1e-8),3.5)";
and give it a try.
Old   March 6, 2013, 06:07
Ehsan
i changed time scheme to Euler and changed T but error persists.initial U is zero and i changed it but the error didn't change
these are variable BC's:
p:
FoamFile
    version     2.0;
    format      ascii;
    object      p;
boundaryField
    right
        /*type fixedValue;
        rho none;
        psi psi;
        phi phi;
        p0 1023382.5;
        gamma 1.4;*/
        type groovyBC;
        valueExpression "1023382.5/pow(1+(1.4-1)*magSqr(U)/(2*1.4*287.14*T+1e-8),3.5)";
    left
      type zeroGradient;
    walls
        type zeroGradient;
    empty
        type empty;
U:
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (1 0 0);
boundaryField
    right
     type zeroGradient;
    left
        type fixedValue;
       value uniform (0 0 0);
        /*type groovyBC;
        variables (
        valueExpression "vector(internalField(U).x,0,0)";
        value uniform (0 0 0);*/
walls
        type fixedValue;
    empty
        type empty;
T:
FoamFile
    version     2.0;
    format      ascii;
    object      T;
dimensions      [0 0 0 1 0 0 0];
internalField   uniform 973;
boundaryField
   right
        type zeroGradient;
        /*type            groovyBC;
        value           uniform 973;
       // valueExpression "907";//T0_2-(1.4-1)*magSqr(internalField(U))/(2*1.4*287.14)
        gradientExpression "0";
        fractionExpression "0";*/
    left
      type zeroGradient;
    walls
        type zeroGradient;
    empty
        type empty;
fvSolution is:
solvers
    p
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-11;
        relTol          0;
    pFinal
        $p;
        relTol          0;
    "rho.*"
        $p;
        tolerance       1e-10;
        relTol          0;
    "(U|e|h|R|k|epsilon|omega)"
        solver          PBiCG;
        preconditioner  DILU;
        tolerance       1e-10;
        relTol          0;
        maxIter 25000;
    "(U|h|R|k|epsilon|omega)Final"
        $U;
        relTol          0;
PIMPLE
    momentumPredictor yes;
    nOuterCorrectors 3;
    nCorrectors     5;
    nNonOrthogonalCorrectors 0;
    rhoMin          rhoMin [ 1 -3 0 0 0 ] 0.01;
    rhoMax          rhoMax [ 1 -3 0 0 0 ] 100.0;
fvScheme:
ddtSchemes
    default         Euler;//backward
gradSchemes
    default         faceMDLimited Gauss midPoint 1;
    grad(p)         faceMDLimited Gauss midPoint 1;
    grad(U)         faceMDLimited Gauss cubic 1; //faceMDLimited Gauss GammaV 1
divSchemes
    default         none;
    div(phi,U)      Gauss SFCDV grad(U);//SFCDV-linearUpwind
    div(phi,K)      Gauss SuperBee;//Minmod
    div(phi,h)      Gauss SuperBee;
    div(phi,k)      Gauss SuperBee;
    div(phi,omega)  Gauss SuperBee;
    div(U)          Gauss SuperBeeV;//Gauss limitedLimitedLinear 1 0 1
    div((muEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
    default      Gauss midPoint limited .5;//limited .5
    /*laplacian(muEff,U) Gauss linear corrected;
    laplacian(mut,U) Gauss linear corrected;
    laplacian(DkEff,k) Gauss linear corrected;
    laplacian(DomegaEff,omega) Gauss linear corrected;
    laplacian((rho*(1|A(U))),p) Gauss linear corrected;
    laplacian(alphaEff,h) Gauss linear corrected;
    laplacian(k,T)   Gauss linear corrected;
    laplacian(alpha,e) Gauss linear corrected;
    laplacian(alphaEff,e)  Gauss linear corrected;*/
interpolationSchemes
    default        midPoint;// cubicCorrection
snGradSchemes
    default       limited .5;//corrected
fluxRequired
    default         no;
    p               ;
and at last controlDict:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
libs (
      "libOpenFOAM.so"
      "libsimpleSwakFunctionObjects.so"
      "libswakFunctionObjects.so"
      "libgroovyBC.so"
application     rhoPimpleFoam;
startFrom       latestTime;
startTime       0;
stopAt          endTime;
endTime         2000e-6;//0.020708089;
deltaT          1e-6;
writeControl    adjustableRunTime;
writeInterval   .000001;
purgeWrite      0;
writeFormat     ascii;
writePrecision  10;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable true;
adjustTimeStep  yes;
maxCo           0.1;
maxDeltaT       1;
Old   March 6, 2013, 11:21
Ehsan
thanks for your effort to help dear Daniel.
It was because of new groovyBC.I changed to old version and it answer now.
Old   March 6, 2013, 11:22
Daniel P. Combest
OK, it is indeed your BC setup. I don't have the time to set this up for you, but i have some suggestions.
  • go and look through the groovyBC examples, they will cover what you want. If you dont have them, google for them...they are out there
  • Start with a simpler groovyBC that will be easier to debug.
Good luck
EDIT: read your new post that just mystically appeared....glad you figured it out
Old   March 6, 2013, 12:41
Ehsan
a question occur to me that I'm curious about.
when I set BC for U to zeroGradient or:
right
     type groovyBC;
     gradientExpression "vector(0,0,0)";
it answers without any error
but when I set it to:
right
     type groovyBC;
     valueExpression "internalField(U)";//vector(internalField(U).x,0,0)
it falls to an error on T(energy equation probably) as so:
From function janafThermo<EquationOfState>::limit(const scalar T) const
in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.1/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 108
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = -3333091.721
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = 4080511.561
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = -7124696.499
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = 5774453.414
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = -6575768.989
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = 5981361.409
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = 1404258.482
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = -17090209.16
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = 36020792.5
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = -94818398.64
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = 40233402.34
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = -106376680.8
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = 37389446.51
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = -76115211.3
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = -24650104.63
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = -26951665.22
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = 471535.4463
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = 465677.0027
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = 277204.4414
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = -145721.0621
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = 15779.92442
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = 112883.4828
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = -3083.273126
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = 43.52495911
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = 4976486.257
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = 3178348.937
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = -32897237.32
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = -44825686.95
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = -22612.51171
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = -1870.615087
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = 9690.272357
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = -39521.73991
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = 93265.31041
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = -340838.0148
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = 610015.5259
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = -1813983.217
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = 2650248.864
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = -6558287.943
I thought that internalField(U) or vector(internalField(U).x,0,0) do the same way as zeroGradient(or in groovyBC gradientExpression"0" does).
why?
Old   April 21, 2014, 02:14
CFDUser
CFDUser_ is on a distinguished road
--> FOAM Warning :
Hi Ehsan,
Did you find any clue for above warning to fix?
Regards,
CFDUser_
CFDUser_ is offline   Reply With Quote
Old   April 21, 2014, 11:45
Ehsan
Originally Posted by CFDUser_ View Post
Hi Ehsan,
Regards,
CFDUser_
Hi, yes I did it ! if I remember truely, it was because of the BC. when we use zeroGradient BC it solves the equations implicitly but when use internalField the equations are solved explicitly and may be unstable although in both cases the values on the boundary and internal value is the same but in zeroGradient case we say to OpenFOAM that solve these equations so that the values on the boundary be at last equal as the value on neighbor cells but in internalField case we say put the value on the neighbor cells on the boundaries now and then solve the equations!
besides that, the velocity on outward flow should be read from inside implicitly and only pressure should be set there as a known value otherwise error will arise due to instability.
I hope these explanations be what you asked about.
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
Old   April 22, 2014, 13:32
CFDUser
Wow, This is more than expected. Thanks a lot Ehsan.
Regards,
CFDUser_
immortality likes this.
Old   July 11, 2019, 18:33
Miriana De Rose
MiriDR is on a distinguished road
I also have this problem. But I don't know how to fix it.
--> FOAM Warning :
From function Foam::scalar Foam::janafThermo<EquationOfState>::limit(Foam::sc alar) const [with EquationOfState = Foam:erfectGas<Foam::specie>; Foam::scalar = double]
in file /home/pawan/OpenFOAM/OpenFOAM-v1812/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 117
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 5000; T = -388.868
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 5000; T = -111.631
min/max(T) = 200, 1742.55
Any suggestion?
I read that the problem could be about different values in BC in the Internal Field and in the neighbor cells, but i did not understand exactly what it means!
MiriDR is offline   Reply With Quote
Old   March 24, 2021, 08:15
Evren Yilmaz Yakin
evrenykn is on a distinguished road
Hi, I have a same problem when using reactingFoamLTS
Do you have any idea about this issue?
Originally Posted by MiriDR View Post
--> FOAM Warning :
--> FOAM Warning :
Any suggestion?
Best Regards,
Evren
evrenykn is offline   Reply With Quote
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 19:00
c++ libraries and solver compiling vaina74 OpenFOAM Installation 13 February 3, 2012 18:43
[OpenFOAM] Saving ParaFoam views and case sail ParaView 9 November 25, 2011 16:46
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
user defined function cfduser CFX 0 April 29, 2006 11:58
