pipe flow OpenFOAM
Like Tree2Likes
  • 1 Post By stix
  • 1 Post By rpberlin
Old   February 28, 2013, 10:41
Default pipe flow OpenFOAM
stix is on a distinguished road
Hi!
I am new to OpenFOAM and I have to use OpenFOAM for my diploma thesis. I want to compare the results of OpenFOAM with simple examples, which can be calculated by hand. My first example is a straight pipe flow and i already have problems. My geometry is a 1mx1m quadratic tunnel with a length of 20m. I defined all boundary conditions (inlet 5 m/s, outlet pressure=0, wall ). The flow is turbulent and i use the komegaSST model for the turbulence. i simulated the flow with different mesh resolutions (various y+). The y+ values i were 30, 50, 100, 150.
Now the problem is that i calculated the pressure loss analytically and the OpenFOAM results aren't even near the exact results. They are 30% (and for high y+ values even more) away from the exact results.
Could anybody please help me with my problem?
Thanks, Daniel
immortality likes this.
stix is offline   Reply With Quote
Old   March 4, 2013, 17:44
Ryan
rpberlin is on a distinguished road
I can think of a few reasons why your pressure drop is too high.
Are you using fully-developed flow in your analytical calculations and are you specifying a flat velocity profile at the inlet?
Otherwise, can you show a couple of pictures of your mesh and your results?
mizzou likes this.
rpberlin is offline   Reply With Quote
setup problems - LES pipe flow with cyclic BC (1) and direct mapped inlet (2) florian_krause OpenFOAM 22 June 13, 2013 22:25
[GAMBIT] meshing in GAMBIT, a flow through a pipe having complex inflow geometry mazhar1613 ANSYS Meshing & Geometry 1 January 12, 2012 00:18
[ASK] Flow in Corrugated Pipe with FLUENT Primadhani FLUENT 1 May 11, 2011 21:41
Pipe Flow Saima CFX 1 January 10, 2011 17:41
Turbulence intensity in fully devloped pipe flow - Reference Shocktrain Main CFD Forum 0 October 14, 2010 07:58
