February 27, 2013, 07:08 |
channelFoam
Pedro Ramos
Rep Power: 14 |
Hello there!
I'm doing a simulation of the flow around a cylinder with the solver channelFoam. something like this: http://openfoamwiki.net/images/1/17/...rf_cylMesh.jpg Any of you is working with a similar case? I'm trying to adptate the channel395 example of openfoam but i'm not having success. Any of you have a tutorial for thys kind of problem? Please, help me. Regards. |
February 28, 2013, 16:31 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Pedro,
Can you be a bit more specific of what exactly you're trying to do? Best regards, Bruno
February 28, 2013, 16:44 |
Pedro Ramos
Rep Power: 14 |
Hello Bruno.
I'm workin in a research project at FEUP, Porto. We are trying to do a numerical simulation of the flow around a cylinder. Like this: http://www.youtube.com/watch?v=1u-Bx13PRGg The numerical investigation will be validated agains experimental data of the open channel flow around a pille. What kind of openfoam solver do you suggest? I'm trying the channelFOAM! Regards. |
March 2, 2013, 06:28 |
Bruno Santos
Rep Power: 128 |
Hi Pedro,
The solver seems to be a good choice, but it depends on a few more details:
Bruno
March 2, 2013, 16:17 |
Pedro Ramos
Rep Power: 14 |
Hello Bruno!
I changed my plans. I think I should use the interFoam solver, using the VOF method. I have no relevant experience with OpenFOAM I already build the 3D mesh with blockMesh. I need to use LES model because I want compare the results obtained by Fluent. Do you think interFoam is a good idea? Thank you so much, Bruno. Best regards. |
March 2, 2013, 20:16 |
Bruno Santos
Rep Power: 128 |
Hi Pedro,
At first I didn't even think that VOF supported LES... but then I remembered that the tutorials folder does have 3 kinds: "laminar", "ras" and "les". I don't know which specific version of OpenFOAM you're using, but if you've got 2.1.1 installed, have a look into this tutorial that 2.1.x has got: https://github.com/OpenFOAM/OpenFOAM...s/waterChannel You can then try and compare the case setup with the tutorial "multiphase/interFoam/les/nozzleFlow2D". I honestly am not sure of what else to suggest to you. The rule of thumb with OpenFOAM is to gradually work your way up from a simple case to the target case. So try to keep the geometry as simple as possible to start with. Starting with icoFoam, simpleFoam and/or pimpleFoam would help you get the feeling for how OpenFOAM works... But if you want to stick to interFoam, then I suggest that you do some simple cases similar to your target case, starting with laminar, then RAS and finally LES, always comparing with Fluent if possible, so that you can get a good feeling on how things work on OpenFOAM. This of course is if and only if you feel more at ease with Fluent In addition, do not switch to parallel mode until you really need it! OpenFOAM's VOF in parallel requires some additional calibration of the "fvSchemes" file. Searching the forum for this information should bring up some possible solutions. Best regards, Bruno
April 11, 2013, 07:01 |
Pedro Ramos
Rep Power: 14 |
Hello again!
I'm using the interFoam solver and I got tihis: https://dl.dropboxusercontent.com/u/...ier9abril3.avi I have a problem in the outlet. What boundary condition do you suggest? Best regards. |
April 11, 2013, 10:51 |
Bruno Santos
Rep Power: 128 |
Hi Pedro,
Are you talking about the detail where the water level seems to reduce on the outlet only? And what boundary conditions are you currently using? Are they identical (on the outlet) to the ones provided in the tutorial "waterChannel"? Have you confirmed if the gravity "constant/g" is pointing in the right way? By the way, I don't know if you have seen the following website: http://folk.ntnu.no/nilsol/cases/openfoam/ - it's geometrically different from what you're doing, but the type of simulation is similar.... Best regards, Bruno
April 20, 2013, 15:06 |
#9 |
Bruno Santos
Rep Power: 128 |
Hi Pedro,
I know that you've been able to go further on this topic, at least from what I've seen from this thread: http://www.cfd-online.com/Forums/ope...tml#post421781 But I'm posting here about a very recent thread I've seen just now that might be useful to you: http://www.cfd-online.com/Forums/ope...nnel-flow.html Good luck! Bruno
April 23, 2013, 06:33 |
#10 |
Pedro Ramos
Rep Power: 14 |
Thanks Bruno!
Right now, the problem is the inlet zone. As you can see here ( http://d.pr/i/yhog ) the water goes up in front of the inlet... Regards. |
April 26, 2013, 06:54 |
#11 |
Pedro Ramos
Rep Power: 14 |
April 26, 2013, 14:19 |
#12 |
Matthew Denno
Rep Power: 16 |
Hi Pedro,
Are you initializing the velocity field with setFields? I have seen that kind of wave when the inlet BC does not match the internal field. Matt |
April 26, 2013, 20:55 |
#13 |
Bruno Santos
Rep Power: 128 |
Greetings to all!
There is another possibility: the initial pressure fields might be incorrectly defined. Check the following thread for more information: http://www.cfd-online.com/Forums/ope...ity-field.html - more specifically, check post #7 Best regards, Bruno
April 29, 2013, 18:51 |
#14 |
Bruno Santos
Rep Power: 128 |
Quick note: I found today the boundary condition:
variableHeightFlowRateInletVelocityFvPatchVectorField Perhaps that boundary condition can help in not injecting too much water into the domain? I haven't re-checked the boundary conditions discussed on the related threads, to see if this is the one already being used...
May 8, 2013, 07:27 |
#15 |
Jose Rey
Rep Power: 18 |
Hi Pedro,
There was recent post that might interest you. It looks like a similar problem as the one you were having: http://www.cfd-online.com/Forums/ope...t-k-omega.html |
p equation solver in channelFoam | cheng1988sjtu | OpenFOAM Running, Solving & CFD | 0 | September 6, 2012 18:55 |
Pressure gradient, channelFoam | libra | OpenFOAM | 4 | July 11, 2012 01:40 |
Error in channelFoam Run in parallel | dhruv | OpenFOAM | 3 | March 2, 2012 06:36 |
perturbation in channelFoam? | cheng1988sjtu | OpenFOAM Running, Solving & CFD | 5 | November 2, 2011 16:36 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 14:06 |
