request for volScalarField none
Like Tree1Likes
  • 1 Post By CFDUser29
Old   January 9, 2013, 07:58
Default request for volScalarField none
operita is on a distinguished road
Dear experts,
I am trying a LES calculation in a channel with heat transfer.
The solver I am using is buoyantPimpleFoam. Cyclic boundary
conditions are set in the streamwise, spanwise direction. The
pressure drop is given by a fanPressure type boundary condition
set on p_rgh (cyclic conditions are set for p). After successfully
computing rho, Ux, Uy, Uz, h for the first time step the solver
experieces the following FATAL ERROR instead of correctly computing p_rgh
request for volScalarField none from objectRegistry region0 failed
available objects of type volScalarField are
22
div(phi)
psi
K
K_0
h
rho
rhoThermo
k
h_0
p_rgh
(1|A(U))
dpdt
gh
delta
alpha
rho_0
p
T
p_0
alphaSgs
mu
muSgs
From function objectRegistry::lookupObject<Type>(const word&) const
in file /opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/objectRegistryTemplates
.C at line 131.
Do you have an idea of why "volScalarField none" is mentioned? Thanks in advance.
operita is offline   Reply With Quote
Old   July 24, 2023, 04:42
CFDUser29 is on a distinguished road
Your post was old but I am facing the same issue and I wonder if you were able to solve your problem.
I am using reactingFoam which is also a solver using heat transfer.
I hope to hearing from you
Jialin likes this.
CFDUser29 is offline   Reply With Quote
Old   April 18, 2024, 12:36
胡瑞娘
huruiniang is on a distinguished road
Remove every parameter defined as 'none' in the 0 folder.
huruiniang is offline   Reply With Quote
[OpenFOAM] Saving ParaFoam views and case sail ParaView 9 November 25, 2011 16:46
Problem with paraFoam ata OpenFOAM 14 November 30, 2009 05:23
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 03:32
[OpenFOAM] Xwindows crash with paraview save srinath ParaView 1 October 15, 2008 10:37
Memory request Giovanni Siemens 1 September 10, 2001 13:21
