Simplefoam, steady or unsteady
Like Tree8Likes
  • 5 Post By fumiya
  • 2 Post By Naresh yathuru
  • 1 Post By Naresh yathuru
Old   December 22, 2012, 21:02
Default Simplefoam, steady or unsteady
hawkeye321 is an unknown quantity at this point
Hi FOAMERS
SIMPLEFOAM is steady, (due to the manual), but when I am running pitzDaily with it, why do I get a solution at times t = 0 to 1000 s?
hawkeye321 is offline   Reply With Quote
Old   December 22, 2012, 23:29
fumiya's Avatar
Fumiya Nozaki
fumiya is on a distinguished road
The original simpleFoam solver is for the steady calculations. In steady calculations,
deltaT has no effect on the results and is usually set to 1 so that the time means the
number of iterations.
Hope that helps,
fumiya
fumiya is offline   Reply With Quote
Old   February 20, 2013, 05:59
Malik
malaboss is on a distinguished road
If simpleFoam is for steady calculations, then why is it possible to change the ddtScheme into "Euler" rather than "steadyState" in system/fvSchemes ?
is it ok to apply this change ?
When I tested this on a cylinder at RE = 100 it gave me the same results for Cd and strouhal.
By the way, the results are far from the experiments. With the solver piso and ico, the same mesh and boundary conditions, it is better.
It makes me think that the simple Solver solver should never be used as a transient solver.
Am i right ?
malaboss is offline   Reply With Quote
Old   February 20, 2013, 06:09
Nima Samkhaniani
nimasam is on a distinguished road
simpleFoam is an steady-state solver and those changes has no effect on result
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   February 20, 2013, 06:15
Malik
Thank you, it makes sense now.
It is quite confusing to let the user write Euler in the ddtSchemes. It would be better to fix this scheme as steadyState.
Old   February 20, 2013, 10:04
Ahmed Khattab's Avatar
ahmed
Ahmed Khattab is on a distinguished road
Originally Posted by mahdiiowa View Post
Hi FOAMERS
Hi Mahdi,
i don't know exactly how openFOAM deals with steady state but, one approach is to consider it as transient called (pseudo transient) it add transient term (d/dt) and start run from sensible values like starting from rest (it is easier to get these values for transient than steady state). it deals with transient term in different way from piso algorithm to accelerate solution. finally, you should ignore all values in developing time and only take into consider values after developing time when values become fixed.
good luck
Ahmed Khattab is offline   Reply With Quote
Old   March 14, 2014, 02:51
Fengjiao Bian
jiaojiao is on a distinguished road
Hi ,Fumiya! I want to use LES turbulence model to simulate steady state of wind turbine with smagorinsky model. Could you tell me if I could choose the SimpleFoam solver?I see there are some articles with the method of LES in steady state but not in OF,So I am wondering how to achieve it. I know that LES method are usually used in trasient condition, I want to make sure does the LES inconsistent with simplefoam solver because when I run the MRFSimpleFoam ,it shows the error cannot find the file RASProperties. Could you help me ?
jiaojiao is offline   Reply With Quote
Old   March 14, 2014, 03:07
Bernhard
Bernhard is on a distinguished road
It does not make any sense to do steady state LES simulations. I would be interested in any articles showing this. Of coarse, you can run a transient solver, on a stable, physically steady case, but this does not make it a steady state solver.
Bernhard is offline   Reply With Quote
Old   March 14, 2014, 03:31
Fengjiao Bian
《Steady-State Large-Eddy Simulations to Study the Stratocumulus to Shallow Cumulus Cloud Transition 》 http://journals.ametsoc.org/doi/abs/...urnalCode=atsc
Old   August 11, 2014, 08:37
aylalisa is on a distinguished road
Hi jiaojiao,
did u find an answer on doing LES for a steady state flow?
Ayla
aylalisa is offline   Reply With Quote
Old   March 4, 2015, 05:43
Default simpleFoam steady or unsteady
  #11
Naresh Yathuru
Naresh yathuru is on a distinguished road
Hi Foamers,
I know this can be a silly question. I know that simple foam is a steady state solver and the delta T means the iteration number.
When i run my simulation i get this
Time = 1
smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 7.827025e-13, No Iterations 20
smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 5.0458368e-13, No Iterations 22
smoothSolver: Solving for Uz, Initial residual = 1, Final residual = 3.9496433e-13, No Iterations 25
GAMG: Solving for p, Initial residual = 1, Final residual = 3.6324613e-11, No Iterations 1000
time step continuity errors : sum local = 6.3981153e-14, global = 3.4832047e-17, cumulative = 3.4832047e-17
smoothSolver: Solving for omega, Initial residual = 0.17479046, Final residual = 5.3209563e-13, No Iterations 20
smoothSolver: Solving for k, Initial residual = 1, Final residual = 7.9795701e-13, No Iterations 22
ExecutionTime = 104.1 s ClockTime = 109 s
So what does No iterations mean here?
I think in trasient solvers there are inner iteration loops .
This is confusing me could some one help me. I tried to go through the simpleFoam.c but i couldnt crack it.
Regards,
Naresh
elham usefi and ViLaks like this.
Naresh yathuru is offline   Reply With Quote
Old   March 4, 2015, 06:00
Nima Samkhaniani
Those iteration numbers are for solution convergence in each time iteration
Old   March 4, 2015, 07:22
Naresh Yathuru
Thank you so much Nima for the quick reply.
Just to clarify , please correct me if i m wrong.
1. These iterations depends on the tolerance value i specify in the FVsolution.
And the tolerance is also global so it stops the simulation when the required convergence is achevied.
solvers
p
solver GAMG;
tolerance 1e-06;
relTol 1e-06;
smoother GaussSeidel;
nPreSweeps 0;
nPostSweeps 2;
cacheAgglomeration on;
agglomerator faceAreaPair;
nCellsInCoarsestLevel 10;
mergeLevels 1;
"(U|k|epsilon|omega|R|nuTilda)"
solver smoothSolver;
smoother symGaussSeidel;
tolerance 1e-06;
relTol 1e-06;
now i have a doubt if "reltol" plays a role in the inner iterations. Thank you for your time.
with regards,
Naresh
ViLaks likes this.
conversion steady to unsteady Clementhuon Siemens 7 January 26, 2012 05:33
steady to unsteady wlt_1985 FLUENT 6 December 4, 2010 17:17
Steady needs unsteady. nico Main CFD Forum 0 September 21, 2007 05:50
Turbulent: Steady or Unsteady: confusion prem FLUENT 0 March 30, 2006 11:40
steady or unsteady? (in dpm) winnie FLUENT 1 April 28, 2003 12:30
