problem in applying periodic boundary condition
Like Tree1Likes
  • 1 Post By adambarfi
Old   December 6, 2012, 06:31
Default problem in applying periodic boundary condition
adambarfi's Avatar
Mostafa Mahmoudi
adambarfi is on a distinguished road
Send a message via Yahoo to adambarfi Send a message via Skype™ to adambarfi
Hi everybody,
I've created my 2D mesh with Gambit and select two boundary as periodic BC. Then I converted it with fluentMeshToFoam. my periodic BC name was 'periodic' and actually it contains two edges of my model. I used foamUpgradeCyclics and my bc splited to two BCs:
periodic_half0
    type            cyclic;
    nFaces          93;
    startFace       50116;
    neighbourPatch  periodic_half1;
periodic_half1
    type            cyclic;
    nFaces          93;
    startFace       50209;
    neighbourPatch  periodic_half0;
then I modified the files in 0 case.
but when I ran paraFoam and want to see my meshes the below error appeared:
--> FOAM FATAL ERROR:
More than six unsigned transforms detected:
6(((4.8172043e-05 0.00028 0) (1 0 0 0 1 0 0 0 1) 0) ((5.41935484e-05 0.00028 0) (1 0 0 0 1 0 0 0 1) 0) ((6.02150538e-05 0.00028 3.32344303223e-24) (1 0 0 0 1 0 0 0 1) 0) ((6.62365592e-05 0.00028 0) (1 0 0 0 1 0 0 0 1) 0) ((7.225806455e-05 0.00028 9.50757114744e-24) (1 0 0 0 1 0 0 0 1) 0) ((7.827956985e-05 0.00028 -1.28310141797e-23) (1 0 0 0 1 0 0 0 1) 0))
    From function void Foam::globalIndexAndTransform::determineTransforms()
    in file primitives/globalIndexAndTransform/globalIndexAndTransform.C at line 185.
FOAM exiting
is here anybody here could help me?
thank you
adambarfi is offline   Reply With Quote
Old   December 6, 2012, 12:13
Aathavan
Aadhavan is on a distinguished road
have you defined periodic condition in gambit, before generating mesh?
I couldn’t remember exactly, but I think I have solved this problem changing the face ordering.
Thanks,
Aadhavan
Aadhavan is offline   Reply With Quote
Old   December 6, 2012, 13:31
adambarfi's Avatar
Mostafa Mahmoudi
Originally Posted by Aadhavan View Post
Thanks,
Aadhavan
thank you Aadhavan,
yes, I defined it in Gambit. I had solved my problem with Fluent before and now I'm trying to solve it with OpenFOAM.
what is your exact meaning of 'changing the face ordering'?
Old   December 7, 2012, 06:40
Aathavan
I found it in another thread, the message is:
" The problem were unordered cyclic patches. That sometimes happens, when you create these patches directly in the blockmeshdict.
Instead you could try to build the mesh with normal patches (type patch). Afterwards you can use createPatch together with a createpatchdict to replace the patch types with cyclic patches and couple the cells correctly"
I meant face ordering is " right face is sharing the information to left face"
Thanks,
Aadhavan
Old   December 7, 2012, 06:43
adambarfi's Avatar
Mostafa Mahmoudi
thank you Aadhavan,
I found it,too. I will test it and if I have any problem, I will be here again
Old   December 7, 2012, 07:49
Aathavan
Hi Adambarfi,
have you got success in your problem, if so please post the solution here.
Thanks,
Aadhavan
Old   August 4, 2014, 13:39
adambarfi's Avatar
Mostafa Mahmoudi
dear Aadhavan,
I know It's too late to post the solution I found for this problem, because I find it today for another project. but i think it's worthy to post the solution here so that other people can solve this problem.
I used createPatch utility to correct the order of points on cyclic patches and couple the cells correctly.
you can get the createPatchDict from here.
hope this help.
Regards,
Mostafa
mgg likes this.
strange flow of pressure boundary adjacent periodic condition oilsok FLUENT 2 May 26, 2012 13:51
Periodic Boundary Condition for upwind difference yohey44 Main CFD Forum 0 October 27, 2010 14:10
(Heattransfer) Temperature boundary condition problem suitup OpenFOAM Bugs 15 October 14, 2010 23:18
Transient outlet boundary condition problem jwillie2000 CFX 1 December 7, 2009 18:07
a problem with Boundary condition M Rad Main CFD Forum 12 November 27, 1998 13:49
