December 5, 2012, 07:46 |
interDyMFoam- Floating point exception Error
Marhamat Zeinali
Rep Power: 17 |
Hi All,
for simulating my case using with interDymFoam solver I just changed the mesh of sloshingTank2D case, I attached my case here. ( please do blockMesh before starting). before running the case I initialized the velocity by running the case with potentialFoam solver. but when I want to start the run with interDyMFoam I get the below strange error. Create time Create mesh for time = 0 Selecting dynamicFvMesh solidBodyMotionFvMesh Selecting solid-body motion function SDA Applying solid body motion to entire mesh Reading field p_rgh Reading field alpha1 Reading field U Reading/calculating face flux field phi Reading transportProperties Selecting incompressible transport model Newtonian Selecting incompressible transport model Newtonian Selecting turbulence model type laminar Reading g Calculating field g.h PIMPLE: Operating solver in PISO mode time step continuity errors : sum local = 2.85057e-06, global = 7.14331e-23, cumulative = 7.14331e-23 GAMGPCG: Solving for pcorr, Initial residual = 1, Final residual = 2.78369e-08, No Iterations 1 time step continuity errors : sum local = 1.51316e-07, global = -1.36584e-23, cumulative = 5.77747e-23 Courant Number mean: 1.35576e-06 max: 1.55603e-05 Starting time loop Interface Courant Number mean: 0 max: 0 Courant Number mean: 1.32918e-06 max: 1.52551e-05 deltaT = 0.00116279 Time = 0.00116279 solidBodyMotionFunctions::SDA::transformation(): Time = 0.00116279 transformation: ((0 0 0) (1 (0.000363523 0 0))) Execution time for mesh.update() = 0.01 s MULES: Solving for alpha1 Phase-1 volume fraction = 0.0790278 Min(alpha1) = 0 Max(alpha1) = 1 MULES: Solving for alpha1 Phase-1 volume fraction = 0.0790278 Min(alpha1) = -2.86237e-29 Max(alpha1) = 1 MULES: Solving for alpha1 Phase-1 volume fraction = 0.0790278 Min(alpha1) = -1.71602e-28 Max(alpha1) = 1 GAMG: Solving for p_rgh, Initial residual = 1, Final residual = 0.00420348, No Iterations 2 #0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::inv(Foam::Field<Foam::SymmTensor<double> >&, Foam::UList<Foam::SymmTensor<double> > const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #4 in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/interDyMFoam" #5 in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/interDyMFoam" #6 in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/interDyMFoam" #7 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #8 in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/interDyMFoam" Floating point exception could anybody explain the reason? Regards, Marhamat |
December 24, 2012, 09:49 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Marhamat,
All I could figure out was:
Another suggestion is to do gradual modifications of the original case. From the attached case, it looks like you've tried to do all modifications in a single go, which for someone not experienced with OpenFOAM this is simply a bad idea I think you should do the steps somewhat like this (also know as divide-and-conquer):
Best regards, Bruno
December 26, 2012, 14:40 |
Marhamat Zeinali
Rep Power: 17 |
Hi Bruno
Perfect reply.Tanks a lot for devoting time to my problem. Regards & merry Christmas, Marhamat |
Compile calcMassFlowC | aurore | OpenFOAM Programming & Development | 13 | March 23, 2018 08:43 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 20:08 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 21:50 |
Compiling problems with hello worldC | fw407 | OpenFOAM Installation | 21 | January 6, 2008 18:38 |
[Gmsh] Gmsh and samplesurface | touf | OpenFOAM Meshing & Mesh Conversion | 2 | December 10, 2007 03:27 |
