October 25, 2012, 06:15 |
What means "bounding epsilon"?
Mattia
Rep Power: 14 |
Hello, I have an easy question. I don't understand what means "bounding epsilon" or k, during running of simpleFoam. Is there someone that can tell me what it means?
Thanks a lot. Best Regards. Mattia |
October 25, 2012, 10:51 |
Simone
Rep Power: 14 |
Hi Mattia,
I have experienced the same problems. What I can suggest you is to evaluate carefully the initial/boundary values for your turbulent variables, and maybe you could have a look to your fvSchemes and fvSolution files. More precisely: - in fvSchemes you could use upwind scheme for the terms involving your turbulent variables; - in fvSolution have a look to the tolerances you use for your turbulent variables and to the relaxation factors (maybe you could be a little more conservative and use a lower value of relaxation factor) With these modifications my simulation has not diverged any more. Best regards Simone |
October 26, 2012, 09:10 |
Bounding Turbulence variables
Goncalo Pedro
Rep Power: 17 |
Hi Mattia
The solver is reporting high or low values of a turbulence variable. It is typically indicative of some instability within the solution. As the post above mentions there are a couple of ways to deal with it. In my experience it often comes down to mesh quality. Maybe lack of refinement in certain areas with high gradients etc. Sometimes these bounded values go away as the solution converges. Goncalo |
October 29, 2012, 09:59 |
Mattia
Rep Power: 14 |
Thanks batta31 and gonpe for the replies.
Best regards. |
error means? | hanid | Main CFD Forum | 0 | September 8, 2008 14:25 |
BC evaluation by means of external lists allocated in the solver | shrina | OpenFOAM Running, Solving & CFD | 2 | January 18, 2007 12:29 |
What does the floating point error means? | jon william | FLUENT | 1 | October 8, 2006 09:57 |
plot order points... what does it means ? | Cyril | FLUENT | 0 | June 7, 2006 06:56 |
What means % in Fortran? | What means % in Fortran | Main CFD Forum | 2 | April 20, 2004 15:34 |
