Problem with SimpleFoam for a solution around an OneraM6 wing |
Mattia
Rep Power: 14 ![]() |
Hello, I'm trying to find the solution, with simpleFoam, around a wing.
I did the mesh with GMSH, I checked it and it's ok! When I run simpleFoam, after some time I have this error: --------------------------------------------------------------------------------------------------------------------------- HTML Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.7.x | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 1.7.x-131caa989cd3 Exec : simpleFoam Date : Oct 23 2012 Time : 14:48:03 Host : mattia-Satellite-A100 PID : 4265 Case : /media/HDE_Mattia/TESI/OpenFoam_SIM/My_OneraM6 nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting RAS turbulence model kEpsilon kEpsilonCoeffs { Cmu 0.09; C1 1.44; C2 1.92; sigmaEps 1.3; } Starting time loop Time = 1 smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 0.0156354, No Iterations 4 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 0.0147744, No Iterations 4 smoothSolver: Solving for Uz, Initial residual = 1, Final residual = 0.0141945, No Iterations 4 GAMG: Solving for p, Initial residual = 1, Final residual = 0.0765887, No Iterations 5 time step continuity errors : sum local = 0.00785526, global = -6.37702e-05, cumulative = -6.37702e-05 DILUPBiCG: Solving for epsilon, Initial residual = 0.0122775, Final residual = 0.000168175, No Iterations 2 bounding epsilon, min: -5574.49 max: 71373.4 average: 145.518 DILUPBiCG: Solving for k, Initial residual = 1, Final residual = 0.023163, No Iterations 2 bounding k, min: -147.366 max: 951.351 average: 5.56723 ExecutionTime = 50.28 s ClockTime = 51 s Time = 2 smoothSolver: Solving for Ux, Initial residual = 0.26106, Final residual = 0.00377569, No Iterations 4 smoothSolver: Solving for Uy, Initial residual = 0.0441241, Final residual = 0.000763274, No Iterations 4 smoothSolver: Solving for Uz, Initial residual = 0.390185, Final residual = 0.0058094, No Iterations 4 GAMG: Solving for p, Initial residual = 0.147535, Final residual = 0.0107923, No Iterations 1 time step continuity errors : sum local = 0.053149, global = 0.000500766, cumulative = 0.000436996 DILUPBiCG: Solving for epsilon, Initial residual = 0.0402059, Final residual = 0.00171671, No Iterations 1 bounding epsilon, min: -121237 max: 5.27191e+06 average: 3535.89 DILUPBiCG: Solving for k, Initial residual = 0.0747554, Final residual = 0.00241621, No Iterations 2 bounding k, min: -146.836 max: 5643.87 average: 31.7521 ExecutionTime = 78.74 s ClockTime = 79 s Time = 3 smoothSolver: Solving for Ux, Initial residual = 0.247456, Final residual = 0.0206429, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.0387877, Final residual = 0.0032168, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 0.343374, Final residual = 0.024948, No Iterations 2 GAMG: Solving for p, Initial residual = 0.166044, Final residual = 0.0114922, No Iterations 2 time step continuity errors : sum local = 0.0447917, global = 0.000423066, cumulative = 0.000860062 DILUPBiCG: Solving for epsilon, Initial residual = 0.0555406, Final residual = 0.00191473, No Iterations 1 bounding epsilon, min: -5.39163e+06 max: 5.54757e+08 average: 71838.7 DILUPBiCG: Solving for k, Initial residual = 0.0707114, Final residual = 0.00186781, No Iterations 2 bounding k, min: -3189.27 max: 154294 average: 95.4119 ExecutionTime = 106.9 s ClockTime = 107 s Time = 4 smoothSolver: Solving for Ux, Initial residual = 0.192757, Final residual = 0.00805001, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.0908262, Final residual = 0.00341814, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 0.291972, Final residual = 0.011914, No Iterations 2 GAMG: Solving for p, Initial residual = 0.463544, Final residual = 0.0389622, No Iterations 2 time step continuity errors : sum local = 0.0852108, global = 0.00132486, cumulative = 0.00218492 DILUPBiCG: Solving for epsilon, Initial residual = 0.0594854, Final residual = 0.000642822, No Iterations 1 bounding epsilon, min: -8.30055e+09 max: 3.0866e+11 average: 4.61978e+06 DILUPBiCG: Solving for k, Initial residual = 0.338118, Final residual = 0.00675346, No Iterations 1 bounding k, min: -6.38181e+06 max: 5.92471e+07 average: 1001.34 ExecutionTime = 133.67 s ClockTime = 134 s Time = 5 smoothSolver: Solving for Ux, Initial residual = 0.797821, Final residual = 0.0211082, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.739135, Final residual = 0.0658153, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 0.54783, Final residual = 0.0312859, No Iterations 2 GAMG: Solving for p, Initial residual = 0.424735, Final residual = 0.0249722, No Iterations 2 time step continuity errors : sum local = 7.96186e+10, global = -2.33191e+07, cumulative = -2.33191e+07 DILUPBiCG: Solving for epsilon, Initial residual = 0.999997, Final residual = 0.0964261, No Iterations 1 bounding epsilon, min: -2.27741e+23 max: 8.88371e+24 average: 4.00346e+19 DILUPBiCG: Solving for k, Initial residual = 0.999975, Final residual = 0.0152503, No Iterations 1 bounding k, min: -5.98034e+19 max: 4.30253e+20 average: 6.4329e+15 ExecutionTime = 160.39 s ClockTime = 161 s Time = 6 smoothSolver: Solving for Ux, Initial residual = 0.503326, Final residual = 0.0145054, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.516262, Final residual = 0.0087694, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 0.663085, Final residual = 0.0268232, No Iterations 2 GAMG: Solving for p, Initial residual = 0.992137, Final residual = 9.14002e-05, No Iterations 1 time step continuity errors : sum local = 1.55743e+12, global = 4.00732e+10, cumulative = 4.00499e+10 DILUPBiCG: Solving for epsilon, Initial residual = 9.499e-09, Final residual = 9.499e-09, No Iterations 0 bounding epsilon, min: 5.95232e-21 max: 2.63588e+31 average: 1.74496e+26 DILUPBiCG: Solving for k, Initial residual = 1, Final residual = 5.60578e-08, No Iterations 1 bounding k, min: -9.87096e+31 max: 4.69593e+33 average: 1.50957e+29 ExecutionTime = 184.34 s ClockTime = 185 s Time = 7 smoothSolver: Solving for Ux, Initial residual = 0.176609, Final residual = 0.00788783, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.00488076, Final residual = 6.44686e-05, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 0.062501, Final residual = 0.00183637, No Iterations 2 GAMG: Solving for p, Initial residual = 2.91086e-11, Final residual = 2.91086e-11, No Iterations 0 time step continuity errors : sum local = 7.19548e+23, global = -3.95748e+09, cumulative = 3.60925e+10 DILUPBiCG: Solving for epsilon, Initial residual = 6.70065e-12, Final residual = 6.70065e-12, No Iterations 0 bounding epsilon, min: 6.75762e-21 max: 1.83829e+46 average: 6.2131e+40 DILUPBiCG: Solving for k, Initial residual = 0.137207, Final residual = 0.000197093, No Iterations 2 bounding k, min: -1.8125e+40 max: 1.33333e+43 average: 5.85742e+37 ExecutionTime = 208.37 s ClockTime = 209 s Time = 8 smoothSolver: Solving for Ux, Initial residual = 2.84546e-11, Final residual = 2.84546e-11, No Iterations 0 smoothSolver: Solving for Uy, Initial residual = 3.46671e-09, Final residual = 3.46671e-09, No Iterations 0 smoothSolver: Solving for Uz, Initial residual = 4.31442e-11, Final residual = 4.31442e-11, No Iterations 0 #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Uninterpreted: #3 Foam::GAMGSolver::scalingFactor(Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double> const&, Foam::Field<double> const&) const in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so" #4 Foam::GAMGSolver::scalingFactor(Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double>&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so" #5 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so" #6 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so" #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam171/lib/linuxGccDPOpt/libfiniteVolume.so" #8 in "/opt/openfoam171/applications/bin/linuxGccDPOpt/simpleFoam" #9 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6" #10 in "/opt/openfoam171/applications/bin/linuxGccDPOpt/simpleFoam" Floating point exception (core dumped) Is it an error from the numerical scheme? I see that there are a large value for bounding epsilon and k. Is here the problem? The fvScheme file is: HTML Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.7.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; grad(p) Gauss linear; grad(U) Gauss linear; } divSchemes { default none; div(phi,U) Gauss limitedLinear 1; div(phi,k) Gauss limitedLinear 1; div(phi,epsilon) Gauss limitedLinear 1; div(phi,R) Gauss limitedLinear 1; div(R) Gauss linear; div(phi,nuTilda) Gauss limitedLinear 1; div((nuEff*dev(grad(U).T()))) Gauss linear; } laplacianSchemes { default none; laplacian(nuEff,U) Gauss linear corrected; laplacian((1|A(U)),p) Gauss linear corrected; laplacian(DkEff,k) Gauss linear corrected; laplacian(DepsilonEff,epsilon) Gauss linear corrected; laplacian(DREff,R) Gauss linear corrected; laplacian(DnuTildaEff,nuTilda) Gauss linear corrected; } interpolationSchemes { default linear; interpolate(U) linear; } snGradSchemes { default corrected; } fluxRequired { default no; p ; } Thanks for the replies. Best regards. Mattia |
Mattia
When I turn off turbulence in RAS Properties, It goes ok and the time step continuity errors has no large value. The solution, seen by Paraview, seems ok. How can I correct the problem with epsilon and K.
Thanks. Best regards. |
Zifei Yin
would you please send your Mesh file and your case file to yzf1215@gmail.com? I'm having a similar problem like you.
Mattia
Hello, I solved the problem. It was in the turbulence model. I imposed Spalart-Allmras or Realizable K-epsilon and the solution now doesn't diverge!
simpleFoam: problem with the U file | samiam1000 | OpenFOAM Running, Solving & CFD | 5 | November 10, 2015 16:47 |
3-D wing analysis problem | arjit | FLUENT | 14 | June 17, 2013 15:39 |
Problem running simpleFoam on a multi element airfoil | vinz | OpenFOAM Running, Solving & CFD | 18 | April 11, 2013 12:26 |
3D wing (flapping elastically) flexing UDF problem | djan | Fluent UDF and Scheme Programming | 3 | March 30, 2012 12:37 |
Solution convergence problem - poor mesh? | Shawn_A | OpenFOAM Running, Solving & CFD | 2 | November 12, 2011 20:31 |
