OpenFOAM-2.1.0 Writes Data in Old Format and Reads in New Format |
Nishit Joseph
Rep Power: 15 ![]() |
Hi OF Users!
I am having a seprate difficulity regarding OF-2.1 with the 'parallel' patches influencing the the solution here. In trying to diagnose that issue I have hit a seprate one. Here is what I am trying to do. Run the solver as a single process for a few time steps. Use the intermediat solution to deocmpose the case. Then run the case from the last computed time step. I can
I cannot
Here is my output when I try to run the solver again as a single processor Code:
$ rhoCentralFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.1.0-bd7367f93311 Exec : rhoCentralFoam Date : Oct 04 2012 Time : 14:26:10 Host : "jlightDell" PID : 10761 Case : /home/jlight/CFD/DSTO/MainWork/Wire_OF_New nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 1.000000e-08 Reading thermophysical properties Selecting thermodynamics package ePsiThermo<pureMixture<sutherlandTransport<specieThermo<hConstThermo<perfectGas>>>>> Reading field U --> FOAM Warning : From function Field<Type>::Field(const word& keyword, const dictionary&, const label) in file /home/jlight/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/Field.C at line 262 Reading "/home/jlight/CFD/DSTO/MainWork/Wire_OF_New/1.000000e-08/U::boundaryField::wire" from line 166680 to line 167095 expected keyword 'uniform' or 'nonuniform', assuming deprecated Field format from Foam version 2.0. --> FOAM FATAL IO ERROR: Expected a '(' while reading VectorSpace<Form, Cmpt, nCmpt>, found on line 166686 the label 200 file: /home/jlight/CFD/DSTO/MainWork/Wire_OF_New/1.000000e-08/U::boundaryField::wire::refValue at line 166686. From function Istream::readBegin(const char*) in file db/IOstreams/IOstreams/Istream.C at line 94. FOAM exiting JLight Last edited by JLight; October 4, 2012 at 08:18. |
Nishit Joseph
Just an update on this.
I was looking at the U files and found that the keyword 'nonuniform' was missing for the refValues and valueFraction. However I am not sure which file controls the output for boundary fields like this one (being the maxwellSlipU from rhoCentralFoam's BC). I will like to edit the source and fix this issue. JLight |
Nishit Joseph
The fix is simple and I have reported a bug to OpenFOAM.
Just edit the file $FOAM_APP/solvers/compressible/rhoCentralFoam/BCs/U/maxwellSlipUFvPatchVectorField.C. Code:
--- ../../../rhoCentralFoam/BCs/U/maxwellSlipUFvPatchVectorField.C 2011-11-25 03:59:50.000000000 +1100 +++ maxwellSlipUFvPatchVectorField.C 2012-10-04 22:30:46.318141418 +1000 @@ -194,11 +194,9 @@ os.writeKeyword("thermalCreep") << thermalCreep_ << token::END_STATEMENT << nl; os.writeKeyword("curvature") << curvature_ << token::END_STATEMENT << nl; - - os.writeKeyword("refValue") - << refValue() << token::END_STATEMENT << nl; - os.writeKeyword("valueFraction") - << valueFraction() << token::END_STATEMENT << nl; + + refValue().writeEntry("refValue", os); + valueFraction().writeEntry("valueFraction", os); writeEntry("value", os); } JLight |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
