September 25, 2012, 19:22 |
BC's for k-omega SST (low / hi Re setups)
Rep Power: 17 |
hi everyone,
i have been testing my k-omega SST setup for OF using a simple flat plate geometry, and BC's i have worked out from looking at a number of other posts on the issue. although there is a *lot* out there on the setups you need to use, i dont seem to get the impression that there has been widespread agreement on how the model is supposed to be implemented anyway, so i have a low Re and a hi Re mesh. the BC's for the two meshes are: For the hi Re mesh: Code:
'k' WALL { type kqRWallFunction; value uniform 1; } 'omega' WALL { type omegaWallFunction; value uniform 1; } 'nut' WALL { type nutkWallFunction; value uniform 0; } Code:
'k' WALL { type fixedValue; value uniform 1e-12; } 'omega' WALL { type omegaWallFunction; value uniform 1e9; } 'nut' WALL { type nutUSpaldingWallFunction; value uniform 0; } Using yPlusRAS to check the meshes, i see that the first node points for each mesh are in the correct region, so i cant quite work out what the problem is. BC's perhaps?? anyway, i would appreciate any feedback on anything obvious i have gotten wrong + am quite keen to 'finalise' the 'proper' approach for the current implementation of k-omega SST (OF v2.1.1) thanks a lot in advance! Jonathan |
September 26, 2012, 09:33 |
Rep Power: 17 |
never mind ... solved it ...
September 28, 2012, 17:37 |
Rick Tejeda
Rep Power: 14 |
Hi Jonathan,
How did you resolve this? |
October 4, 2012, 07:39 |
stephane sanchi
Rep Power: 18 |
Hi Jonathan,
what formula do you use to set 'value uniform 1e9' for k at the wall for your low Reynolds mesh (y+~1) ? Best regards, Stephane. |
October 4, 2012, 08:06 |
Rep Power: 17 |
Hi Stephane,
I didnt use a formula - looking through the forums and theory, i realise that omega tends to infinity at the wall - therefore, i just used a large number as the omega BC ... regards jonathan |
February 2, 2014, 19:15 |
Ye Zhang
Rep Power: 17 |
Hi Jonathan
I also did this validation with komega SST turbulence model. But with Low Re and high Re model both failed. There is mismatch in the log-law region. Can you please give a hint how you solve it? Best regards, Ye |
February 3, 2014, 04:07 |
#7 | |
Rep Power: 17 |
hi Kid,
I havent looked at OF for a little while, but in the last version i was using (2.1.1), i finally used the following for a low Re mesh: 'k' -> set to SMALL no at wall 'omega' -> use omegaBC built into OF. This calculates omega at the wall using the correct formula from Menter 'nut' -> I used 'calculated' condition and not nut wall function as in my first post PS I didnt do anymore with the hi-Re meshes, as my project needed low-Re only. hope this helps a little. cheers jonathan PPS I dont know what the latest versions of OF are using for turbulence wall BC's these days. Might pay to download the latest UG and look through the release notes and code to see what is actually going on ... cheers jon Quote:
February 10, 2014, 16:36 |
Ye Zhang
Rep Power: 17 |
Hi Jonathan,
Thanks a lot for your reply. I finally got the correct result after several trying. Best regards, Ye |
Low Reynolds Number SST Model | Josh | CFX | 41 | June 4, 2023 20:00 |
overshooting of Omega in SST komega using simpleFoam | cm_jubayer | OpenFOAM | 2 | June 7, 2020 13:52 |
Boundary Conditions for k omega SST | dancfd | OpenFOAM Pre-Processing | 0 | June 10, 2011 00:25 |
Very Low Re: SST vs. v2-f? | CAVT | Main CFD Forum | 0 | September 25, 2010 05:34 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 06:12 |
