polyDualMesh results in non-planar faces and non-convex cells
Like Tree1Likes
  • 1 Post By deepsterblue
Old   September 13, 2012, 09:47
Default polyDualMesh results in non-planar faces and non-convex cells
Tomislav Maric
tomislav_maric is on a distinguished road
Hi everyone,
I have an extremely simple domain: a box of dimensions [0,1]^3 which is meshed with tetrahedrons using the Netgen algorithm of Salome (version 6.4.0, 64 bit). When I use the polyDualMesh to generate a polyhedral mesh of the boxed domain, I get cells which are non-convex and have non-planar faces. Here is a picture of such a cell.
I've tried multiple feature angles, although the 90 degrees seems most sensible for a simple box domain. Any advice on this?
Here's the case with the .unv of the tetrahedral mesh.
Note: creating a more regular tetrahedral mesh using a decomposition of hex cells results in a combination of hex-poly cells, where the polyhedra are convex with planar faces, but the cell aspect ratio is kind of high (around 2).
Is there a way to get a good polyhedral mesh using purely tet mesh generation algorithms such as Netgen?
tomislav_maric is offline   Reply With Quote
Old   September 13, 2012, 11:18
Sandeep Menon
deepsterblue will become famous soon enough
Have you checked to ensure that your underlying tet-mesh is Delaunay? If not, you'll have to ensure that first.
Of course, you could easily pre-process the underlying tet-mesh (with smooth/remesh) before you convert it to polyhedra..
tomislav_maric likes this.
Sandeep Menon
University of Massachusetts Amherst
https://github.com/smenon
deepsterblue is offline   Reply With Quote
Old   September 13, 2012, 11:24
Tomislav Maric
Thanks! Nope, didn't check this.... I'm working with Salome, so I'm not sure how it goes about generating tet meshes..
As for smoothing-remeshing: how can I be sure that the dual will result in convex cells? I mean, what parameters/workflow do I use for smooth/remesh in this case?
Old   September 13, 2012, 11:29
Sandeep Menon
I typically use the mesquiteMotionSolver in combination with moveDynamicMesh for a few time-steps. If you want to remesh as well, you can use dynamicTopoFvMesh (which can include a smoother as well).
Sorry for blatantly advertising my stuff, but couldn't help it...
Sandeep Menon
Old   September 13, 2012, 11:32
Tomislav Maric
Hehehehe marketing is always good.. and your stuff is worth advertising, so no worries there! Thanks for the info, I will try it!
