Continuity Error: Mass Inflow/Outflow
Like Tree1Likes
  • 1 Post By Tiffany
Old   August 15, 2012, 19:24
Default Continuity Error: Mass Inflow/Outflow
Anonymous
Tiffany is on a distinguished road
Hi, I'm new to OpenFOAM. I'm trying to model the flow of a mixture of liquids in a cylindrical shape with interFoam. When I try running the solver, I get the error below. I set up the shape to be enclosed by walls on all sides (where one of the walls rotates). I don't have an inflow or outflow that I'm aware of. I don't understand why I'm getting this error. Any ideas?
Create time
Create mesh for time = 0
PIMPLE: Operating solver in PISO mode
Reading field p_rgh
Reading field alpha1
Reading field U
Reading transportProperties
Selecting incompressible transport model Newtonian
Selecting turbulence model type LESModel
Selecting LES turbulence model Smagorinsky
SmagorinskyCoeffs
ce 1.05;
ck 0.07;
Reading g
Calculating field g.h
time step continuity errors : sum local = 4.35666e-18, global = 2.09e-19, cumulative = 2.09e-19
--> FOAM FATAL ERROR:
Continuity error cannot be removed by adjusting the outflow.
Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow.
Total flux : 1e-300
Specified mass inflow : 2.89178e-15
Specified mass outflow : 3.18322e-15
Adjustable mass outflow : 0
From function adjustPhi(surfaceScalarField& phi, const volVectorField& U,const volScalarField& p
in file cfdTools/general/adjustPhi/adjustPhi.C at line 118.
FOAM exiting
dachs likes this.
Tiffany is offline   Reply With Quote
Old   July 31, 2024, 04:57
dachs is on a distinguished road
I have a very similar problem, has anyone found a solution?
dachs is offline   Reply With Quote
Old   July 31, 2024, 07:30
Tobermory will become famous soon enough
The solution is to check your boundary conditions. The code is telling you that it cannot enforce continuity on the domain because you have over-constrained the solver with your boundaries.
If you are still struggling with this, post your velocity and pressure boundary files and a description of the domain/flow scenario.
Tobermory is offline   Reply With Quote
Old   July 31, 2024, 08:05
Hi thanks for your quick reply and the help you offered.
I want to carry out a two-phase simulation (oil/air) for the fluid space within a rolling bearing. So I have a closed system, which makes me wonder even more about the error message.
At the beginning I did a very simple 2 phase simulation of a closed ring, which runs without errors. Now the idea is to cut the geometry of the rolling elements (saved as CAD) out of the mesh with the SnappyHexMesh (I have tested on a single phase simulation and it works here). I have defined new boundary conditions for the newly created surfaces and run the simulation as follows:
blockMesh
surfaceFeautures
snappyHexMesh -overwrite
setFields
interFoam
Then I get the error message:
Specified mass inflow : 1.79258e-18
Specified mass outflow : 1.85626e-18
|  \\    /   O peration     | Version:  v11                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    frontWall
        type            fixedValue;
        value         uniform (0 0 0);
    backWall
        type            fixedValue;
    innerWall
        type            fixedValue;
    outerWall
        type            fixedValue;
    innerGap
        type            fixedValue;
    outerGap
        type            fixedValue;
    middleGap
        type            fixedValue;
   innerRing
        type            rotatingWallVelocity;
        origin          (0 0 0);
        axis             (0 0 1);
    omega         constant 18.274; //relative Rotation Velocity in rad/s for 300rpm
    outerRing
        origin          (0 0 0);
        axis             (0 0 1);
    omega         constant -13.325; //relative Rotation Velocity in rad/s for 300rpm
    roller01
        origin        (0.0 0.083 0);
        axis         (0 0 1);
    omega         constant -98.402; //relative Rotation Velocity in rad/s for 0 Slip
    roller02
        origin      (0.026 0.079 0);
        axis         (0 0 1);
    roller03
        origin      (0.049 0.067 0);
        axis         (0 0 1);
    roller04
        origin      (0.067 0.049 0);
        axis         (0 0 1);
    roller05
        origin      (0.079 0.026 0);
        axis         (0 0 1);
    roller06
        origin      (0.083 0.0 0);
        axis         (0 0 1);
    roller07
        origin      (0.079 -0.026 0);
        axis         (0 0 1);
    roller08
        origin      (0.067 -0.049 0);
        axis         (0 0 1);
    roller09
        origin      (0.049 -0.067 0);
        axis         (0 0 1);
    roller10
        origin      (0.026 -0.079 0);
        axis         (0 0 1);
    roller11
        origin      (0.0 -0.083 0);
        axis         (0 0 1);
    roller12
        origin      (-0.026 -0.079 0);
        axis         (0 0 1);
    roller13
        origin      (-0.049 -0.067 0);
        axis         (0 0 1);
    roller14
        origin      (-0.067 -0.049 0);
        axis         (0 0 1);
    roller15
        origin      (-0.079 -0.026 0);
        axis         (0 0 1);
    roller16
        origin      (-0.083 0.0 0);
        axis         (0 0 1);
    roller17
        origin      (-0.079 0.026 0);
        axis         (0 0 1);
    roller18
        origin      (-0.067 0.049 0);
        axis         (0 0 1);
    roller19
        origin      (-0.049 0.067 0);
        axis         (0 0 1);
    roller20
        origin      (-0.026 0.079 0);
        axis         (0 0 1);
|  \\    /   O peration     | Version:  v2312                                 |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p_rgh;
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    frontWall
        type            zeroGradient;
    backWall
        type             zeroGradient;
    innerWall
        type              zeroGradient;
    outerWall
        type               zeroGradient;
        innerRing
        type            fixedFluxPressure;
        value           uniform 0;
    outerRing
        value           uniform 0;
    innerGap
        value           uniform 0;
    outerGap
        value           uniform 0;
    middleGap
        value           uniform 0;
    roller01
        value           uniform 0;
    roller02
        value           uniform 0;
    roller03
        value           uniform 0;
    roller04
        value           uniform 0;
    roller05
        value           uniform 0;
    roller06
        value           uniform 0;
    roller07
        value           uniform 0;
    roller08
        value           uniform 0;
    roller09
        value           uniform 0;
    roller10
        value           uniform 0;
    roller11
        value           uniform 0;
    roller12
        value           uniform 0;
    roller13
        value           uniform 0;
    roller14
        value           uniform 0;
    roller15
        value           uniform 0;
    roller16
        value           uniform 0;
    roller17
        value           uniform 0;
    roller18
        value           uniform 0;
    roller19
        value           uniform 0;
    roller20
        value           uniform 0;
Old   August 2, 2024, 13:35
I can see why you are puzzled now. It is odd. The only thing that comes to mind is that your use of a fixedValue boundary for the stationary walls, eg
    frontWall
        type            fixedValue;
is a little odd (I would have expected noSlip). What type are these defined as in constant/polyMesh/boundary? Patch or wall? If it is a patch, then I can see it trying to treat it as an inlet, which might be causing the continuity issue.
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
