adjointShapeOptimizationFoam for In-compressible NS
Like Tree1Likes
  • 1 Post By kjw
Old   July 9, 2012, 05:05
Default adjointShapeOptimizationFoam for In-compressible NS
sam
smanekshaw is on a distinguished road
Hi
I would like more details about this solver.
Could i use it to optimize wing/body shape for INS equations?
Does it use a continous or discrete adjoint solver?
Where could i get details/papers about the solver
Thanks
Sam
smanekshaw is offline   Reply With Quote
Old   July 9, 2012, 05:56
Roland
sylvester is on a distinguished road
Hi Sam,
AdjointShapeOptimizationFoam is a continous adjoint topology optimizer using the incompressible Navier-Stokes equations. It probably can be used for wing/body shape optimization, but in its present form it is more suitable for internal flows.
The code of adjointShapeOptimizationFoam lists this paper as source:
http://pdf.aiaa.org/preview/CDReadyM...V2007_3947.pdf
Best regards,
Sylvester
sylvester is offline   Reply With Quote
Old   November 12, 2012, 16:32
Default example
kjw
Krzysztof Wołosz
kjw is on a distinguished road
Welcome to all Foamers,
I am trying to proceed the example presented in the paper quoted below.
Originally Posted by sylvester View Post
Hi Sam,
While the case is calculated with simpleFoam, the flow seem to be Ok, the same example computed with adjointShapeOptimizationFoam react a little bit odd.
Below the results of adjoint... and simple.. are presented, respectively.
The code attached comes from adjointShapeOptimizationFoam.
Best Regards
Christopher
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      RASProperties;
RASModel        laminar;//kEpsilon;
turbulence      off;//on;
printCoeffs     off;//on;
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      transportProperties;
transportModel  Newtonian;
nu              nu [0 2 -1 0 0 0 0] 2e-4;//1e-5;
lambda          lambda   [0 -2 1 0 0 0 0] 1e5;
alphaMax        alphaMax [0 0 -1 0 0 0 0] 200.0;
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    "(p|pa)"
        solver          GAMG;
        tolerance       1e-08;
        relTol          0.001;
        smoother        GaussSeidel;
        nPreSweeps      0;
        nPostSweeps     2;
        cacheAgglomeration true;
        nCellsInCoarsestLevel 10;
        agglomerator    faceAreaPair;
        mergeLevels     1;
    "(U|Ua|k|epsilon)"
        solver          GAMG;
        nSweeps         2;
        tolerance       1e-08;
        relTol          0.01;
	nPreSweeps      0;
        nPostSweeps     2;
        mergeLevels     1;
SIMPLE
    nNonOrthogonalCorrectors 0;
    pRefCell 0;
    pRefValue 0;
relaxationFactors
    fields
        "(p|pa)"        0.2;
        "(alpha)"           0.1;
    equations
        "(U|Ua)"        0.2;
        "(k|epsilon)"   0.7;
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         steadyState;
gradSchemes
    default         Gauss linear;
    grad(p)         Gauss linear;
    grad(U)         Gauss linear;
divSchemes
    default         none;
    div(phi,U)      Gauss upwind;
    div(phi,k)      Gauss upwind;
    div(phi,epsilon) Gauss upwind;
    div((nuEff*dev(T(grad(U))))) Gauss linear;
    div(-phi,Ua)    Gauss upwind;
    div((nuEff*dev(T(grad(Ua))))) Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
    laplacian(nuEff,U) Gauss linear corrected;
    laplacian(1,p) Gauss linear corrected;
    laplacian(1|A(U),p) Gauss linear corrected;
    laplacian(DkEff,k) Gauss linear corrected;
    laplacian(DepsilonEff,epsilon) Gauss linear corrected;
    laplacian(nuEff,Ua) Gauss linear corrected;
    laplacian(1|A(Ua),pa) Gauss linear corrected;
interpolationSchemes
    default         linear;
    interpolate(U)  linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    p;
    pa;
    object      Ua;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    inlet
        type            fixedValue;
        value           uniform (0 1 0);
	walls
        type            fixedValue;
        value           uniform (0 0 0);
    outlet
        type            adjointOutletVelocity;
        value           uniform (1 0 0);
    frontAndBack
        type            empty;
    object      U;
boundaryField
    inlet
        type            fixedValue;
    outlet
        type            fixedValue;
    walls
        type            fixedValue;
    frontAndBack
        type            empty;
    object      pa;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    inlet
        type            zeroGradient;
	walls
        type            zeroGradient;
    outlet
        type            adjointOutletPressure;
        value           uniform 0;
    frontAndBack
        type            empty;
    object      p;
boundaryField
    inlet
        type            zeroGradient;
    walls
        type            zeroGradient;
    outlet
        type            fixedValue;
        value           uniform 0;
    frontAndBack
        type            empty;
unnikrsn likes this.
kjw is offline   Reply With Quote
Old   December 4, 2012, 07:04
Samuele Z
samiam1000 is on a distinguished road
Hi all,
pardon the interruption, just a question for you: where can I find the case posted in the last post? Is it in the tutorials?
Thanks a lot,
Samuele
samiam1000 is offline   Reply With Quote
Old   December 4, 2012, 17:47
kjw
Krzysztof Wołosz
This case is in the paper that has been linked. It has been described and recreated.
It is not in the tutorial.
Regards
Krzysztof
Originally Posted by samiam1000 View Post
Hi all,
Thanks a lot,
Samuele
Old   December 4, 2012, 18:18
Samuele Z
Is it possible to have the case folder?
Old   January 7, 2013, 16:42
immortality's Avatar
Ehsan
immortality is on a distinguished road
what's the link of full article paper?
immortality is offline   Reply With Quote
Old   January 7, 2013, 16:52
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
AIAA papers typically costs money - and I guess it also does in this case.
Kind regards,
Niels
ngj is offline   Reply With Quote
Old   February 12, 2020, 14:10
Cambridge is on a distinguished road
Hi all,
Thanks a lot,
Samuele
Hi
Hope you are still on this project. I am new in topology optimisation using OpenFOAM, the link of this paper is not available any more. Can you please send me that? Is that possible to have your library of this problem? Thank you so much.
regards
Cambridge is offline   Reply With Quote
Old   February 12, 2020, 15:54
hxaxtma is on a distinguished road
Have a look at daFoam
https://dafoam.readthedocs.io/en/lat...pressible.html
hxaxtma is offline   Reply With Quote
Old   February 13, 2020, 06:30
Originally Posted by hxaxtma View Post
Hi hxaxtma,
Thank you so much for your helpful information. Do you specialise in this?
regards
FSI-Oscillating Flexible Fin Mid Grove CFX 7 September 25, 2012 00:59
The problem of inner iteration when calling the subroutine guoxj CFX 18 October 23, 2010 21:37
Fin inside supersonic flow Liol Calvert FLUENT 8 March 22, 2010 10:31
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin Kaushik FLUENT 1 May 8, 2000 07:47
Compressible vs. Incompressible formulations Fernando Velasco Hurtado Main CFD Forum 3 January 7, 2000 17:51
