adjointShapeOptimizationFoam checkerboarding inlet
Like Tree2Likes
  • 2 Post By sylvester
Old   June 14, 2012, 06:52
Default adjointShapeOptimizationFoam checkerboarding inlet
Roland
sylvester is on a distinguished road
For an optimization study I am working with an Ahmed body using adjointShapeOptimizationFoam.
As you can see from the picture 'ahmed_alpha.jpg' the solver works really well near the body, trying to extend the body with an aerodynamic fairing. However near the inlet I am experiencing a strange checkerboarding problem in my adjoint equations, see pictures 'ahmed_pa.jpg' and 'ahmend_Ua.jpg'. All pictures are taken after (only) 100 iterations.After a further several hundred iterations the adjoint flow field fully diverges. The primal flow field is smooth, as expected, see pictures 'ahmed_p.jpg' and 'ahmed_U.jpg'.
The adjoint boundary conditions are taken from the adjointShapeOptimizationFoam tutorial (see below), as are the values for lambda and alphaMax. The fvSolution and fvSchemes settings (see below) are based on the tutorials with lower adjoint relaxations and uncorrected in stead of corrected schemes. Lower values of relTol and relaxation where also tested, but without improvements. CheckMesh reports 'Mesh OK', with no warnings.
Does anyone have suggestions on how best to solve this?
Thanks!
regards,
Sylvester
solvers
    "(p|pa)"
        solver          GAMG;
        tolerance       1e-08;
        relTol          0.01;
        smoother        GaussSeidel;
        nPreSweeps      0;
        nPostSweeps     2;
        cacheAgglomeration true;
        nCellsInCoarsestLevel 10;
        agglomerator    faceAreaPair;
        mergeLevels     1;
    "(U|Ua|k|omega)"
        solver          smoothSolver;
        nSweeps         2;
        tolerance       1e-08;
        relTol          0.1;
SIMPLE
    nNonOrthogonalCorrectors 0;
relaxationFactors
    fields
        p               0.3;
        pa              0.1;
        alpha           0.1;
    equations
        U               0.7;
        Ua              0.1;
        "(k|omega)"     0.7;
ddtSchemes
    default         steadyState;
gradSchemes
    default         Gauss linear;
divSchemes
    default         Gauss upwind;
    div((nuEff*dev(T(grad(U))))) Gauss linear;
    div((nuEff*dev(T(grad(Ua))))) Gauss linear;
laplacianSchemes
    default         Gauss linear uncorrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         uncorrected;
fluxRequired
    default         no;
    p;
    pa;
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p;
dimensions      [ 0 2 -2 0 0 0 0 ];
internalField   uniform 0;
boundaryField
        type            zeroGradient;
    outlet
        type            adjointOutletPressure;
        value           uniform 0;
    symmetry
        type            symmetryPlane;
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      Ua;
dimensions      [ 0 1 -1 0 0 0 0 ];
internalField   uniform ( -1 0 0 );
boundaryField
        type            fixedValue;
        value           uniform ( 0 0 0 );
    inlet
        type            fixedValue;
        value           uniform ( -1 0 0 );
    outlet
        type            adjointOutletVelocity;
    farfield
        type            slip;
    symmetry
        type            symmetryPlane;
sylvester is offline   Reply With Quote
Old   June 19, 2012, 05:46
Default pseudo staggered approach for the adjoint equations
Roland
Hi!
Using a pseudo staggered approach for the adjoint equations helps, see the images below.
I've modified adjointShapeOptimizationFoam a bit so it uses the pseudo staggered grid approach also used in, for example, buoyantBoussinesqSimpleFoam.
As you can see in the images, this approach removes the checkerboarding near the floor, but it does not completely remove it over the full surface of the inlet. The adjoint equations only diverge at the inlet, the rest of the domain are OK. The second image also shows that the calculation of 'alpha' is unaffected by the pseudo staggering.
Any directions on how to proceed would be much appreciated!
Regards,
Sylvester
kiddmax and fumiya like this.
Old   January 7, 2013, 16:51
immortality's Avatar
Ehsan
immortality is on a distinguished road
hi.how did you solved the problem?can this solver be used for compressible flows?could you introduce me some useful papers or texts about using the method?i want to know how points are changed according to this solver.can it be used with optimization algorithms like ant colony or other ones?thank you.
immortality is offline   Reply With Quote
Old   January 8, 2013, 05:38
Roland
I haven't been able to work on this, so not much progress has been made. The adjoint solver in OpenFOAM is for incompressible flows only. For compressible flows the adjoint equations also exist, so you should be able to make a compressible version. A Google search will probably provide you with references on this.
regards,
Sylvester
Old   January 8, 2013, 06:44
Ehsan
thanks.if send me a suitable to start pdf ill be very thankful to you!
Force.of.love@gmail.com
Old   May 28, 2018, 11:36
C. Okubo is on a distinguished road
Hi!
I know its been a while since this post started. Any news? I am facing the same problem. Even though I was able to have some better results by using a limited grad(Ua) and relaxation factors higher for pa than Ua, I would say that something inside the solver needs attention. If you check adjoint velocities at the inlet, they point to an akward direction, this make confuse sensitivities and inlet of the domains happens to have some checkerboard. See this other post:
adjointShapeOptimizationFoam - inlet velocity weird behavior
I still was not able to fix this (if this is something that needs to be fixed).
Regards,
Okubo
C. Okubo is offline   Reply With Quote
adjoint, ahmed, checkerboarding, instability, optimization
VOF Volume fraction in Velocity inlet aruelle FLUENT 2 May 10, 2024 11:17
Oscillating inlet BC November OpenFOAM 4 March 21, 2012 21:46
Velocity inlet boundary condition for porous medium Chander CFX 3 March 11, 2012 22:18
Inlet Velocity in CFX aeroman CFX 12 August 6, 2009 19:42
Diffusion component at inlet Balaji FLUENT 2 August 8, 2005 08:37
