Does PISO algorithm work with interfoam in openFOAM 2.1.0?
Like Tree4Likes
  • 3 Post By akidess
  • 1 Post By Phicau
Old   June 13, 2012, 01:35
Default Does PISO algorithm work with interfoam in openFOAM 2.1.0?
Krishna Sandeep
Krishna Sandeep is on a distinguished road
Hello everyone
I have been using openFOAM to simulate a dam break problem. The issue is that i used PISO algorithm in the "fvSolutions" file and used interFOAM as the solver. When I tried to run the program, an error message crept in as follows:
" keyword PIMPLE undefined in the file ..\fvsolutions"
But when I tried to run the same code in FOAM 1.7.x, I could see the results. What could possibly be the reason?
Please reply.....
Thank u in advance
Krishna Sandeep is offline   Reply With Quote
Old   June 13, 2012, 03:40
akidess's Avatar
Anton Kidess
Solver structure changed from 1.7.x to 2.1.x, and PISO was replaced by PIMPLE. Adapt your case to the new solver - see the interFoam tutorial as a guideline.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   June 13, 2012, 03:50
Pablo Higuera
Phicau is on a distinguished road
Hi Krishna
just change PISO for PIMPLE within fvSolution and everything will run again. Furthermore, PIMPLE is a merging of PISO and SIMPLE algorithms, if you do not specify any overrelaxation factor you will still use PISO: when the simulation starts you can read - PIMPLE: Operating solver in PISO mode
Krishna Sandeep likes this.
Phicau is offline   Reply With Quote
Old   June 14, 2012, 02:32
Krishna Sandeep
Thank u everyone I shall try using PIMPLE....
openfoam 1.7.x, openfoam 2.1.x, piso
Erosion modeling in OpenFOAM 2.1.0 mecbe2002 OpenFOAM 6 November 9, 2017 22:29
OpenFoam 2.0.1 --> 2.1.0 SH_P OpenFOAM Installation 8 January 5, 2012 03:43
OpenFoam 2.1.0 Ubuntu release 19/12/2011 Ancioi OpenFOAM Installation 4 December 24, 2011 09:40
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 07:55
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 19:07
