Water level in a rotating tank problem
Like Tree2Likes
  • 1 Post By lovecraft22
  • 1 Post By iamed18
Old   June 5, 2012, 02:30
Smile Water level in a rotating tank problem
Krishna Sandeep
Krishna Sandeep is on a distinguished road
Hi everyone
I am completely new to openFOAM and am trying to workout the " water level in a rotating tank" problem. I should find out the new surface of water and the pressure distribution inside the water. Please direct me how to solve it...if anyone have already tried it please give me a link to the files so that i can run the case.
Krishna Sandeep is offline   Reply With Quote
Old   June 5, 2012, 04:31
lore
lovecraft22 is on a distinguished road
Send a message via Skype™ to lovecraft22
Is the thank cylindrical and it's just rotating around its center?
lovecraft22 is offline   Reply With Quote
Old   June 5, 2012, 07:33
Krishna Sandeep
yeah the tank is cylindrical and is rotating about its vertical axis.....i want to see the vortex formation i.e., the shape of the free water surface..
Old   June 5, 2012, 07:36
lore
Then you just need to set your cylinder as a rotating wall in your U file;
 "cylinder_.*"
        type rotatingWallVelocity;
        origin (0 0 0);
        axis (0 0 1);
        omega constant 3000;
Krishna Sandeep likes this.
Old   June 6, 2012, 03:16
kid
cfdkid
kid is on a distinguished road
Hi Lore,Hello sandeep
Is the tank going to be open or closed ? ( free surface model or regular internal flow or closed lid with two fluids (air,water))
________________________________________
Regards,
CFDkid
It never gets easier You just get Better
kid is offline   Reply With Quote
Old   June 6, 2012, 03:46
Krishna Sandeep
The tank is closed. assume that the liquid is inviscid and free of surface tension. Water is filled up to half of the tank. What solver should i use? I've been doing the problem similar to that of dam-break case with different initial fields and viscosity and sigma as 0....is this correct?
Old   June 6, 2012, 03:47
Krishna Sandeep
The tank is closed. assume that the liquid is inviscid and free of surface tension. Water is filled up to half of the tank. What solver should i use? I've been doing the problem similar to that of dam-break case with different initial fields and viscosity and sigma as 0....is this correct? I ve given the rotating wall condition and can actully feel the wall rotating....
Old   June 11, 2012, 10:20
Edward Leonard
iamed18 is on a distinguished road
I don't know how valid the inviscid approximation will work for this since the rotating boundary will be your entire driving force for the flow - if there's no viscosity near the boundary layer, then what reason would the fluid have to flow?
iamed18 is offline   Reply With Quote
Old   November 15, 2014, 11:32
Deutschland
Dhruval is on a distinguished road
hi. sandeep,
have you found the solution?
Dhruval is offline   Reply With Quote
Old   April 24, 2016, 14:22
Post variable omega according to algorithm calculated value
Muhammad Usman
13msmemusman is on a distinguished road
what if i want to input omega value from an algorithm??? means i am getting rotation value from an algorthm and i want to use it in solver.
 "cylinder_.*"
        origin (0 0 0);
        axis (0 0 1);
13msmemusman is offline   Reply With Quote
Old   February 15, 2018, 06:30
Default Rotating Wall Velocity and Dirichlet
  #11
Panchatcharam Mariappan
mpanch13114 is on a distinguished road
I am working on a similar problem. Rotating wall velocity = Dirichlet boundary condition ?? or Are they different?
Regards
Panch
mpanch13114 is offline   Reply With Quote
rotatingcylinder, waterlevel
Problem with the 2D rotating blade-CFX-12.1 Araz CFX 5 September 3, 2011 08:54
Rotating problem / transient / 2D Logan86 CFX 6 July 8, 2011 07:57
Simulating air injects to water in a tank Howard Wang FloEFD, FloWorks & FloTHERM 1 March 16, 2009 04:17
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
Tank problem using CFD meda Main CFD Forum 3 July 1, 1999 22:44
