OF2.1: turbulentInlet for LES, description of how the fluctuations are generated
Like Tree7Likes
  • 7 Post By fcollonv
Old   June 4, 2012, 06:44
Default OF2.1: turbulentInlet for LES, description of how the fluctuations are generated
Jan Östh
Jan.Östh is on a distinguished road
Hi
Does anybody know how the turbulent fluctuations are generated when using the turbulentInlet as an inlet condition in a LES simulation in Openfoam v2.1 ? If anybody could point to a scientific publication where the method employed is described it would be very helpful for me.
thanks
Jan.Östh is offline   Reply With Quote
Old   June 5, 2012, 08:14
Jan Östh
From what I've been able to interpret from the source code in turbulentInletFvPatchField.H and turbulentInletFvPatchField.C the turbulent inlet generates random fluctuations, and is not based on any method that tries to create synthesized turbulence through fourier modes.
Has anybody implemented a synthesized turbulence generating inlet himself? If, are you willing to share the code?
If not, would it be hard to implement it? If anybody who is knowledgeable could give me some general start up guide lines how to implement for exemple the method proposed in Smirnov et al, "Random Flow Generation
Technique for Large Eddy Simulations and Particle-Dynamics Modeling", J. Fluids Engineering, 2001, Vol. 123
It would be helpful. I might give it a try...
Old   June 6, 2012, 11:50
Frederic Collonval
Location: Technische Universitaet Munich - Lehrstuhl fuer Thermodynamik
fcollonv is on a distinguished road
Hi Jan,
There are lots of threads already on the subject - for example concerning re-mapping look for "de Villiers".
If you really want a turbulence synthesizer, there is one available in the code of LTT Rostock (http://www.kroegeronline.net/exchang...Extensions.tgz - call inflowGenerator). It's based on the transport of vortex to generate the turbulent fluctuations following a given scale and Reynolds tensor.
!! The inlet should be oriented such as the x-axis is pointing towards the inside of the domain - that's hard coded :s
Hope that it will help
Frederic Collonval
Technische Universität München
Thermodynamics Dpt.
fcollonv is offline   Reply With Quote
Old   June 7, 2012, 04:48
Jan Östh
Hi Frederic
Thank you for the reply. I will look into the code from Rostock. I also found the threads about the inlet mapping, this might be an option as well for me.
/Jan
Old   June 15, 2012, 11:22
Julien
Djub is on a distinguished road
hi Ian. I know a nice method from statisctical approach: you can read
Efficient Simulation of Multidimensionaol Random Fields
(Jin, Lutes and Sarkani, journal of Engineering Mechanics, oct. 1997, 1082-1089).
This method is able to generate correlated random fields with controlled spectral density.
Nevertheless, I am not sure this algorithm gives a divergence-free U field (I have to try that since several years...). I know "home-made" implementations of this algorithm, but I am not (yet ) a Foam programmer... Let me know if you find something in openFoam about this!
Djub is offline   Reply With Quote
Old   October 16, 2012, 05:56
cfdonline2mohsen's Avatar
Mohsen KiaMansouri
cfdonline2mohsen is on a distinguished road
Originally Posted by fcollonv View Post
Hi Jan,
Hi Frederic
Thanks for sharing the code
I want some more details about how this inflow generator works
would you please share the paper that is implemented in this code or at least the name of the paper and/or the authors?
Thanks in advance
Best Regard,
Mohsen
cfdonline2mohsen is offline   Reply With Quote
Old   December 17, 2012, 13:55
nabeel
nabeelalzurfi is on a distinguished road
HI,
you can use random number generator to implement the turbulent inlet boundary condition. The random generator interval should be between (-10 % and 10 % of inlet velocity).
nabeelalzurfi is offline   Reply With Quote
Old   October 24, 2014, 11:34
Freedom
wenxu is on a distinguished road
Hi Jan,
Hi,thank you for your sharing, but i cant open the link,http://www.kroegeronline.net/exchang...Extensions.tgz could you send it to me, thank you very much!!
my email box: 981588592@qq.com
wenxu is offline   Reply With Quote
Old   October 24, 2014, 11:41
Freedom
hello,Mohsen.i cant download the code,could you send it to me. 981588592@qq.com
thank you very much!!!
regards,
wen
Old   April 22, 2015, 03:06
Saeedur Rahman
1saeed9 is on a distinguished road
The link doesn't work. Could you please mail me the code at saeedur.rahman.imece@gmail.com ?
1saeed9 is offline   Reply With Quote
Old   May 6, 2015, 11:01
Sadiq Huq
comflics is on a distinguished road
Uni Rostock's OpenFOAM extension is hosted in GitHub
Code: https://github.com/LEMOS-Rostock/LEMOS-2.3.x
Features: http://www.lemos.uni-rostock.de/en/d...nfoam-content/
comflics is offline   Reply With Quote
Old   August 7, 2016, 22:39
Mahdi Hosseinali
anishtain4 is on a distinguished road
Does anyone knows what is the paper that turbulentInlet boundary condition is based on? It sure looks like to be implemented from a paper.
anishtain4 is offline   Reply With Quote
Old   February 18, 2018, 17:16
Default Les
  #13
fathia
tou7a is on a distinguished road
hello why the random generator interval should be between (-10% and 10%of inlet velociity
tou7a is offline   Reply With Quote
Old   February 18, 2018, 17:17
fathia
please why it should be between (-10% and 10% )
Old   November 26, 2019, 17:57
George Pichurov
jorkolino is on a distinguished road
Hi, do you know if turbulentInlet uses a random seed, for example clock time? I seem to get one and the same simulation results when running it multiple times, so it seems to me the seed is not arbitrary, but hard coded. Could anyone confirm this?
jorkolino is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
error message cuteapathy CFX 14 March 20, 2012 07:45
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
