Francesco Capuano
Rep Power: 16 ![]() |
Dear all,
I am trying to run a large-eddy simulation of turbulent pipe flow (which should not be conceptually different from a channel flow) by using channelFoam, and have encountered some problems. There are a couple of interesting threads on the forum about LES of pipes/channels, but none of them has solved my issues. If one considers a fully-developed flow in a pipe of diameter D, I think the following steps must be performed (please correct me if I'm wrong): 1. Create a 3D mesh, with a length of about 5*D in the streamwise direction; 2. Set up cyclic boundary conditions for "inlet"/"outlet", and no-slip for wall; 3. Impose a fluctuating field for variables (i.e. U) to generate turbulence; 4. Run channelFoam; 5. Postprocess (e.g. average in time and over the circumferential direction). My doubts are particularly concerned with steps 3 and 5. About step 3: a. How to perturb the velocity field? The perturbU and perturbCylinder utilities seem not to work with OpenFOAM 2.1.0. b. Is it really necessary to superimpose fluctuations? In principle, assuming a sufficiently high Reynolds number (Re > Re_tr ~ 1800), shouldn't LES be able to capture turbulence itself? (e.g., starting from instabilities of growing amplitude) And about 5: is the postChannel utility useful for pipe flow? Thanks in advance. Francesco |
Ganesh Vijayakumar
Reg. point 3, I think the best way to do it would be outside of OpenFOAM. I have done LES of channel flow in a rectangular channel, and I remember having imposed an initial condition with an approximate log law profile and desired variance distribution. If your mesh is large, you may want to go for this approach.
Reg. point 5, I think the best way to do it is to create cellZones with all cells at a constant radius. Then enable functionObjects to do the averaging over the cellZones. It may seem odd that you need about 50-100 cellZones, but you can script the process out and that should make it easier. The latest version of OpenFOAM can even do time averaging for you along with spatial averaging in the functionObjects. |
Hallo All,
Is there any utility to know about that can be used to perform spatial averaging of fields in some specific direction.? Regards, Awais |
#4 | |
Francesco Capuano
give a look at the postChannel utility, it performs spatial averaging in the two homogeneous directions of a channel flow. Regards, Francesco |
channelfoam, les, pipe flow |
LES turbulent pipe flow | panara | OpenFOAM Running, Solving & CFD | 68 | January 26, 2023 11:34 |
LES of turbulent channel flows | cedric_duprat | OpenFOAM Running, Solving & CFD | 220 | November 18, 2019 04:19 |
Particle deposition on circular cylinder in turbulent flow | Julian K. | CFX | 1 | October 3, 2011 17:51 |
Turbulent Flow in a Square Duct using LES | Hock Ming | FLUENT | 0 | February 7, 2009 20:25 |
LES on two phase flow | Li Yang | Main CFD Forum | 0 | May 12, 2004 08:10 |
