May 25, 2012, 06:03 |
cubic and limitedCubic scheme reference
Vesselin Krastev
Rep Power: 20 |
Hi all,
I was wondering if there are some references about the cubic/limitedCubic interpolation scheme implemented in OpenFOAM. I guess that the cubic scheme should be a centered fourth order scheme, but what about the limited one? What kind of limter/boundedness criterion is used? Is the same TVD limiter (Sweby limiter) used also for the limitedLinear scheme? Any additional info about this matter will be appreciated Thanks V. |
May 29, 2012, 09:04 |
Vesselin Krastev
Rep Power: 20 |
Well, I think I've found the answer myself: the scheme is indeed the centered fourth order differencing and the limited one uses a TVD limiter which should be the same as used in the limtedLinear scheme.
linearUpwind scheme in OpenFOAM 2.0.1 ??? | cabul | OpenFOAM | 8 | November 9, 2011 06:57 |
4th order schemes in channelOodles | maka | OpenFOAM Bugs | 9 | January 19, 2009 11:58 |
Unknown Discretization scheme | dinonettis | OpenFOAM Running, Solving & CFD | 3 | March 16, 2008 08:52 |
