Why are pointVectorFields not mapped using mapFields?
Like Tree1Likes
  • 1 Post By Henning86
Old   May 16, 2012, 08:22
Default Why are pointVectorFields not mapped using mapFields?
Max Haase
maxof is on a distinguished road
Hi all,
I am simulating boats which are free to heave and trim using interDyMFoam (OF-2.1.0). To make my simulations more efficient, I want to map a coarse mesh solution onto a fine mesh. I works perfectly as long as the object isnt moving. For some reason pointVectorFields (ie the pointDisplacement file) do not get mapped, even though they are required to run the simulation in the the target directory. I tried to grep the orientation (of the moving object) from the source directories pointDisplacement file and chucked it into the target directories file, but that is obviously not working. That draw a few questions regarding my understanding of mapFields and interDyMFoam:
Q1: Why are pointVectorFields not mapped?
Q2: How do I map the mesh deformation correctly?
Q3: Why is there a pointDisplacement AND cellDisplacement file, isnt that redundant information? Latter one is mapped OK.
Grateful for any advice!
Cheers, Max
maxof is offline   Reply With Quote
Old   May 16, 2012, 20:54
Max Haase
Well I just figured out how to solve Q2: You simply specify (deformed) orientation and centreOfMass AND initialOrientation and initialCentreOfMass. The actual points will be moved accordingly by the solver and the cellDisplacement too. Too easy!
Cheers, Max
Old   April 23, 2014, 09:44
Henning86 is on a distinguished road
hi
i have a similar problem with interDyMFoam (moving mesh) and mapFields. I just want to map from a coarse to a fine mesh but the solver crashes probably caused by the cell movement.
How did you solve the problem?
i use the command:
mapFields -sourceTime latestTime -consistent
Best regards
Henning
Henning86 is offline   Reply With Quote
Old   April 23, 2014, 12:35
Default solved
hi,
i figured it out.
mapFields doesn't take moving meshes into account. The domains of both cases dont match since the displacement isn't considered resulting in a crash.
It can be solved by using a dynamicMesh instead of fvmesh in mapFields
1. replace all fvmesh with solidBodyMotionFvMesh
2. update Header
3 compile
If you map the fields from the sourcecase to the target case the time folders need to be identical and the target case folder needs to be empty.
best regards
Henning
wyldckat likes this.
Old   April 25, 2014, 16:31
Retired Super Moderator
Bruno Santos
Greetings Henning,
It might make sense to report this issue on the bug tracker: http://www.openfoam.org/bugs/ - specially since you've already found the solution
Although, there is a limitation to this: if you change all "fvMesh" references to "solidBodyMotionFvMesh" or similar, then mapFields will only work if the file "constant/dynamicMeshDict" exists.
Best regards,
Bruno
Old   December 25, 2022, 11:49
TWB
quarkz is on a distinguished road
Originally Posted by Henning86 View Post
hi,
i figured it out.
2. update Header
3 compile
best regards
Henning
Hi Henning86 (or anyone),
Can you explain more clearly how it is done?
What do you mean by:
2. update Header
3 compile
Thanks!
quarkz is offline   Reply With Quote
Old   June 19, 2023, 12:50
TWB
I just tried to give it a go.
I'm not sure how to create a new mapField application so I took the easy way out. I simply edit the mapField.* source code and recompile a new OF.
However, I don't think I did it right. I simply search and replace all "fvmesh" with "solidBodyMotionFvMesh" in the 3 source codes:
mapFields.C
mapFields.H
mapFieldsTemplates.C
During compile, the error is:
In file included from mapFields/mapFields.H:224,
                 from mapFields/mapFields.C:28:
mapFields/mapFieldsTemplates.C:28:10: fatal error: solidBodyMotionFvMesh.H: No such file or directory
 #include "solidBodyMotionFvMesh.H"
compilation terminated.
make: *** [/home/users/nus/tsltaywb/scratch/OpenFOAM/OpenFOAM-v2212/wmake/rules/General/transform:38: /home/users/nus/tsltaywb/scratch/OpenFOAM/OpenFOAM-v2212/build/linux64Gcc841DPInt32Opt/src/functionObjects/field/mapFields/mapFields.o] Error 1
Can anyone help?
boats, interdymfoam, mapfields, pointdisplacement, pointvectorfields
Issues with mapFields BlackBoatNavArch OpenFOAM Pre-Processing 38 May 28, 2021 17:29
Modified mapFields? mturcios777 OpenFOAM Pre-Processing 4 October 31, 2012 12:33
transientSimpleDyMFoam, mapFields and decomposePar pad OpenFOAM Running, Solving & CFD 0 December 3, 2010 06:22
is free meshing or mapped meshing is best for flow problems shanu Main CFD Forum 0 February 18, 2010 12:58
[Other] is free meshing or mapped meshing is best for flow problems shanu OpenFOAM Meshing & Mesh Conversion 0 February 18, 2010 12:56
