Customize MULES
Like Tree1Likes
  • 1 Post By Phicau
Old   March 14, 2012, 12:43
Default Customize MULES
Pablo Higuera
Phicau is on a distinguished road
Dear all,
I need to modify MULES, and therefore convert it to myMULES.
In order to do so I follow the standard procedure copying the three files in my user folder, run rename 's/MULES/myMULES/g' *.* and sed -i 's/MULES/myMULES/g' *.*
I create the Make folder and add the two files:
files
myMULES.C
LIB = $(FOAM_USER_LIBBIN)/libmyMULES
options
EXE_INC = \
    -I$(LIB_SRC)/triSurface/lnInclude \
    -I$(LIB_SRC)/meshTools/lnInclude
LIB_LIBS = \
    -lOpenFOAM \
    -ltriSurface \
    -lmeshTools \
    -lfiniteVolume
Note that in the latter one I have added -lfiniteVolume
Then I try to compile it, but several errors regarding impossibility to locate and load dependencies arise.
¿What else do I have to include?
Thanks a lot
Pablo
Phicau is offline   Reply With Quote
Old   March 14, 2012, 13:08
Pablo Higuera
The magic of posting: you then achieve what you want in 5 minutes.
files
myMULES.C
options
EXE_INC = \
    -I$(LIB_SRC)/meshTools/lnInclude \
    -I$(LIB_SRC)/finiteVolume/lnInclude
LIB_LIBS = \
    -lOpenFOAM \
    -ltriSurface \
    -lmeshTools \
    -lfiniteVolume
and if you want to integrate the new MULES in myInterFoam:
files
myInterFoam.C
EXE = $(FOAM_USER_APPBIN)/myInterFoam
options
EXE_INC = \
    -I$(LIB_SRC)/transportModels \
    -I$(LIB_SRC)/transportModels/incompressible/lnInclude \
    -I$(LIB_SRC)/transportModels/interfaceProperties/lnInclude \
    -I$(LIB_SRC)/turbulenceModels/incompressible/turbulenceModel \
    -I$(LIB_SRC)/finiteVolume/lnInclude \
    -I./myMULES
EXE_LIBS = \
    -ltwoPhaseInterfaceProperties \
    -lincompressibleTransportModels \
    -lincompressibleTurbulenceModel \
    -lincompressibleRASModels \
    -lincompressibleLESModels \
    -lfiniteVolume \
    $(FOAM_USER_LIBBIN)/libmyMULES.so
regarding that the 3 custom MULES files are within the myMULES folder in the root of myInterFoam
randolph likes this.
Old   August 6, 2018, 10:46
Reviewer #2
randolph is on a distinguished road
files
myMULES.C
options
EXE_INC = \
LIB_LIBS = \
    -lOpenFOAM \
    -ltriSurface \
    -lmeshTools \
    -lfiniteVolume
files
myInterFoam.C
options
EXE_INC = \
    -I./myMULES
EXE_LIBS = \
    -lfiniteVolume \
This line drag me out of the 1-week debugging session
randolph is offline   Reply With Quote
mules
Multiple floating objects CKH OpenFOAM Running, Solving & CFD 14 February 20, 2019 10:08
interFoam VOF is loosing fluid wersoe OpenFOAM Running, Solving & CFD 12 June 26, 2013 09:13
Errno 24 linux ivanwhlau OpenFOAM Running, Solving & CFD 6 July 1, 2009 11:16
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 12:16
Can I Customize Fluent Environment venugopal FLUENT 0 June 16, 2004 13:15
