simpleFunctionObjects and OpenFOAM 2.0.x
Like Tree1Likes
  • 1 Post By gschaider
Old   November 22, 2011, 10:47
Default simpleFunctionObjects and OpenFOAM 2.0.x
Oliver Lauer
olauer is on a distinguished road
Hello everybody,
is there already a version of simpleFunctionObjects which compiles with OpenFOAM 2.0.x? For me
wmake libso
ends up with
SOURCE=patch/patchAverageFunctionObject/patchAverageFunctionObject.C ; g++-4.3 -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Woldstyle-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/data/rod/simulation/OpenFOAM/OpenFOAM-2.0.x/src/finiteVolume/lnInclude -I/data/rod/simulation/OpenFOAM/OpenFOAM-2.0.x/src/meshTools/lnInclude -I/data/rod/simulation/OpenFOAM/OpenFOAM-2.0.x/src/sampling/lnInclude -I/data/rod/simulation/OpenFOAM/OpenFOAM-2.0.x/src/triSurface/lnInclude -I/data/rod/simulation/OpenFOAM/OpenFOAM-2.0.x/src/lagrangian/basic/lnInclude -IlnInclude -I. -I/data/rod/simulation/OpenFOAM/OpenFOAM-2.0.x/src/OpenFOAM/lnInclude -I/data/rod/simulation/OpenFOAM/OpenFOAM-2.0.x/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/patchAverageFunctionObject.o
/data/rod/simulation/OpenFOAM/OpenFOAM-2.0.x/src/OpenFOAM/lnInclude/functionObject.H: In static member function 'static Foam::autoPtr<Foam::functionObject> Foam::functionObject::adddictionaryConstructorToTa ble<functionObjectType>::New(const Foam::word&, const Foam::Time&, const Foam::dictionary&) [with functionObjectType = Foam::PatchAverageFunctionObject]':
/data/rod/simulation/OpenFOAM/OpenFOAM-2.0.x/src/OpenFOAM/lnInclude/functionObject.H:91: instantiated from 'Foam::functionObject::adddictionaryConstructorToT able<functionObjectType>::adddictionaryConstructor ToTable(const Foam::word&) [with functionObjectType = Foam::PatchAverageFunctionObject]'
patch/patchAverageFunctionObject/patchAverageFunctionObject.C:44: instantiated from here
/data/rod/simulation/OpenFOAM/OpenFOAM-2.0.x/src/OpenFOAM/lnInclude/functionObject.H:84: error: cannot allocate an object of abstract type 'Foam::PatchAverageFunctionObject'
patch/patchAverageFunctionObject/patchAverageFunctionObject.H:54: note: because the following virtual functions are pure within 'Foam::PatchAverageFunctionObject':
/data/rod/simulation/OpenFOAM/OpenFOAM-2.0.x/src/OpenFOAM/lnInclude/functionObject.H:152: note: virtual bool Foam::functionObject::execute(bool)
make: *** [Make/linux64GccDPOpt/patchAverageFunctionObject.o] Error 1
Thanks for any ideas
Oliver
olauer is offline   Reply With Quote
Old   November 22, 2011, 15:26
Retired Super Moderator
Bruno Santos
Greetings Oliver,
Here's a quote from the wiki page dedicated to simpleFunctionObjects:
Originally Posted by http://openfoamwiki.net/index.php/Contrib_simpleFunctionObjects
Note: This library will be integrated into swak4Foam starting with OF 2.0. The library is still compilable independently of the other parts of swak
Best regards,
Bruno
Old   November 22, 2011, 17:48
Assistant Moderator
Bernhard Gschaider
Originally Posted by wyldckat View Post
Greetings Oliver,
Best regards,
Bruno
There is even a link to download it via SVN at the bottom of the page. Haven't you seen it? It's been there for .... er .... almost 2 minutes
wyldckat likes this.
Old   November 23, 2011, 04:50
Thumbs up
Oliver Lauer
Thank you very much.
As always, it is an advantage if you can read
Nevertheless, my original posting wasn't completely useless
[SOLVED] Intel Compiler 12.1 + Ubuntu 11.10 (gcc 4.6) + OpenFOAM 2.0.x wyldckat OpenFOAM Installation 0 November 4, 2011 15:52
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 07:55
OpenFOAM 2.0.x libscotch issues gfilip OpenFOAM Installation 4 July 11, 2011 12:23
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 07:25
Modified OpenFOAM Forum Structure and New Mailing-List pete Site News & Announcements 0 June 29, 2009 06:56
