Storing Boundary Condition Values for Later Use
Like Tree2Likes
  • 2 Post By Fransje
Old   October 19, 2011, 16:10
Question Storing Boundary Condition Values for Later Use
Francois
Fransje will become famous soon enough
Dear Foamers,
I would like to be able to store time-averaged patch values I extract from a boundary condition I'm programming. More specifically I'm trying to store a vectorField. The problem is that at every (sub)-iteration step the boundary condition I'm working on is instantiated and destroyed again, making it impossible to store it in the boundary condition itself.
I thought of a few things:
  1. I could store it in a file, but reading from and writing to disk every sub-iteration step would be prohibitively expensive, so that is not an option.
  2. I tried hacking my way into the IOobject registry, by using a IOList<vector>, but it is deleted as soon as my boundary condition is uninstantiated.. So that doesn't work either.
  3. I tried putting the same IOList<vector> in the solver, which doesn't work either, because when the solver start I don't know what the size of my vectorField would be, and I can't modify the IOList object once it is created..
So this leaves me out of ideas...
Would anybody know how to solve this? Maybe by finding a way workaround allowing me to modify the IOList?
Looking forward to your suggestions
Francois.
Fransje is offline   Reply With Quote
Old   October 19, 2011, 22:08
David Gaden
marupio is on a distinguished road
Can you access it during a sub iteration, when it is still alive, and store a copy at the top level? Then you could use your registry hack to retrieve a const copy from within the boundary condition the next time to create a fresh copy.
I can't think of much else - the algorithm you describe is difficult to guess at.
Follow me on twitter @DavidGaden
marupio is offline   Reply With Quote
Old   October 19, 2011, 22:20
Sandeep Menon
deepsterblue will become famous soon enough
So you want a vectorField stored for each time-step? Are you looking to store this list of vectorFields to a file eventually (i.e., when the run is completed presumably)?
You can always resize a field using the setSize() member function, so it is possible to modify it after construction.
Sandeep Menon
University of Massachusetts Amherst
https://github.com/smenon
deepsterblue is offline   Reply With Quote
Old   October 20, 2011, 04:41
Tomislav Maric
tomislav_maric is on a distinguished road
Originally Posted by Fransje View Post
Dear Foamers,
Why would you define and destroy a boundary condition, and even more on every sub-iteration? The purpose of the BC is to influence the computation of the matrix coefficients, you may have a boundary condition which requires some kind of sub-cycle, but at the end, it will just do that. Do you mean you are initializing and deleting a FvPatchField object (or derived one)?
What is the overall algorithm that you need? I don't mean what you have implemented so far, but, your actual goal?
tomislav_maric is offline   Reply With Quote
Old   October 20, 2011, 11:02
Francois
Dear All,
Thank you for your replies!
I will reply to them in anti-chronological order.
  1. Dear Tomislav, Sorry for being unclear. Yes, I'm using a derived -FvPatchField, so it is being re-instantiated at every sub-iteration.
    The overal algorithm I need for my PatchField I already implemented. I'm working on a sort of recycled-inflow. But for the time being, as I didn't manage to store time-averaged mean-velocity data, I can only look at planner-averages. Eventually I would like to be able to also include time-averaging for increased accuracy.
  2. Dear Sandeep, Yes, in fact, the easiest for me would be to store a vectorField which I can lookup and modify at each timestep. And eventually, yes, I will print it to a file. But the printing out is not the issue, the use of OFstream is very straightforward.
  3. Dear David, Yes, I can access the IOobject I create during a sub-iteration, when it's still alive. Unfortunately, once my I exit my boundary condition, it gets kicked out of the registry.. :-(
    I doubt the setSize() option would work on my third solution (i.e., where the IOobject is created in the solver), because the object returned from the registry database is constant. Something like:
    const IOList<vector>& myVec = mesh.thisDb().lookupObject< IOList<vector> >("myVectorList");
I hope this clarified slightly the explanation of the issue I was having..
Looking forward to your replies,
Kind regards,
Francois.
Old   October 20, 2011, 11:35
Tomislav Maric
Well, if the IOobject is dying when going out of scope, why not wrap it into a tmp<IOobject>? This way, it won't die after going out of scope... either this or autoPtr..
I think I get what you mean to do now (hopefully), thanks for clarifying!
Tomislav
Old   October 20, 2011, 17:21
David Gaden
Yes, you could try using tmp. See here: http://openfoamwiki.net/index.php/OpenFOAM_guide/tmp
Here's what I mean.
In createFields.H:
- Create a vectorField with a size of 0.
- Initialize your IOList<vector> hack as well, size = 0.
In your custom boundary condition:
- lookup your IOList
-- if size = 0, initialize your temporary vectorField with all vectors at your initial guess (zero?).
-- if size != 0, initialize your temporary vectorField by copying the vectors from IOList.
In you solver body, sub-iteration loop, when the custom boundary condition exists:
- Access the boundary field in question.
- setSize your IOList, and copy the field values into it.
Old   October 21, 2011, 09:15
Thumbs up
Francois
Dear Tomislav, dear David,
Although I was aware of the existence of tmp<> objects I thought they were only used to return large objects from functions. I will re-dive in the wiki and try to implement my vectorFields following your guidelines. I'll keep you updated on my progress!
Thank you for your help,
Kind regards,
Francois.
Old   October 21, 2011, 10:47
David Gaden
tmp<> will only work if another object is holding a reference to it outside of your boundary condition.
Old   December 9, 2011, 12:00
Smile Store in Object registry
Francois
Anyways, just in case somebody might be interested in how I solve this problem, here is my workaround:
  1. Look in the database if my variable exisits.
  2. This leads to two options:
    1. No, it doesn't exist. => read the variable from a file, create an IOobject from it and store it in the database. Then use it.
    2. Yes, it exists. => Great. Just look it up and use it.
  3. After use, it has to be updated in the databse. However, you can only retrieve const object from the database, so in theory you cannot change the objects in the database directy. But a workaround can be found using a const_cast<>() function.
The check, reading and checking in of the new variable in the registry is done with this code gem:
List<vector> avgMeanReturned( my_var_size, vector::zero );
if( !mesh.thisDb().foundObject< IOList< vector > >( "avgMean" ) )
    if( Pstream::master() )
        avgMeanReturned = readMeanFromFile();
    reduce( avgMeanReturned , sumOp< List< vector > >() );
    mesh.thisDb().store
        new IOList< vector >
            IOobject
                "avgMean",
                mesh,
                IOobject::NO_READ,
                IOobject::NO_WRITE
            avgMeanReturned
else
    const IOList< vector >& dbVecLst
        = mesh.thisDb().lookupObject< IOList< vector > >(  "avgMean"  );
    avgMeanReturned = dbVecLst;
return avgMeanReturned;
And the update with const_cast<>() can be done using:
// using the new variable avgMeanUpdated
const_cast< IOList< vector >& >( dbVecLst ) = avgMeanUpdated;
Hope this might be of help to somebody someday.
Kind regards,
Francois.
Boundary condition & reverse flows zhenglun.wei FLUENT 4 October 25, 2011 18:38
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 16:45
how to set up a wall boundary condition according to calculated wall shear stress? gameoverli OpenFOAM Pre-Processing 1 May 21, 2009 09:28
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
Pressure Boundary Condition Matt Umbel Main CFD Forum 0 January 11, 2002 11:06
