Custom BC compile warnings & Runtime Errors
Like Tree1Likes
  • 1 Post By ic3wall
Old   September 28, 2011, 16:05
Default Custom BC compile warnings & Runtime Errors
Hisham's Avatar
Hisham Elsafti
Hisham is on a distinguished road
Dear Foamers,
I have modified some existing BCs (the timwVaryingMappedFixedValue and the tractionDisplacement). My goal is to make a timeVaryingMappedTractionDisplacement. I made what I believe to be the necessary modifications. I debugged apparent errors and it builds with warnings and an error . To me now, it is clear they are not just warnings they are errors because a sample problem crashes at initializing the variable for the BC, although it works fine for a displacement timwVaryingMappedFixedValue BC.
The warnings for the wmake:
hisham@numubuntu-System-Product-Name:~/OpenFOAM/numubuntu-2.0.0/trySolidDisplacementFoam$ wmake
Making dependency list for source file timeVaryingMappedTractionDisplacement/timeVaryingMappedTractionDisplacementFvPatchVectorField.C
SOURCE=timeVaryingMappedTractionDisplacement/timeVaryingMappedTractionDisplacementFvPatchVectorField.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/opt/openfoam200/src/finiteVolume/lnInclude -ItractionDisplacement/lnInclude -ItimeVaryingMappedTractionDisplacement/lnInclude -I/opt/openfoam200/src/triSurface/lnInclude -I/opt/openfoam200/src/meshTools/lnInclude -IlnInclude -I. -I/opt/openfoam200/src/OpenFOAM/lnInclude -I/opt/openfoam200/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/timeVaryingMappedTractionDisplacementFvPatchVectorField.o
timeVaryingMappedTractionDisplacement/timeVaryingMappedTractionDisplacementFvPatchVectorField.H: In constructor ‘Foam::timeVaryingMappedTractionDisplacementFvPatchVectorField::timeVaryingMappedTractionDisplacementFvPatchVectorField(const Foam::fvPatch&, const Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh>&)’:
timeVaryingMappedTractionDisplacement/timeVaryingMappedTractionDisplacementFvPatchVectorField.H:110:21: warning: ‘Foam::timeVaryingMappedTractionDisplacementFvPatchVectorField::pressure_’ will be initialized after
timeVaryingMappedTractionDisplacement/timeVaryingMappedTractionDisplacementFvPatchVectorField.H:65:14: warning:   ‘Foam::word Foam::timeVaryingMappedTractionDisplacementFvPatchVectorField::fieldTableName_’
timeVaryingMappedTractionDisplacement/timeVaryingMappedTractionDisplacementFvPatchVectorField.C:45:1: warning:   when initialized here
timeVaryingMappedTractionDisplacement/timeVaryingMappedTractionDisplacementFvPatchVectorField.H:95:16: warning: ‘Foam::timeVaryingMappedTractionDisplacementFvPatchVectorField::startTractionAverage_’ will be initialized after
timeVaryingMappedTractionDisplacement/timeVaryingMappedTractionDisplacementFvPatchVectorField.H:92:21: warning:   ‘Foam::scalarField Foam::timeVaryingMappedTractionDisplacementFvPatchVectorField::startPressureSampledValues_’
timeVaryingMappedTractionDisplacement/timeVaryingMappedTractionDisplacementFvPatchVectorField.H:105:16: warning: ‘Foam::timeVaryingMappedTractionDisplacementFvPatchVectorField::endTractionAverage_’ will be initialized after
timeVaryingMappedTractionDisplacement/timeVaryingMappedTractionDisplacementFvPatchVectorField.H:103:21: warning:   ‘Foam::scalarField Foam::timeVaryingMappedTractionDisplacementFvPatchVectorField::endPressureSampledValues_’
timeVaryingMappedTractionDisplacement/timeVaryingMappedTractionDisplacementFvPatchVectorField.H: In constructor ‘Foam::timeVaryingMappedTractionDisplacementFvPatchVectorField::timeVaryingMappedTractionDisplacementFvPatchVectorField(const Foam::timeVaryingMappedTractionDisplacementFvPatchVectorField&, const Foam::fvPatch&, const Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh>&, const Foam::fvPatchFieldMapper&)’:
timeVaryingMappedTractionDisplacement/timeVaryingMappedTractionDisplacementFvPatchVectorField.C:85:1: warning:   when initialized here
timeVaryingMappedTractionDisplacement/timeVaryingMappedTractionDisplacementFvPatchVectorField.H: In constructor ‘Foam::timeVaryingMappedTractionDisplacementFvPatchVectorField::timeVaryingMappedTractionDisplacementFvPatchVectorField(const Foam::fvPatch&, const Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh>&, const Foam::dictionary&)’:
timeVaryingMappedTractionDisplacement/timeVaryingMappedTractionDisplacementFvPatchVectorField.C:123:1: warning:   when initialized here
timeVaryingMappedTractionDisplacement/timeVaryingMappedTractionDisplacementFvPatchVectorField.H: In copy constructor ‘Foam::timeVaryingMappedTractionDisplacementFvPatchVectorField::timeVaryingMappedTractionDisplacementFvPatchVectorField(const Foam::timeVaryingMappedTractionDisplacementFvPatchVectorField&)’:
Hisham is offline   Reply With Quote
Old   September 28, 2011, 16:06
Hisham's Avatar
Hisham Elsafti
Continue:
timeVaryingMappedTractionDisplacement/timeVaryingMappedTractionDisplacementFvPatchVectorField.C:171:1: warning:   when initialized here
timeVaryingMappedTractionDisplacement/timeVaryingMappedTractionDisplacementFvPatchVectorField.H: In constructor ‘Foam::timeVaryingMappedTractionDisplacementFvPatchVectorField::timeVaryingMappedTractionDisplacementFvPatchVectorField(const Foam::timeVaryingMappedTractionDisplacementFvPatchVectorField&, const Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh>&)’:
timeVaryingMappedTractionDisplacement/timeVaryingMappedTractionDisplacementFvPatchVectorField.C:206:1: warning:   when initialized here
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/opt/openfoam200/src/finiteVolume/lnInclude -ItractionDisplacement/lnInclude -ItimeVaryingMappedTractionDisplacement/lnInclude -I/opt/openfoam200/src/triSurface/lnInclude -I/opt/openfoam200/src/meshTools/lnInclude -IlnInclude -I. -I/opt/openfoam200/src/OpenFOAM/lnInclude -I/opt/openfoam200/src/OSspecific/POSIX/lnInclude   -fPIC -Xlinker --add-needed Make/linux64GccDPOpt/tractionDisplacementFvPatchVectorField.o Make/linux64GccDPOpt/timeVaryingMappedTractionDisplacementFvPatchVectorField.o Make/linux64GccDPOpt/trySolidDisplacementFoam.o -L/opt/openfoam200/platforms/linux64GccDPOpt/lib \
	     -lfiniteVolume -lOpenFOAM -ldl   -lm -o /home/hisham/OpenFOAM/hisham-2.0.0/platforms/linux64GccDPOpt/bin/trySolidDisplacementFoam
The new BC is linked directly (statically) to the solver, just as the case with the solidDisplacementFoam solver and the tractionDisplacement BC. I, therefore, introduced a new solver called trySolidDisplacementFoam (no need to mess the original now, is there?)
I enclose the solver files and a tryPlateHole example. I hope that my error is easy to spot for someone (I am sure it is)!
Best regards,
Hisham
Old   September 29, 2011, 07:51
Hisham's Avatar
Hisham Elsafti
Dear Foamers,
I have modified it a bit. It compiles with warnings still. However, a run was successful. As I open paraFoam and choose to view the displacement "D", it crashes giving the following error:
hisham@numubuntu-System-Product-Name:~/solidDispFoamRun$ trySolidDisplacementFoam > log
hisham@numubuntu-System-Product-Name:~/solidDispFoamRun$ paraFoam &
[1] 3154
--> FOAM FATAL IO ERROR:
    Cannot find 'value' entry on patch CaissonLeft of field D in file "/home/hisham/solidDispFoamRun/0/D"
    which is required to set the values of the generic patch field.
    (Actual type timeVaryingMappedTractionDisplacement)
    Please add the 'value' entry to the write function of the user-defined boundary-condition
file: /home/hisham/solidDispFoamRun/0/D::boundaryField::CaissonLeft from line 47 to line 48.
    From function genericFvPatchField<Type>::genericFvPatchField(const fvPatch&, const Field<Type>&, const dictionary&)
    in file genericFvPatchField/genericFvPatchField.C at line 71.
FOAM exiting
I have tried the following line in the write function of the BC:
writeEntry("value", os);
I also tried:
this->writeEntry("value", os);
Both give the same error! Please help me find out the problem. I can upload the current version of code upon request.
Best regards,
Hisham
Old   September 29, 2011, 09:23
Hisham's Avatar
Hisham Elsafti
I managed to solve the problems. It seems to work alright. Still needs more testing though. Anyone interested, please email me.
Thanks,
Hisham
Old   November 1, 2011, 22:10
ic3wall is on a distinguished road
I had the same problem, when it says:
"... will be initialized after "
Make sure you declare your variables in the same order in both the .C and .H files
lincui likes this.
ic3wall is offline   Reply With Quote
Old   November 2, 2011, 03:48
Hisham's Avatar
Hisham Elsafti
I guess this is a C++ issue ...
Maybe a link like this will help:
http://objectmix.com/c/343613-warnin...zed-after.html
Regards,
Hisham
boundary condition, mapped, soliddisplacementfoam, timevarying
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 14:21
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
