Mirko Vukovic
Rep Power: 17 ![]() |
I am developing a boundary condition based on turbulentTemperatureCoupledBaffle and compiling with Code:
wmake libso Code:
multiRegionRadSimpleSolver: symbol lookup error: /opt/OpenFOAM/OpenFOAM-2.0.x/platforms/linux64Gcc45DPOpt/lib/libcoupledDerivedFvPatchFields.so: undefined symbol: _ZN4Foam9NamedEnumINS_22temperatureCoupledBase11KMethodTypeELi4EE5namesE Code:
nm /opt/OpenFOAM/OpenFOAM-2.0.x/platforms/linux64Gcc45DPOpt/lib/libcoupledDerivedFvPatchFields.so | grep _ZN4Foam9NamedEnumINS_22temperatureCoupledBase11KMethodTypeELi4EE5namesE U _ZN4Foam9NamedEnumINS_22temperatureCoupledBase11KMethodTypeELi4EE5namesE Thank you, Mirko |
David Gaden
Rep Power: 22 ![]() |
Whenever I get weird, inconsistent errors like that, I try recompiling OpenFOAM. That's my shot in the dark.
#3 | |
Martin Beaudoin
The capital letter U in front of the symbol stands for Undefined... 'man nm' is your friend here. Martin |
Mirko Vukovic
I was wondering what the `U' meant :-) I should have pursued it further.
Mirko |
Mirko Vukovic
I think I understand what went wrong: I was overriding an OpenFOAM library with my own incomplete library.
I am adding a boundary condition derived from compressible::turbulentTemperatureCoupledBaffle. In Make/files, I specified as the destination $FOAM_USER_LIBBIN/libcompressibleTurbulenceModel. Presumably, this prevented the $FOAM_LIBBIN/libcompressibleTurbulenceModel from linking. Mirko |
#6 | |
Dongyue Li
Rep Power: 18 ![]() |
If it prevented the lib from linking, how to relink it with your own lib? |
Hisham Elsafti
Dear all,
I got a similar error like that today and it went away after fixing an error in the code. The error was forgetting to add the class name before the function name for some reimplemented virtual functions: void className::functionName() instead of just: void functionName() Hisham |
Mieszko Młody
Dear Mirko,
I now that it was in 2009... but I have similar problem, but even more strange... I developed new BC as well, but im my case everything run well on one processor, but If I want to run in parallel I got the same error as u had. running decomposeParDic: dlopen error : /home/user/OpenFOAM/user-2.3.0/platforms/linux64GccDPOpt/lib/customlibcompressibleTurbulenceModel.so: undefined symbol: _ZN4Foam9NamedEnumINS_22temperatureCoupledBase11KM ethodTypeELi4EE5namesE any idea ? thank you MM |
#9 |
Vedamt Chittlangia
Rep Power: 9 ![]() |
was anyone able to solve this problem?
I am stuck here and can't move forward. |
#10 |
Jue Wang
Rep Power: 12 ![]() |
I got the same problem. Still looking for information to solve it. Joe |
#11 |
Jue Wang
I'm not sure if it's exactly the same problem as I came across as the following link and I solved mine. Good luck! Joe New dynamic mesh rule with symbol lookup error |
#12 |
tooran
Hi All,
In order to access the mesh information add the follwoing lines in my own library : const objectRegistry& db(); const volVectorField& U = db().lookupObject<volVectorField>("U"); const fvMesh & mesh = U.mesh(); forAll ( etat, cellI) //loop through cell centres { etat[cellI]=mesh.C()[cellI].y(); if ( etat[cellI]< 0.048)..... But because of the const objectRegistry& db(); const volVectorField& U = db().lookupObject<volVectorField>("U"); const fvMesh & mesh = U.mesh(); when I run it, it shows me error : symbol lookup error:........................ undefined symbol: _ZN4Foam15viscosityModels2dbEv Does anybody can help me? Thanks |
#13 |
tooran
I solved the problem by removing the following lines
const objectRegistry& db(); const volVectorField& U = db().lookupObject<volVectorField>("U"); const fvMesh & mesh = U.mesh(); And just write the following line: const fvMesh& mesh = U_.mesh(); |
#14 |
Tushar Survase
Rep Power: 5 ![]() |
I have faced the similar type of issue. Libraries need to be compiled correctly. Check the file and options of Make folder. In my case, the libraries were not linked. Hope it helps.
#15 | |
Elliott Sutton
Rep Power: 6 ![]() |
error: ‘const volVectorField& Foam::constitutiveEq::U_’ is private within this context 147 | const fvMesh& mesh = U_.mesh(); |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
OpenFOAM install on Ubuntu Natty 11.04 | bkubicek | OpenFOAM | 13 | May 26, 2011 05:48 |
How to install CGNS under windows xp? | lzgwhy | Main CFD Forum | 1 | January 11, 2011 18:44 |
[Netgen] Installation of Netgen in SuSE Linux 92 | edvardsenpriv | OpenFOAM Meshing & Mesh Conversion | 23 | January 16, 2009 06:12 |
user defined function | cfduser | CFX | 0 | April 29, 2006 10:58 |
