Solving N (Non-Coupled) Scalar Transport Equations
Like Tree2Likes
  • 2 Post By marc.immer
Old   July 8, 2011, 04:20
Default Solving N (Non-Coupled) Scalar Transport Equations
Joel Lehikoinen
joel.lehikoinen is on a distinguished road
I need to create a solver based on buoyantPimpleFoam which solves an arbitrary (around 10) scalar transport equations. I have written a solver which solves one passive scalar transport equation. I could just copy-paste that code enough many times, but I would like to know if a more elegant solution is possible: Namely, how easy it would be to implement a for-loop that solves N scalar transport equations, where N is specified by the user? The problem is, I don't know C++ and I'm not too familiar with the classes present in OpenFOAM.
As far as I know, the vectors in OpenFOAM are always 3-dimensional. But could I use a tensor of rank (1,N) or (N,1) to store the scalars? Or is using a tensor a bad idea, if I want to have different BCs for the scalars? Tensor would be nice because then I wouldn't have to worry about how to get OF to read/write files with indices in their names (scalar1, scalar2, etc.).
This is not a critical problem, as I said I can just copy-paste the code snippet that solves one scalar transport equation N times, but if I want to change the number of scalars later it becomes cumbersome to recompile the solver every time. I was just wondering if anyone with more knowledge of C++ and OF source code knows these things.
Regards,
Joel
joel.lehikoinen is offline   Reply With Quote
Old   July 8, 2011, 05:00
Laurence R. McGlashan
l_r_mcglashan will become famous soon enough
Sure, you can use a PtrList. Here's how you initialise them:
//  Create a list of pointers to the mass fraction field of each species.
    PtrList<volScalarField> chemicalSpecies(numberOfSpecies);
    for (label i=0; i<numberOfSpecies; ++i)
        Info << "Creating Species " << namesOfSpecies[i] << endl;
        chemicalSpecies.set
            i,
            new volScalarField
                IOobject
                    namesOfSpecies[i],
                    runTime.timeName(),
                    mesh,
                    IOobject::NO_READ,
                    IOobject::AUTO_WRITE
                mesh,
                dimensionedScalar("zero", dimless, 0.0),
                mixtureFraction.boundaryField().types()
Then use a for loop to solve the equations, as done in, for example, YEqn.H in solvers/combustion/chemFoam
Laurence R. McGlashan :: Website
l_r_mcglashan is offline   Reply With Quote
Old   July 12, 2011, 03:41
Joel Lehikoinen
Thank you very much for your help, I managed to create the solver I will need.
Old   February 19, 2013, 03:56
AD
dinksy is on a distinguished road
I am also trying to solve a similar problem of solving transport equation of n scalars, say c, and would like to define them as an array, such as c[n] instead of defining n separate scalarfields. The above thread was of some help but if you can tell me which solver it is a part of then I could look into it to clarify my doubts. The main problem I face is with the definition of c as an array in the initial time folder [0].
Regards
dinksy is offline   Reply With Quote
Old   October 1, 2013, 06:47
Marc
marc.immer is on a distinguished road
I'm asking myself the same question (how to initialize the array in the 0 folder).
Did you make any progress?
Marc
marc.immer is offline   Reply With Quote
Old   October 1, 2013, 09:36
Olivier
olivierG is on a distinguished road
hello,
Why you don't use reactingFoam or rhoReacting(Buoyant)Foam ?
At least take a look at this solver.
regards,
olivier
olivierG is offline   Reply With Quote
Old   October 1, 2013, 09:44
Marc
Thanks, reactingFoam is helpful. But I guess there is no easier way than duplicating/renaming the files in the 0 Folder for each species. But this at least can be automated with a script.
Cheers
Marc
Old   October 1, 2013, 09:50
Olivier
yes and no
If you take a look at reactingFoam tutorial, for product of reaction, you have a "Ydefault" file, in which you specify the defaut boundary conditions for the species. So you may try to use this.
regards,
olivier
Old   October 1, 2013, 11:16
Marc
I took a look at the reactingFoam solver. Since I'm only interested in a passive scalar transport, having a whole thermodynamic model might be a bit overkill... I'm not sure how I could only extract the classes I need, since it all seems to dependend on the classes basicMultiComponentMixture and chemistryReader.
Regards
Marc
Old   October 3, 2013, 09:00
Marc
I managed to get it to work. I used parts of the reactingFoam for the loop structure,
tmp<fv::convectionScheme<scalar> > mvConvection
	    fv::convectionScheme<scalar>::New
		mesh,
		fields,
		phi,
		mesh.divScheme("div(phi,si_h)")
	volScalarField kappaEff
	    "kappaEff",
	    turbulence->nu()/Pr + turbulence->nut()/Prt
	forAll(s, i)
	    volScalarField& si = s[i];
	    tmp<fvScalarMatrix> siEqn
		    fvm::ddt(si)
		  + mvConvection->fvmDiv(phi, si)
		  - fvm::laplacian(kappaEff, si)
	    sources.constrain(siEqn());
            solve(siEqn() == sources(si),mesh.solver("si"));
and copy pasted parts of the chemistryReader to get the initial files.
To define the species, I added a list into the transportProperties dict. (makes it easier to read in the createFields.H
wordList names(transportProperties.lookup("scalars"));
    PtrList<volScalarField> s(names.size());
    forAll(s, i)
        IOobject header
            names[i],
            mesh.time().timeName(),
            mesh,
            IOobject::NO_READ
        // check if field exists and can be read
        if (header.headerOk())
            s.set
                i,
                new volScalarField
                    IOobject
                        names[i],
                        mesh,
                        IOobject::MUST_READ,
                    mesh
        else
            volScalarField sdefault
                IOobject
                    "sdefault",
                    mesh,
                    IOobject::NO_WRITE
                mesh
            s.set
                i,
                new volScalarField
                    IOobject
                        names[i],
                        mesh,
                        IOobject::NO_READ,
                    sdefault
    multivariateSurfaceInterpolationScheme<scalar>::fieldTable fields;
    forAll(s, i)
	    fields.add(s[i]);
olivierG and reza2031 like this.
scalar transport
GAMG solver causes troubles colinB OpenFOAM Running, Solving & CFD 5 June 13, 2013 08:48
Full pipe 3D using icoFoam cyberbrain OpenFOAM 4 March 16, 2011 10:20
calculation diverge after continue to run zhajingjing OpenFOAM 0 April 28, 2010 05:35
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 12:16
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
