Source Term on Scalar Transport Equation
Like Tree4Likes
  • 1 Post By santos
  • 1 Post By santos
  • 2 Post By santos
Old   January 27, 2011, 12:59
Default Source Term on Scalar Transport Equation
alessio.nz's Avatar
Alex
alessio.nz is on a distinguished road
I have to add a transport scalar equation on the variable "C" but the problem is how to add the source term.
Using for instance SimpleFoam and modifying the solver I obtain the following equation for C "Ceqn.H":
solve
fvm::ddt(C)
+fvm::div(phi, C)
-fvm::laplacian(nu, C)
This is without source term and it works after I tested, including all the changes I have to do in the NewSimpleFoam.C and in createFields.H
Suppose that I want to add the sorce term with the following expression ST=C*(1-C), considering that I have to respect the dimensions in the solving, how can I set this ?
thanks in advance
alex
alessio.nz is offline   Reply With Quote
Old   January 28, 2011, 06:20
santos's Avatar
Jose Luis Santos
santos is on a distinguished road
Send a message via Skype™ to santos
You can just include your source term as 'C*(1-C)' in the Ceqn.H equation. In this way it will be defined explicitly. I am not sure if you can work out the dimensions of this source term so it is consistent with the other terms.
Probably you want the source term to be implicit for better convergence stability, so you need to include it as: 'fvm::Sp(k,C)', where k is a constant that is to be multiplied by C.
Regards,
Jose
rarnaunot likes this.
santos is offline   Reply With Quote
Old   January 28, 2011, 06:32
alessio.nz's Avatar
Alex
Hi, thanks for the reply. If I consider the second option, implicit ST, and I write the fvm::Sp(k,C) to the Ceqn.H, do you think I should also declare the k in the createFields.H? regards alex
Old   January 28, 2011, 06:56
santos's Avatar
Jose Luis Santos
Alex,
k is a placeholder for the constants that are multiplied by C in your source term.
Hence, if your source term is 2*C, it is defined implicitly as: fvm::Sp(2,C). The Programmers Guide that comes with OpenFOAM has more information on this.
Regards,
Jose
Old   January 28, 2011, 08:01
alessio.nz's Avatar
Alex
thanks a lot! I will try to fix it.
cheers,
alex
Old   January 31, 2011, 04:49
Default re: Source Term on Scalar Transport Equation
alessio.nz's Avatar
Alex
Hi I setted the equation as follows, but everytime there is an error. Do you know how can I solve it?
Actually, considering I need a source term dimensioned as [00-10000] I wrote the equation in this was, but I still don't get the error. Regards. alex
/*{CEqn.H}*\
solve
fvm::ddt(C)
+fvm::div(phi, C)
-fvm::laplacian(nu, C)==
fvm::ddt(C*(1-C))
Making dependency list for source file SourceFanzySimple.C
SOURCE=SourceFanzySimple.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/cvos/shared/apps/OpenFOAM/OpenFOAM-1.7.1/src/turbulenceModels -I/cvos/shared/apps/OpenFOAM/OpenFOAM-1.7.1/src/turbulenceModels/incompressible/RAS/RASModel -I/cvos/shared/apps/OpenFOAM/OpenFOAM-1.7.1/src/transportModels -I/cvos/shared/apps/OpenFOAM/OpenFOAM-1.7.1/src/transportModels/incompressible/singlePhaseTransportModel -I/cvos/shared/apps/OpenFOAM/OpenFOAM-1.7.1/src/finiteVolume/lnInclude -IlnInclude -I. -I/cvos/shared/apps/OpenFOAM/OpenFOAM-1.7.1/src/OpenFOAM/lnInclude -I/cvos/shared/apps/OpenFOAM/OpenFOAM-1.7.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/SourceFanzySimple.o
In file included from SourceFanzySimple.C:63:
Ceqn.H: In function âint main(int, char**)â:
Ceqn.H:6: error: no matching function for call to âddt(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >)â
/cvos/shared/apps/OpenFOAM/OpenFOAM-1.7.1/src/finiteVolume/lnInclude/readSIMPLEControls.H:6: warning: unused variable âmomentumPredictorâ
/cvos/shared/apps/OpenFOAM/OpenFOAM-1.7.1/src/finiteVolume/lnInclude/readSIMPLEControls.H:9: warning: unused variable âtransonicâ
make: *** [Make/linux64GccDPOpt/SourceFanzySimple.o] Error 1
Old   January 31, 2011, 05:52
santos's Avatar
Jose Luis Santos
I am not sure you can include your source term like that, ddt should be in the form ddt(C) or ddt(rho,C).
If you need: (C*(1-C))/dt, then try:
solve
fvm::ddt(C)
+fvm::div(phi, C)
fvm::Sp(1-C,C)/runTime.deltaT()
The source term is not fully implicit, as 1-C is defined explicitly. Maybe someone else knows how to define the whole term implicit.
Regards,
Jose
solefire likes this.
Old   January 31, 2011, 06:04
alessio.nz's Avatar
Alex
Thanks José!
I have also another way, just I want you to give me an opinion about it:
if I write explicitly the ST as (C*a*(1-C)) where "a" has the dimension of [1/time] to keep the dimension in the parabolic equation, setted in the transportproperties, do you think is it reasonable?
cheers,alex
Old   January 31, 2011, 06:19
santos's Avatar
Jose Luis Santos
Actually I have used in the past a 'quick and dirty' trick that allows you to do just that:
sourceTerm = (1-C)*C*runTime.deltaT().value()/runTime.deltaT();
Therefore, you get the correct dimension, without needing to care about the deltat value.
Regards,
Jose
sharonyue and rarnaunot like this.
Old   January 31, 2011, 08:56
alessio.nz's Avatar
Alex
thanks again for the reply!
regards,
Alex
Solve poisson equation just add a source term nandiganavishal OpenFOAM Running, Solving & CFD 18 November 14, 2022 10:12
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
Transport Equation for a scalar - Compressible Solver alessio.nz OpenFOAM Programming & Development 5 April 11, 2013 10:04
How to deal with this energy equation source term? H.S.Fang FLUENT 2 December 27, 2001 07:42
