How OpenFoam stores variable values
Like Tree2Likes
  • 1 Post By olesen
  • 1 Post By Luise
Old   July 26, 2010, 06:13
Unhappy How OpenFoam stores variable values
Antonio Martins
titio is on a distinguished road
Send a message via MSN to titio Send a message via Skype™ to titio
Hi Foamers.
I am having difficulties in understanding how OpenFoam stores variables, in particular dependent variables like for example velocity vector and stress tensor field, in the elements, and how it uses them when performing calculations, especially those associated with div schemes for convection and convective related derivatives.
Information in the literature, including Jasak thesis, are not very user friendly in this regard.
The problem is that my boss wants to know every little detail concerning OpenFoam, and he is having doubts that OpenFoam is any good.
Regards,
António Martins
titio is offline   Reply With Quote
Old   July 28, 2010, 06:33
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Originally Posted by titio View Post
Hi Foamers.
If you really wish to understand it, you'll have to wade your way through the source documentation. For example, starting with a volScalarField
http://foam.sourceforge.net/doc/Doxy...ca1069e5ec8d15
you can work back to the GeometricField http://foam.sourceforge.net/doc/Doxy...tricField.html
which gets you to a DimensionedField.html
http://foam.sourceforge.net/doc/Doxy...onedField.html
which has a dimensionSet http://foam.sourceforge.net/doc/Doxygen/html/classFoam_1_1dimensionSet.html for managing consistence in the operations and then there are the various bits of the field (internal, boundary..)
BTW: what happens when your boss can't get the same implementation information for a commercial code? I guess he wouldn't use a commercial code then.
aylalisa likes this.
olesen is offline   Reply With Quote
Old   August 4, 2010, 10:25
David Gaden
marupio is on a distinguished road
VectorSpace has the actual data members for the tensor and vector components, which it stores as arrays. OpenFOAM defines its own lists, which I doubt are much different from STL lists. Fields are lists with algebra defined (for instance, using operator overloads). GeometricFields are fields with boundaries defined.
The indexing of the lists varies by what is defined. For instance, the diagonal coefficients are scalarFields, indexed by cell number; the owner and neighbour coefficients are also scalarFields, but these are indexed by cell faces.
My boss also had concerns about OpenFOAM. It seems the open source can scare some people... but try and find a commercial code that tells you where its TensorFields are stored.
marupio is offline   Reply With Quote
Old   August 5, 2010, 15:58
Luise is on a distinguished road
You can find information about the basic principles in
Weller, Tabor, Jasak, Fureby; A tensorial approach to computational continuum mechanics using object-oriented techniques, 1998
http://powerlab.fsb.hr/ped/kturbo/op...apers/Foam.pdf.
Luise
Luise is offline   Reply With Quote
Old   September 2, 2010, 23:07
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
Quoting David:
I agree with you in the STL part, FOAM's List has an interface similar to STL one, but there is a very important difference, in FOAM, Lists are raw memory, from List.C we have:
00041 // Construct with length specified
00042 template<class T>
00043 Foam::List<T>::List(const label s)
00044 :
00045     UList<T>(NULL, s)
00046 {
00047     if (this->size_ < 0)
00048     {
00049         FatalErrorIn("List<T>::List(const label size)")
00050             << "bad size " << this->size_
00051             << abort(FatalError);
00052     }
00053
00054     if (this->size_)
00055     {
00056         this->v_ = new T[this->size_];
00057     }
00058 }
and has ramdom access capabilities. STL ones are based in linked lists.
Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
Old   September 2, 2010, 23:33
Hi Foamers.
maybe you can give some other info about your concerns. If I understand, much of you want to know is related with lists as people said. In Figure 2.5 from FOAM's Programmer's Guide, one can see that values of fields are stored in GeometricFields, they have a lot info but essentially the values of the field and its positions. To do so it is necessary to have pointers to a fvMesh and a Field, finally Field class has a List of type T, where List and T are classes too.
Respect of div schemes for convection and convective related derivatives, it depends on the kind of operations you want to do, if these are implicit operations (fvm) or explicit (fvc) ones.
Regards.
Research Scientist
Old   October 14, 2010, 11:56
Default Hi
T.D. is on a distinguished road
Hi
i have something like this and i don't know if it is implemented in openfoam
it is:
fvc::div(nusEff * T)
where nusEff is a scalar spacial varying viscosity law to be defined and T is a tensor
so if i do fvc::div(nusEff *T), will it be ok in openFoam? or it should be done another way?
How to define a new nusEff , lets for example in simpleFoam different from the existing nuEff()?
thanks
T.D. is offline   Reply With Quote
OpenFOAM - Validation of Results Ahmed OpenFOAM Running, Solving & CFD 10 May 13, 2018 19:28
Reference Values for Troughs @ variable Angle? hornig FLUENT 1 April 12, 2014 23:26
max node values exceed max element values in contour plot jason_t FLUENT 0 August 19, 2009 12:32
How to monitor variable values of point at t=0 sec yunhee CFX 3 February 13, 2008 13:45
Strongly variable and high viscosity bergantz OpenFOAM Running, Solving & CFD 1 June 23, 2007 11:02
