Reading forces from previous time step within solver
Like Tree1Likes
  • 1 Post By quarkz
Old   March 14, 2010, 07:58
Default Reading forces from previous time step within solver
Stefan
SD@TUB is on a distinguished road
Hello FOAMers,
what would be the best way of reading forces from previous time step within solver code? I'm calculating some cases with OF 1.6 via simpleFoam.
I noticed the function objects where pressure and viscous forces/moments are integrated over given walls (using "libforces.so"). In forces.C the
data of interest accessed by:
fm.first().first() (pressure forces) or fm.first().second() (viscous forces)
fm.second().first() (moment of pressure forces) or fm.second().second() (moment of viscous forces)
return fm;
fm.write();
Now i tried to catch the values within solver code. I added my own header in simpleFoam.C where i calculate some additional stuff. Within this header i want to initialize variables with the summarized forces (under consideration of the listed headers in forces.C), but it doesn't work. I did something like:
scalar Fp = fm.first().first();
scalar Fv = fm.first().second();
According to the OF programmers guide, field data from previous time step are associated with geometricField<type>. In my understanding this isn't applicable for calculated forces, because they applied to pressure and shear stress on walls.
I'm not familiar with the code conventions of OF and new to object oriented programming in C++! Any advice is much appreciated...
/Stefan
SD@TUB is offline   Reply With Quote
Old   May 25, 2016, 04:00
Federica Biano
federicabi is on a distinguished road
Originally Posted by SD@TUB View Post
Hello FOAMers,
return fm;
fm.write();
/Stefan
Hi!
I know that this is an old post but I'm very interested in it. Have you found a solution to that problem? I need to customize a restraint library inserting pressure and viscous forces calculated in the previous time step.
Do you have any suggestion?
Best regards
Federica
federicabi is offline   Reply With Quote
Old   August 19, 2020, 20:35
Exclamation Any updates?
Bernardo Ribeiro
beluiz93 is on a distinguished road
Hi all,
I'm also very interested in this problem. Has anyone managed to figure it out?
Thanks much!
Bernardo
beluiz93 is offline   Reply With Quote
Old   March 4, 2022, 02:42
TWB
quarkz is on a distinguished road
I also need to read the forces from the prev time step but I do not know how to do it.
Currently, what I did is:
1. I filter the forces output file to something simpler
2. read in that file to get the forces req
It works but it's slower.
quarkz is offline   Reply With Quote
Old   March 5, 2022, 07:29
Michael Alletto
mAlletto will become famous soon enough
I don't know if it is useful but geometric fields have the member function oldTime() and prevIter() which gives back the value of the field at the previous time step and iterations, respectly.
Best
Michael
mAlletto is offline   Reply With Quote
Old   April 24, 2023, 12:51
TWB
Hi all,
I have managed to get the forces and moments by directly calling from within OF.
I have attached the code, but some parts of my calculation are removed.
So anyone interested can just modify a bit to get it working for them. This is for OF v2206. Some ver may require removal of "s".
xiangxiang likes this.
forces, header, solver
Dynamic moving mesh Pei-Ying Hsieh (Hsieh) OpenFOAM Running, Solving & CFD 64 June 7, 2012 11:04
Reading old time step markc OpenFOAM Running, Solving & CFD 8 July 22, 2008 16:11
Doubt on Implicit Methods analyse In India Main CFD Forum 10 March 9, 2007 04:01
AMG versus ICCG msrinath80 OpenFOAM Running, Solving & CFD 2 November 7, 2006 16:15
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
