How to read a list from a dictionary?
Like Tree3Likes
  • 3 Post By vigneshTG
Old   December 29, 2009, 14:12
Default How to read a list from a dictionary?
Ivan Flaminio Cozza
ivan_cozza is on a distinguished road
Send a message via MSN to ivan_cozza
Hi Foamers,
I need to read a list of lists from a dictionary composed as follows:
listName
number of elements
(a b c d e f)
(g h i l m n)
where letters are labels. Something like blockMesh does when reading the blocks in blockMeshDict.
Can someone suggest me how to do it?
Thank you in advance,
Ivan
ivan_cozza is offline   Reply With Quote
Old   December 29, 2009, 15:22
Ola Widlund
olwi is on a distinguished road
Hi Ivan,
Knowing there's another piece of code that already does what you want is half the answer: If I was you, I would have a look at the source code for blockMesh, and see what it does to read the blockMeshDict.
/Ola
olwi is offline   Reply With Quote
Old   December 29, 2009, 18:33
Laurence R. McGlashan
l_r_mcglashan will become famous soon enough
I read in labels from a file using labelIOList, which is just a typedef for IOList<label>, so I imagine labelListIOList (IOList<labelList>) is what you want. It's probably used as follows:
labelListIOList listListName
IOobject
"listListName",
runTime.time().constant(), // Assuming your dictionary is in constant/
mesh,
IOobject::MUST_READ,
IOobject::NO_WRITE
variable of type List<labelList>
It looks like the functionality you looking for with reading the listList from a dictionary is in the file createTopology.C in the blockMesh folder.
Laurence R. McGlashan :: Website
l_r_mcglashan is offline   Reply With Quote
Old   January 2, 2010, 12:11
Ivan Flaminio Cozza
Thank you Laurence,
I tested your solution, and it works fine for me!
Ivan
IOobject
"listListName",
mesh,
IOobject::NO_WRITE
Old   August 29, 2014, 10:48
PicklER is on a distinguished road
Hello
Could you (Laurence or Ivan) please elaborate a little bit more how to achieve the reading in of a list. Say I want to read in the list "datP" that is (0.5 5.0 10.0) from the a file called "Data" in the constant directory. I followed the solution of Laurence but my lack of knowledge of C++ is not helping
In my my main program (solver):
#include "labelListIOList.H"
and
#include "readData.H"
readData.H looks as follows:
labelListIOList Data
IOobject
"Data",
mesh,
IOobject::NO_WRITE
labelList(datP)
I know the labelList(datP) is not correct. My Data file looks as follows (all files include headers):
datP (0.5 5.0 10.0);
Kind regards
PicklER is offline   Reply With Quote
Old   November 7, 2014, 05:13
Default IO object syntax for labelListList
Vignesh
vigneshTG is on a distinguished road
Dear All,
I tried to create IO object of type labelListList using the information i found in this thread which is given below
labelListIOList proxCells
IOobject
"proxCells",
mesh,
IOobject::NO_READ,
IOobject::AUTO_WRITE
I tried compiling it but i get an error as shown below
 p, li { white-space: pre-wrap; }  findProxCells.C: In function 'int main(int, char**)':
 findProxCells.C:95:1: error: expected primary-expression before ')' token
 make: *** [Make/linux64GccDPOpt/findProxCells.o] Error 1
Can some one tell me what i am missing in definition ?
Have a nice weekend !!
Thanks and Regards
Vignesh
vigneshTG is offline   Reply With Quote
Old   November 7, 2014, 09:31
Vignesh
Dear All,
Finally i found a solution, here it is !!
IOList<labelList> proximityCells(
      IOobject(
                "proximityCells",
                mesh,
                IOobject::NO_WRITE
Please correct me if i am wrong !
Thanks and Regards
Vignesh
reading a list of lists from a dictionary kian OpenFOAM Running, Solving & CFD 2 June 3, 2009 11:44
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 15:37
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
