rhoPisoFoam with radiation
Like Tree5Likes
  • 1 Post By braennstroem
  • 1 Post By gschaider
Old   October 22, 2009, 15:34
Default rhoPisoFoam with radiation
Fabian Braennstroem
braennstroem is on a distinguished road
I am struggling a bit with the implementation of a radiation source for rhoPisoFoam.
Basically, I added:
#include "radiationModel.H"
adjusted the options file with:
-I$(LIB_SRC)/thermophysicalModels/radiation/lnInclude \
-lradiation \
and added a radition source to the enthalpy eqn:
solve
fvm::ddt(rho, h)
+ fvm::div(phi, h)
- fvm::laplacian(turbulence->alphaEff(), h)
DpDt
+ radiation->Sh(thermo)
thermo.correct();
radiation->correct();
Unfortunately, I get this error, which I do not understand:
In file included from rhoPisoFoam.C:74:
hEqn.H: In function ‘int main(int, char**)’:
hEqn.H:9: error: expected primary-expression before ‘->’ token
hEqn.H:13: error: expected primary-expression before ‘->’ token
Has anyone an idea, what this means?
Thanks!
Fabian
Ramzy1990 likes this.
braennstroem is offline   Reply With Quote
Old   October 23, 2009, 05:49
Assistant Moderator
Bernhard Gschaider
Hi Fabian. You probably figured out by now, but I'll tell it anyway.
Basically it means "I don't know this radiation object you are talking about". Have you created it? Have a look at the last lines of createFields.H of the buoyantRadiationFoam-solver for an example
Bernhard
Old   October 23, 2009, 06:18
Fabian Braennstroem
Hallo Bernhard,
thanks for the explanation! Though it seems, that is not needed anymore in 1.6.x or maybe the object gets created in another way than in 1.5,where it is done with:
Info<< "Creating radiation model\n" << endl;
autoPtr<radiation::radiationModel> radiation
radiation::radiationModel::New(T)
Would be nice, if you have another suggestion.
Fabian
Old   October 23, 2009, 07:23
Assistant Moderator
Bernhard Gschaider
Hallo Bernhard,
I have. If you look at the C-file of that solver in 1.6 you'll see the line
#include "createRadiationModel.H"
which does exactly the same thing
Bernhard
Old   October 23, 2009, 12:01
Fabian Braennstroem
Hi Bernhard,
thanks did not see this ... was always looking for radiation not Radiation :-(
Fabian
Surface incident radiation Pipiola FLUENT 0 August 11, 2009 16:46
Multiphase radiation in CFX Luk_Fiz CFX 5 March 17, 2009 04:51
DO radiation model jarno brunetti FLUENT 0 January 21, 2006 16:52
Radiation: definitions visatron CFX 7 January 8, 2004 16:25
Fluent incident radiation problem Michael Schwarz Main CFD Forum 0 October 21, 1999 06:56
