natural logarithm function
Like Tree2Likes
  • 2 Post By isabel
Old   July 8, 2009, 10:38
Default natural logarithm function
ZHOU Bin
Location: Nanjing/Torino, Nanjing/Piemente, China/Italy
zhoubinwx is on a distinguished road
Send a message via ICQ to zhoubinwx Send a message via MSN to zhoubinwx Send a message via Skype™ to zhoubinwx
Dear all,
We know that for log function:
dimentionedScalar log (const dimentionedScalar & ds)
I try to get the log value of (r/R), where r is the distance between the point and cylinder center, R is the cylinder radius.
When I take a look at "analyticalCylinder" in programmers' guide, we see that
r = volScalarField magCentres;
R = dimensionedScalar radius
However, magCentres/radius (or magCentres/radius.value()) is not dimentionedScalar, so my question is:
do we have log function for this case? Or how could I convert volScalarField into dimentionedScalar, which is required by log function?
Thank you for your attention.
Bin
zhoubinwx is offline   Reply With Quote
Old   July 9, 2009, 03:20
Default solved
ZHOU Bin
This is solved.
Bin
Old   October 21, 2009, 03:27
J. Cai
chiven is on a distinguished road
Hi, dear Zhoubin, do you know how to convert dimentionedScalar into volScalarField? thanks. chiven
chiven is offline   Reply With Quote
Old   October 21, 2009, 06:51
Laurence R. McGlashan
l_r_mcglashan will become famous soon enough
If you solve something, then state how you have solved it. There is NOTHING worse (in my opinion) on message boards than searching through threads such as this!
Laurence R. McGlashan :: Website
l_r_mcglashan is offline   Reply With Quote
Old   July 2, 2010, 06:20
isabel
isabel is on a distinguished road
Hello friends,
I need to define the following variable; it is the natural logarithm of the time and a constant value:
volScalarField miso = ln(runTime+0.001);
But when I try to compile my solver I have the following error:
pdEqn.H:83: error: invalid initialization of reference of type ‘const Foam::fileName&’ from expression of type ‘Foam::dimensionedScalar’
Does anybody know what I have to do?
isabel is offline   Reply With Quote
Old   July 4, 2010, 07:30
'ln' is not what you think it is. 'ln' is defined in openfoam as:
bool ln                      (           const fileName &             src,
          const fileName &             dst
Old   July 5, 2010, 05:30
isabel
ln is the natural logarithm. I have successfully compiled my solver by introducing a surfaceScalarField unit variable:
miso = ln(unit*(runTime + 0.001*scalar(1))));
I am not sure if this is the best option.Does anyone have any better solution, or any comment?
soheil_r7 and Luttappy like this.
Old   July 5, 2010, 05:42
I can't see how that works. Use 'Foam::log' which returns a dimensionedScalar and computes the natural logarithm.
Old   July 5, 2010, 07:13
isabel
Thank you very much. I prefer your suggestion.
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 10:31
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 01:35
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
