Using the snGrad operation
Like Tree4Likes
  • 2 Post By hjasak
  • 1 Post By akidess
  • 1 Post By Novas
Old   August 2, 2006, 11:16
Default Using the snGrad operation
Ruediger Bahrmann
bahrmann is on a distinguished road
I want to modify the epsilon equation of the LaunderGibsonRSTM in the way, which is discribed below. The Problem lies in the snGrad() operation. With snGrad(...) in the equation, compiling the code is not possible. By changing the gradient with a constant, compiling the code is possible.
Could anybody say, what mistake I'm doing?
=================ORIGINAL=EQUATION================ ===========
tmp<fvscalarmatrix> epsEqn
fvm::ddt(epsilon_)
+ fvm::div(phi_, epsilon_)
//- fvm::laplacian(Ceps*(k_/epsilon_)*R_, epsilon_)
- fvm::laplacian(DepsilonEff(), epsilon_)
C1*G*epsilon_/k_ + boundarySource
- fvm::Sp(C2*epsilon_/k_ + boundaryCentral, epsilon_)
================MODIFIED=EQUATION================= ===========
fvm::ddt(epsilon_)
- fvm::Sp(C2*(1.0-((C2-1.4)/C2)*exp(-sqr(sqr(k_)/(6.0*epsilon_*nu()))))*(epsilon_- 2.0*nu()*sqr(fvc::snGrad(pow(k_,0.5))))/k_ + boundaryCentral, epsilon_)
Thanks,
Rüdiger
bahrmann is offline   Reply With Quote
Old   August 2, 2006, 11:29
Default Yes. The first parameter of f
Hrvoje Jasak
Yes. The first parameter of fvm::Sp should be a volume scalar field. In your operations you use fvc::snGrad(pow(k_,0.5) which is a face-normal gradient of k^0.5 (why not sqrt k?).
A face-normal gradient is defined on the faces, and you cannot sum up a cell centred and a face centred field. My guess is that you assume snGrad is doing something different from what it actually does.
Hrv
ramon and nepomnyi like this.
Hrvoje Jasak
Old   August 3, 2006, 10:13
Default Hrvoje, Thank you for answe
Ruediger Bahrmann
Hrvoje,
Thank you for answering so quickly. The answer was very plausible. I think you could help me.
Rüdiger
Old   January 28, 2011, 10:44
Illya Shevchuk
linch is on a distinguished road
what about
phi&(fvc::snGrad(rho))
I suppose phi to be a face centred vector field, and rho to be a cell centred scalar field, so fvc::snGrad(rho) should transform it to a face centered vector field or am I wrong?
I get an error
no match for ‘operator&’ in ‘phi & Foam::fvc::snGrad(const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&) [with Type = double]()’
when I try to perform the operation
linch is offline   Reply With Quote
Old   January 28, 2011, 11:48
akidess's Avatar
Anton Kidess
phi is a surfaceScalarField. It's components are the vector U scalar multiplied with the vector Sf on a face.
nepomnyi likes this.
Old   October 1, 2015, 05:30
David Casasnovas
Novas is on a distinguished road
Originally Posted by linch View Post
what about
I get an error when I try to perform the operation
Obviously is too late for answering this post, but it could help to someone with the same issue. The problem in this operation is that you are trying to make a dot product between a scalar and a vector , instead of two vectors. The correct code is (the outer product between scalar and vector):
phi*(fvc::snGrad(rho))
Novas is offline   Reply With Quote
Operation conditions Paweł FLUENT 2 October 27, 2006 02:35
File operation in UDF Ajay FLUENT 0 April 10, 2004 17:33
Boolean operation Lam FLUENT 1 July 22, 2003 18:18
About the technology of operation Masaru Phoenics 0 June 14, 2003 00:58
Matrix operation : Jay FLUENT 0 November 11, 2002 10:20
