OpenFoam profiling the solver simpleFoam
Like Tree3Likes
  • 3 Post By rob3rt 0ng
Old   February 4, 2008, 08:16
Default OpenFoam profiling the solver simpleFoam
Andre
andre is on a distinguished road
Hi guys,
I am new to OpenFoam and I want to profile the simpleFoam solver. In order to this, I included -pg at EXE_INC and EXE_LIBS in the option file located in $FOAM_SOLVERS/incompressible/simpleFoam/Make/
After recompiling this solver, I run the pitzDaily case by:
simpleFoam . pitzDaily (am already in the $FOAM_RUN/tutorials/simpleFoam directory)
After that it takes a long time to finish the calculations. If I watch the gprof results, by:
gprof $FOAM_APPBIN/simpleFoam gmon.out and watch the total execution time, it tells me it took almost 20 seconds to finish, but the real execution time took 190 seconds. (BTW i changed the endtime in the controlDict file to 200 in stead of 1000, otherwise it took to long to wait)
My questions are: Should I include the -pg flag in more option files? and why is there a difference in the real execution time and the results of gprof?
Greetings, Andre
andre is offline   Reply With Quote
Old   February 6, 2008, 07:37
Default Anyone with ideas plz?
Andre
Old   February 11, 2008, 08:10
Default I recompiled OpenFoam with WM_
Andre
I recompiled OpenFoam with WM_COMPILE_OPTION=Prof to enable profiling.
Again, if i run
simpleFoam . pitzDaily and profile the result, I find out that the real execution time takes 192 seconds, but Gprof profiles only 23 seconds.
I am still wondering what the CPU is doing for 192-23 = 169 seconds.
Can anyone help me with this?
Thanks
Old   February 27, 2008, 09:35
Default Is this somehow related with t
Andre
Is this somehow related with the ldl and math library that are included?
I would appreciate any kind of help.
Thanks
Old   March 10, 2008, 09:39
Default I have a feeling that I am tal
Andre
I have a feeling that I am talking to myself
Can anyone please give me some hints, or help me solving this issue.
Thanks.
Old   March 10, 2008, 12:01
Default 192s is the wall-clock time of
Assistant Moderator
Bernhard Gschaider
192s is the wall-clock time of the profiling-enabled executable? How long does the executable without profiling run? My guess ist, that it would be approx 23 seconds. Maybe the 169s is the administrative effort of the profiling? (But I'm not an expert on profiling, I only know that a profiling executable runs significantly slower)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   March 10, 2008, 14:34
Default Have you tried valgrind/kcache
Mattijs Janssens
mattijs is on a distinguished road
Have you tried valgrind/kcachegrind (which emulates your processor). Produces amazing pictures ;-)
mattijs is offline   Reply With Quote
Old   March 11, 2008, 10:36
Default Kcachegrind is indeed useful i
Andre
Kcachegrind is indeed useful if memory/cache usage must be investigated, but I want to profile for timing and to find out in which function most CPU-time is spend.
Thanks for the replies.
Old   April 7, 2011, 22:39
Robert Ong
rob3rt 0ng is on a distinguished road
Hi Andrea,
I think what Mattijs meant is to run your simulation using this command
valgrind --tool=callgrind <executableName>
then you can obtain block diagrams (along with its executable time) and graph using
kcachegrind <callgrindFileName>
Thanks and regards,
Robert
louisgag, Tobi and serles like this.
rob3rt 0ng is offline   Reply With Quote
Old   April 29, 2017, 09:51
Default how to optimize simpleFoam solver in OpenFOAM
Savita Mane
savee is on a distinguished road
I am trying to optimize simpleFoam solver in OpenFOAM. I have tried with the optimization flags available like O2, O3. The error here is that it is not able to include .h files which are included in the .C file.
If suppose in simpleFoam.C file, the .h file included is fvCFD.H. It is not including that file. Even if I give the full path of that file from /home/...upto that file/fvCFD.H. Then, the next error is like, it will include that file, but in that fvCFD.H, we have again another number of .h files to include.
So, how can we resolve this problem.. Any idea?
savee is offline   Reply With Quote
SimpleFoam as Newtonian laminar flow solver titio OpenFOAM Running, Solving & CFD 2 March 8, 2013 05:44
Dimension change in solver like simpleFoam booz OpenFOAM Running, Solving & CFD 2 August 21, 2008 12:35
MPI profiling OpenFOAM damBreak3D application mellanoxuser OpenFOAM Pre-Processing 0 April 14, 2008 00:15
MPI profiling OpenFOAM damBreak3D application mellanoxuser OpenFOAM Running, Solving & CFD 0 April 14, 2008 00:04
SimpleFoam as laminar solver anja OpenFOAM Pre-Processing 3 April 5, 2007 10:28
