Dimensionless parameters
Like Tree1Likes
  • 1 Post By olesen
Old   January 15, 2009, 17:26
Default Dimensionless parameters
Antonio Martins
titio is on a distinguished road
Send a message via MSN to titio Send a message via Skype™ to titio
Hi all,
I need to define in the transport properties dictionary that do not have dimensions. My strategy was to define them as dimensioned, but placing only zeros in the dimensions definitions. Is this correct, or there is any command that can be used?
Thanks in advance,
Antonio
titio is offline   Reply With Quote
Old   January 16, 2009, 03:59
Default Hi Put the following code i
florian
Location: Mannheim - Vincennes - Valenciennes, Deutchland - France
floooo is on a distinguished road
Hi
Put the following code in createFields.H:
dimensionedScalar name
transportProperties.lookup("name")
and then this one in transportProperties files:
name name [0 0 0 0 0 0 0] 0.5;
Florian
floooo is offline   Reply With Quote
Old   January 16, 2009, 06:11
Default I'd first recommend adding a s
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
I'd first recommend adding a subdictionary to transport properties to avoid possible collision with existing or future names and to cleanly group your variables. I'd also assume that you'd like to enter dimensionless variables without needing to enter the "[0 0 0 0 0]" dimensions, or even bother with adding the name twice (once for the dictionary keyword and once for the dimensionedScalar).
In transportProperties (or somewhere else), add your subdictionary:
antonioSpecialDict
firstParam 1.0;
secondParam 2.0;
Then in your code (eg, createFields.H), use the lookupOrAddToDict static member:
dimensionedScalar param1
dimensionedScalar::lookupOrAddToDict
("firstParam", antonioDict, 10)
dimensionedScalar param2
( "secondParam", antonioDict, 20 )
dimensionedScalar param3
("thirdParam", antonioDict, 30)
This approach not only saves lots of typing in the dictionary, it also lets you specify default values.
If you wish to be extra safe, you'll want to check the original dictionary (eg, transportProperties) for the "antonioSpecialDict" first, and supply the code with an alternative place to edit if necessary.
I guess that dimensionedType should actually have a normal dict lookup (eg, lookupOrDefault) that doesn't alter the dictionary. Maybe you should submit a enhancement request for that.
HakikiCanakkaleli likes this.
olesen is offline   Reply With Quote
Old   February 29, 2016, 04:26
Post
Muhammad Usman
13msmemusman is on a distinguished road
Simply use
varible = runTime.controlDict().lookupOrDefault<scalar>("var ible", 0);
13msmemusman is offline   Reply With Quote
Old   December 10, 2016, 08:06
Smile to use the dimensionless N-S equations in OpenFOAM
Bill Wang
6863523 is on a distinguished road
Dear,
I want to use the dimensionless equations in OpenFOAM. Anyone knows how to turn off the dimension checking? I have posted my problem here
How to use the dimensionless N-S equations in OpenFOAM
Thank you in advance for any suggestions.
Best Regards,
Bill
6863523 is offline   Reply With Quote
Dimensionless Analysis Seamus FLUENT 1 February 28, 2011 13:18
Dimensionless numbers kuba FLUENT 2 September 6, 2007 05:48
Dimensionless quantities badri1979 OpenFOAM Running, Solving & CFD 1 August 22, 2006 18:47
dimensionless equation Subrat Das CFX 0 December 10, 2001 06:30
DIMENSIONLESS SOLVER SC HU FLUENT 2 July 27, 2000 22:58
