fixedGradientFvPatchScalarField or fixedGradientFvPatchField? |
November 10, 2024, 07:46 |
Teddy Liu
Rep Power: 2 |
Hello!
I am using OpenFOAM-v2212, and trying to understand the boundary condition: fixedFluxPressure. But I find the code rather strange, as it calls member functions from a class that seems does not exist (fixedGradientFvPatchScalarField). I searched in the API guide only to find a class named "fixedGradientFvPatchField". How could this code possibly run without errors? I think it may be a version-related issue, but I still can't understand. in fixedFluxPressureFvPatchScalarField.C: Code:
void Foam::fixedFluxPressureFvPatchScalarField::updateSnGrad ( const scalarField& snGradp ) { if (updated()) { return; } curTimeIndex_ = this->db().time().timeIndex(); gradient() = snGradp; fixedGradientFvPatchScalarField::updateCoeffs(); // could it probably be fixedGradientFvPatchField? } |
November 10, 2024, 14:10 |
Rep Power: 14 |
The answer is a little subtle. Class fixedGradientFvPatchScalarField is the implementation of the fixedGradientFvPatchField class, for a scalar field (the field type is the class parameter). It is generated in fixedGradientFvPatchFields.H (https://www.openfoam.com/documentati...8H_source.html), which calls a macro in fvPatchField.H
(https://www.openfoam.com/documentati...ce.html#l00715) to generate the class. That's why you can't find it in Doxygen, or with a grep on the src folder. |
November 10, 2024, 14:19 |
The dependency graph at https://www.openfoam.com/documentati...rField_8H.html
does show that fixedFluxPressureFvPatchScalarField does call fixedGradientFvPatchScalarField. Not sure how this complements what Tobermory provides as information. |
November 11, 2024, 08:18 |
Teddy Liu
Rep Power: 2 |
Wow, Thank You, Tobermory!! It really helped! I never thought it would be a generate class.
November 11, 2024, 08:30 |
#5 | |
Teddy Liu
Rep Power: 2 |
boundary condition, fixedfluxpressure, fixedgradient |
