Momentum equation in buoyantBoussinesqSimpleFoam
Like Tree1Likes
  • 1 Post By CuriousFluidDynamics
Old   September 9, 2024, 11:03
Default Momentum equation in buoyantBoussinesqSimpleFoam
CuriousFluidDynamics is on a distinguished road
Dear all,
I am very new to OpenFOAM so my apologies in advance if this question is too basic.
For the solver of buoyantBoussinesqSimpleFoam there is this term in the momentum equation:
ghf*fvc::snGrad(rhok)
I understood it as:
g_n \nabla ( 1 - \beta (T -T_{ref}))
Where \beta is the thermal expansion coefficient, T the temperature and g_n the inner product of the gravitational acceleration with the location of the face centres. However, why do we take the gradient? From the Boussinesq assumption, there does not seem to be one at first glance: https://en.wikipedia.org/wiki/Boussi...ion_(buoyancy)
CuriousFluidDynamics is offline   Reply With Quote
Old   September 10, 2024, 13:43
Tobermory will become famous soon enough
This term arises because OpenFOAM buoyant solvers don't solve for the static pressure, they solve for a quantity called p_rgh (for stability reasons), which is akin to an anhydrostatic pressure:
p_{rgh} = p - \rho( \vec{g}\cdot \vec{h})
Stick this into the momentum equation, and you will see where the \nabla \rho term comes from (and where the gravity term disappears to).
Tobermory is offline   Reply With Quote
Old   September 12, 2024, 09:27
Thank Tobermory! This really helped. Finally I also found an derivation here: https://www.openfoam.com/documentati...orm-p-rgh.html
Tobermory likes this.
boussinesq, buoyantboussinesqsimple
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 22:43
How to manually add Boussinesq Approximation to the momentum equation of a solver? chymalaia OpenFOAM Programming & Development 2 February 5, 2021 10:07
add a pressure drop term in the momentum equation a.lone FLUENT 0 July 3, 2019 07:48
Domain Reference Pressure and mass flow inlet boundary AdidaKK CFX 75 August 20, 2018 06:37
Coefficients discretized momentum equation michujo Main CFD Forum 4 June 20, 2012 02:33
