custom tree-canopy fvOptions class, error when launching |
July 3, 2024, 08:10 |
María Rosales
Rep Power: 3 |
Good day dear community,
I want to model the effect of a bunch of trees in atmospheric flow. I know there some tools already in openfoam ESI for canopy but I want to follow strictly Dalpe & Masson theory on this. I have only elaborated a class for the source terms on turbulent variables: k and epsilon & omega. The files are attached below. These variable grows in value in this type of physics, so I assumed by '-=' it is a source term, and not a sink. Either way changing + to - or viceversa does not help when simulating. The idea is to apply these sourceterms to a cellSet via a fvOption tool. They compile without issues (wclean .all + wmake libso) in my custom user library for openfoam ESI V2012. The issue happens when running simpleFoam in OpenFOAM ESI 2012 in a singlecore, terminal prompts this error: Code:
mmros@mmros:~/OpenFOAM/mmros-v2306/run/simulations/forestPractices/p1-TurbSourceOnly$ simpleFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2012 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : _7bdb509494-20201222 OPENFOAM=2012 Arch : "LSB;label=32;scalar=64" Exec : simpleFoam Date : Jul 03 2024 Time : 12:46:03 Host : mmros PID : 230848 I/O : uncollated Case : /home/mmros/OpenFOAM/mmros-v2306/run/simulations/forestPractices/p1-TurbSourceOnly nProcs : 1 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 SIMPLE: convergence criteria field p tolerance 1e-08 field U tolerance 1e-08 field "(k|epsilon)" tolerance 1e-12 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type RAS Selecting RAS turbulence model kEpsilon RAS { RASModel kEpsilon; turbulence on; printCoeffs on; Cmu 0.09; C1 1.44; C2 1.92; C3 0; sigmak 1; sigmaEps 1.3; } No MRF models present Creating finite volume options from "constant/fvOptions" Selecting finite volume options type treeCanopySource Source: forestTurbSource - selecting cells using cellSet wdCellSet - selected 160 cell(s) with volume 31277.4802 Applying treeCanopySource to: epsilon and k with Turb. model constants of: Cmu: 0.09C1: 1.43C2: 1.92sigmaE: 1.3sigmaK: 1 The canopy values of Cd: 0.8 and LAD: 2 with betaP: 1 Starting time loop Time = 1 DILUPBiCGStab: Solving for Ux, Initial residual = 0.007754258079, Final residual = 1.248271136e-05, No Iterations 3 DILUPBiCGStab: Solving for Uy, Initial residual = 1, Final residual = 2.908675916e-05, No Iterations 3 DILUPBiCGStab: Solving for Uz, Initial residual = 1, Final residual = 0.001796598423, No Iterations 3 GAMG: Solving for p, Initial residual = 1, Final residual = 0.04614133528, No Iterations 30 GAMG: Solving for p, Initial residual = 0.0002426027944, Final residual = 1.159132676e-05, No Iterations 32 GAMG: Solving for p, Initial residual = 1.156102622e-05, Final residual = 8.983712988e-07, No Iterations 28 time step continuity errors : sum local = 8.612708198e-08, global = 9.50297687e-09, cumulative = 9.50297687e-09 #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigSegv::sigHandler(int) at ??:? #2 ? in /lib/x86_64-linux-gnu/libc.so.6 #3 Foam::tmp<Foam::fvMatrix<double> > Foam::fv::optionList::source<double>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::word const&, Foam::dimensionSet const&) at ??:? #4 Foam::tmp<Foam::fvMatrix<double> > Foam::fv::optionList::operator()<double>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::word const&) at ??:? #5 Foam::RASModels::kEpsilon<Foam::IncompressibleTurbulenceModel<Foam::transportModel> >::correct() at ??:? #6 ? in ~/OpenFOAMv2012/OpenFOAM-v2012/platforms/linux64GccDPInt32Opt/bin/simpleFoam #7 ? in /lib/x86_64-linux-gnu/libc.so.6 #8 __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6 #9 ? in ~/OpenFOAMv2012/OpenFOAM-v2012/platforms/linux64GccDPInt32Opt/bin/simpleFoam Segmentation fault (core dumped) I have attached the files of the class with the make files, + the fvOption file to ease the test. I bet the issue maybe in my source terms but I'm not quite sure how to make them implicit if it's the case. Big thanks to anyone who can take a look on this, Last edited by MMRC; July 3, 2024 at 08:12. Reason: addedAttachmnent |
July 3, 2024, 09:11 |
María Rosales
Rep Power: 3 |
Hello community,
I think my answer is in this tutorial that covers the same topic and clarifies how to define implicit terms: https://www.tfd.chalmers.se/~hani/ku..._Segersson.pdf |
July 5, 2024, 05:17 |
Asking for new help
María Rosales
Rep Power: 3 |
Hello community,
I changed the way of handling the topic, instead of a loop inside a cellSet, which was quite tricky to find a way to apply implicit terms in fvMatrix form into a specific group of cells, I will rely now on on having scalar fields of my Cd and LAD mapped in the mesh, so whether these values are non zero, then a sink/source term will appear in the flow. The tutorial showed that addSup could be overload so in one class we can code source term for a vector (velocity) and a scalar (k,epsilon...etc) I can not compile my new class implementation. New errors are related to: 1) In TKE: Code:
In file included from ../fvOptions/sources/derived/treeCanopySource/treeCanopySource.H:329, from ../fvOptions/sources/derived/treeCanopySource/treeCanopySource.C:28: ../fvOptions/sources/derived/treeCanopySource/treeCanopySourceTemplates.C:89:67: note: mismatched types ‘Foam::DimensionedField<Type, GeoMesh>’ and ‘Foam::Field<double>’ 89 | alpha()*rho()*calcPlantCanopyTerm(U)*betaP_*pow(mag(U),2) - fvm::Sp(betaD_*calcPlantCanopyTerm(U),k) | ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ In file included from /home/mmros/OpenFOAMv2012/OpenFOAM-v2012/src/OpenFOAM/lnInclude/DimensionedField.C:590, from /home/mmros/OpenFOAMv2012/OpenFOAM-v2012/src/OpenFOAM/lnInclude/DimensionedField.H:420, from /home/mmros/OpenFOAMv2012/OpenFOAM-v2012/src/finiteVolume/lnInclude/fvMesh.H:61, from /home/mmros/OpenFOAMv2012/OpenFOAM-v2012/src/fvOptions/lnInclude/cellSetOption.H:104, from ../fvOptions/sources/derived/treeCanopySource/treeCanopySource.H:122, from ../fvOptions/sources/derived/treeCanopySource/treeCanopySource.C:28: /home/mmros/OpenFOAMv2012/OpenFOAM-v2012/src/OpenFOAM/lnInclude/DimensionedFieldFunctions.C:370:1: note: candidate: ‘template<class Type1, class Type2, class GeoMesh> Foam::tmp<Foam::DimensionedField<typename Foam::typeOfSum<arg1, arg2>::type, GeoMesh> > Foam::operator-(const Foam::DimensionedField<TypeR, GeoMesh>&, const Foam::DimensionedField<Type1, GeoMesh>&)’ 370 | operator op \ | ^~~~~~~~ /home/mmros/OpenFOAMv2012/OpenFOAM-v2012/src/OpenFOAM/lnInclude/DimensionedFieldFunctions.C:643:1: note: in expansion of macro ‘PRODUCT_OPERATOR’ 643 | PRODUCT_OPERATOR(typeOfSum, -, subtract) | ^~~~~~~~~~~~~~~~ /home/mmros/OpenFOAMv2012/OpenFOAM-v2012/src/OpenFOAM/lnInclude/DimensionedFieldFunctions.C:370:1: note: template argument deduction/substitution failed: 370 | operator op \ | ^~~~~~~~ /home/mmros/OpenFOAMv2012/OpenFOAM-v2012/src/OpenFOAM/lnInclude/DimensionedFieldFunctions.C:643:1: note: in expansion of macro ‘PRODUCT_OPERATOR’ 643 | PRODUCT_OPERATOR(typeOfSum, -, subtract) And for epsilon, there is this alert: Code:
In file included from ../fvOptions/sources/derived/treeCanopySource/treeCanopySource.H:329, from ../fvOptions/sources/derived/treeCanopySource/treeCanopySource.C:28: ../fvOptions/sources/derived/treeCanopySource/treeCanopySourceTemplates.C: In instantiation of ‘void Foam::fv::treeCanopySource::treeCanopySourceEpsilon(const AlphaFieldType&, const RhoFieldType&, Foam::fvMatrix<double>&, Foam::label) [with AlphaFieldType = Foam::geometricOneField; RhoFieldType = Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>; Foam::label = int]’: ../fvOptions/sources/derived/treeCanopySource/treeCanopySource.C:293:32: required from here ../fvOptions/sources/derived/treeCanopySource/treeCanopySourceTemplates.C:63:12: error: no matching function for call to ‘Sp(Foam::tmp<Foam::Field<double> >, const volScalarField&)’ 63 | fvm::Sp(rho() * alpha() * calcPlantCanopyTerm(U)* (Ce4 * betaP_ * pow(mag(U), 2) - Ce4 * betaD_ * k), epsilon) I followed as reference the previous tutorial and the current fvOption atmPlantCanopyTurbSource code. I attached a new compressed folder where the source files + fvOption dict + boundary dicts are included to ease the test The idea is to mostly run this sourceterm with simpleFoam, and sometimes maybe with bouyantBoussinesqSimpleFoam Big tanks to anyone that can take a look in this. |
#canopy, #fvoptions, #openfoam, #programming, #source modelling |
Can't use "const fvMesh& mesh" in custom class? | keepfit | OpenFOAM Programming & Development | 0 | October 12, 2021 09:47 |
Undefined reference to custom class | cryabroad | OpenFOAM Programming & Development | 5 | July 3, 2018 03:21 |
The udf.h headers are unable to open- in VISUAL STUDIO 13 | sanjeetlimbu | Fluent UDF and Scheme Programming | 4 | May 2, 2016 06:38 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 21:30 |
