Reading a case with different mesh
Like Tree1Likes
  • 1 Post By FBenz
Old   April 10, 2024, 10:51
Default Reading a case with different mesh
Eva
emunoz is on a distinguished road
I am solving a flow (let's call it simulation0) that uses the solution of another simulation (let's call it simulation1) to compute some coefficients needed for the simulation.
I read the variables from simulation1 like:
Y_ref.set
I
new volScalarField
IOobject
name_Yref,
location_simulation1,
mesh,
IOobject::MUST_READ,
IOobject::NO_WRITE
mesh
But, "mesh" is the mesh of simulation0, so the dimensions don't match with simulation1.
I tried to read the mesh of simulation1 like following, but I need runTime or an object similar which I don't know how to reach:
Foam::fvMesh mesh1
Foam::IOobject
Foam::fvMesh::defaultRegion,
runTime,
Foam::IOobject::MUST_READ
How can I read it?
Eva.
emunoz is offline   Reply With Quote
Old   May 6, 2024, 04:52
Default reading different Meshes
Felix Benz
FBenz is on a distinguished road
i guess this question is already up for a couple of days, but maybe this will help:
If you want to read in a mesh from a different directory than constant (I assume here is your mesh from simulation0) you have to replace Foam::fvMesh::defaultRegion with the directory.
e.g.
Foam::fvMesh mesh1
Foam::IOobject
"region1", // read the mesh from constant/region1 directory
runTime.time().timeName(), // adjust the timestep here in case you have different meshes for different times
runTime,
Best regards
Felix
emunoz likes this.
FBenz is offline   Reply With Quote
mesh, openfoam10, read
Volume and Surface mesh taking a lot of time ghost_rider1145 FLUENT 0 March 20, 2024 12:36
[Commercial meshers] Problem with Mesh conversion from FLUENT Meshing to OpenFOAM mn17jyf OpenFOAM Meshing & Mesh Conversion 3 November 1, 2023 10:49
flow over cylinder in openFoam saeed jamshidi OpenFOAM Pre-Processing 3 August 11, 2023 16:16
execFlowFunctionObjects - unknown field problem Toorop OpenFOAM Post-Processing 16 March 14, 2016 04:25
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
