Combining dynamic mesh motion and refinement OF-v2206 |
February 21, 2024, 10:15 |
Paul R
Hello everyone,
I am trying to combine dynamicMotionSolverFvMesh with dynamicRefineFvMesh using esi version of OpenFOAM-v2206. I went across multiple post like this one : https://shorturl.at/tFHY8 And other link like this one : https://shorturl.at/exyX0 That explain quite clearly how to do it on OpenFOAM-2.4.x Eventho, it was not the same version of Openfoam I tried to follow as best as possible the main steps to achieve that. Those steps are : - Copying dynamicRefineFvMesh and rename it as dynamicMotionSolverRefineFvMesh - Replace inside the .H and .C file the dynamicRefineFvMesh by dynamicMotionSolverRefineFvMesh - Add fiew lines inside the Make/files and Make/options. - Then create a motion pointer inside the .H file. / Add to the .H and .C the correct files at the beginning ("#include ....H") / Add to the .C file the functions used inside the dynamicMotionSolverFvMesh to move points. - Compile the new solver. - Modify the dynamicMeshDict. But when I run it I encounter this error message : ''"" --> FOAM FATAL ERROR: (openfoam-2206) The number of points in the mesh seems to have changed. In constant/polyMesh there are 141254 points; in the current mesh there are 231329 points. From virtual void Foam::sixDoFRigidBodyMotionSolver::solve() in file sixDoFRigidBodyMotionSolver/sixDoFRigidBodyMotionSolver.C at line 195. FOAM exiting ''"" What I understand is that after refining the mesh, sixDoFRigidBodyMotionSolver (which is the motionSolver) is still looking for mesh infos inside my constant/polyMesh folder which is not updated. Instead it should be looking at the ones created by the refinement part inside the steps folders "0", "0.5"... So I tried to ckeck where the mesh informations are transmitted to the motionSolver to resolve this but a clear lack of C++ skills on my side is making it really difficult. Is there a way to fix this ? Maybe by updating at every step the constant/polyMesh folder or by pointing the input of the motionSolver to the step folders... Moreover, I did some testing on my case : When I remove the moving object the refinement is working and the simulation runs properly. When I put a threshold impossible to reach for my refinement, the motion part is working and the simulation runs properly. Those two tests makes me think that I am not that far from merging the two solvers but I'm not quite there yet. I'll attached the dynamicMeshDict and the solver .C, Template.C, .H, Make/options and Make/files files to this post. Thank you for your help and your time ! Last edited by Paul R; February 22, 2024 at 11:32. |
August 5, 2024, 04:42 |
Rep Power: 2 |
Hi Paul,
I'm also exploring the combination of dynamic mesh motion and refinement. Have you managed to get it to work? Looking forward to your response. Best, Julien |
November 8, 2024, 06:20 |
Paul R
Hi Julien,
Sorry for the late reply, I moved on to an other project whithout finding a solution for this one. However, if anyone find something, i'll still be interested ! Best of luck, Paul |
dynamic mesh, solver coupling, waves multiphaseinterfoam |
mesh refinement and mesh motion | Jim1310 | OpenFOAM Running, Solving & CFD | 1 | December 22, 2023 07:45 |
flow over cylinder in openFoam | saeed jamshidi | OpenFOAM Pre-Processing | 3 | August 11, 2023 16:16 |
Combining mesh motion and refinement | mturcios777 | OpenFOAM Programming & Development | 15 | September 16, 2022 02:04 |
Mesh Disappering with Dynamic Mesh | FaroukH | FLUENT | 0 | February 23, 2021 19:26 |
Interesting Bug in InterDyMFOAM (Dynamic Mesh Refinement) parallel restart | mostanad | OpenFOAM Programming & Development | 1 | November 24, 2020 05:07 |
