wallShearStress using the multiphaseEulerFoam
Like Tree1Likes
  • 1 Post By Severus
Old   February 18, 2024, 17:19
Default wallShearStress using the multiphaseEulerFoam
gu1
Guilherme
gu1 is on a distinguished road
I need to calculate the wallShearStress using the multiphaseEulerFoam solver (OpenFOAM 9).
I used the funkySetFieldsDict function as follows:
        wallShearStress
		field               wallShearStress;
		create              true;
		aliases             { Uwater U.water; }
		expression          "sqr(sqrt(3e-7*mag(snGrad(Uwater))))*7800";
		dimensions          [0 2 -2 0 0 0 0];
I squared u_Tau and multiplied it by the density of the fluid.
However, the snGrad() function has apparently been suppressed. It made an error. Can anyone help me calculate the wallShearStress?
gu1 is offline   Reply With Quote
Old   February 19, 2024, 14:55
Shravan
Severus is on a distinguished road
I am not sure how to do it with swak4Foam. There could be other people who can help you with that.
However this functionality has been implemented in OpenFOAM v11.
https://twitter.com/CFDdirect/status...28819646144515
https://cpp.openfoam.org/v11/wallShe...8H_source.html
You can see the code and possibly try to implement it in v9.
Good luck!
gu1 likes this.
Severus is offline   Reply With Quote
Old   October 14, 2024, 07:55
gu1
Guilherme
Good luck!
I remember you helped me and I would like to ask for your help again... I created the topic below, if you can visit it.
wallShearStress - MultiphaseEuler - turbulence model
Thanks.
Old   October 18, 2024, 11:01
gu1
Guilherme
I managed to compile, but without much success. If you can help.
wallShearStress function - OpenFOAM 9 - Error
multiphaseeulerfoam, openfoam9, wallshearstress
Plotting the wallShearStress - flat plate problem simucentral OpenFOAM Post-Processing 1 January 5, 2023 06:28
please help me understand the output of wallShearStress New-to-CFD OpenFOAM Post-Processing 1 May 4, 2020 06:37
Finding wallShearStress in dbnsTurbFoam BSengupta OpenFOAM 4 October 21, 2019 22:17
why does 'sample' do this? wallShearStress question CHARLES OpenFOAM Post-Processing 0 August 7, 2013 20:30
wallShearStress VS wallGradU bigrock OpenFOAM Post-Processing 0 July 2, 2013 06:54
