Adding a modified turbulence model to OpenFOAM v2012
Like Tree2Likes
  • 2 Post By chemak
Old   January 15, 2024, 12:58
Default Adding a modified turbulence model to OpenFOAM v2012
Tim_ is on a distinguished road
I am wanting to modify the existing LES turbulence model, Keqn, and have the modified version as a new selectable model when running my simulation (e.g. myKeqn). I understood how to do this in the older versions of open foam (e.g v2.4.0) by compiling it with a makefile and options files. However since the file structure has seemingly changed for OpenFOAM v2012 I am unsure of the best way to go about this.
I have tried adding the modified model using the makeLES function in a make turbulence transport models file to no great success. From what I can understand this all relates to there now being a base class template and potentially the syntax? (but i could very well be mistaken!)
I apologies if this has already been covered and would appreciate being pointed in the right direction.
Tim_ is offline   Reply With Quote
Old   January 16, 2024, 05:05
chemak is on a distinguished road
Recently I implemented a modified RANS model in v2112 following this reference. I think it should work for you too.
https://www.tfd.chalmers.se/~hani/ku...lenceModel.pdf
talop and Tim_ like this.
chemak is offline   Reply With Quote
custom application, openfoamv2012, turbulence model
[GUIDE] Switching turbulence model to SpalartAllmaras gabrielfelix OpenFOAM Running, Solving & CFD 1 March 24, 2022 21:19
Table bounds warnings at: END OF TIME STEP CFXer CFX 4 July 17, 2020 00:44
Trying to implement my own modified LienCubicKE model in OpenFOAM 5.0 rohitsaini@y7mail.com OpenFOAM Programming & Development 1 May 11, 2019 12:26
OpenFOAM 4.0 Released CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 2 October 6, 2017 06:40
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
