Field on Processor forgets values?!
Like Tree1Likes
  • 1 Post By olesen
Old   December 20, 2023, 21:00
Question Field on Processor forgets values?! / Code not running the same on all processors
Luke Hirl
Luke99 is on a distinguished road
So I was working on getting my code parallelized and one part of it was assigning unique values to all cells over all processors. (So that no cell had the same value, when you recombine all processors)
List<scalar> lowCellId(Pstream::nProcs(), 0.0);
List<scalar> highCellId(Pstream::nProcs(), 0.0);
highCellId[Pstream::myProcNo()] = 1.0 * mesh.nCells();
Pstream::gatherList(highCellId);
Pstream::scatterList(highCellId);
for (label procX = 0; procX < Pstream::myProcNo(); ++procX)
	lowCellId[Pstream::myProcNo()] += highCellId[procX];
highCellId[Pstream::myProcNo()] += lowCellId[Pstream::myProcNo()];
Pout<< "from" << lowCellId[Pstream::myProcNo()] <<"to"<<highCellId[Pstream::myProcNo()]<<endl;
for (scalar celli = lowCellId[Pstream::myProcNo()]; celli < highCellId[Pstream::myProcNo()]; celli += 1)
	uniqueCellNo[celli] = celli;
        if(Pstream::myProcNo() == 1)
		Pout<<uniqueCellNo[celli]<<endl;
forAll(uniqueCellNo,celli)
Thats the code I'm using (uniqueCellNo is a simple volScalarField)
My Problem is that when running with more than one processor, all uniqueCellNo fields will have the value of zero. Except for the Master Processor. It has the values I expect.
So I included the lines:
to see if maybe the value assignment fails on all but the master processor. but this works and for the first loop where I do the assignment it prints out the right values to the console. However for every processor except the master it has already forgotten the values by the last loop, with nothing happening in between.
Does anyone know a solution for this. Or can explain to me why the assigned values seem to go out of scope?
Luke99 is offline   Reply With Quote
Old   December 21, 2023, 05:56
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
I will side-step your question entirely and suggest that you take a look at the globalIndex class.
I would probably write something like this:
const globalIndex gi(mesh.nCells());
List<label> uniqueIds = identity(gi.localSize(), gi.localStart());
If your version of OpenFOAM doesn't have that specific identity function:
List<label> uniqueIds(mesh.nCells())
std::iota(uniqueIds.begin(), uniqueIds.end(), gi.localStart());
Luke99 likes this.
olesen is offline   Reply With Quote
Old   December 21, 2023, 06:35
Luke Hirl
Well that seems a lot easier and it works.
Thank you very much
assignment, parallel, parallel calculation
How to write the sampled field values of a curved internal surface? cfdcheckers OpenFOAM Post-Processing 3 July 17, 2021 11:28
[Other] dynamicTopoFVMesh and pointDisplacement RandomUser OpenFOAM Meshing & Mesh Conversion 6 April 26, 2018 08:30
''unknown radialModelType type Gidaspow'' PROBLEM WITH THE BED TUTORIAL AndoniBM OpenFOAM Running, Solving & CFD 2 March 25, 2015 19:44
Old and new values of a field Franko OpenFOAM Programming & Development 2 February 27, 2015 05:06
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
